Why do not see my wireless point-to-point link w/discover?
Hi guys!
I am newbie from dude, but not from mikrotik and routeros…
I use “discover” over my wireless network and i find all of my rb… and all my server and it’s ok…
but, I seen a little problem: I don’t see link 'bout rb and rb and don’t see my link if is down or simply TX/RX status…
I try again and nothing… always the same like before
so try another time with another place in a simple LAN (locally) and there discover all and all links…
What is the problem? Eventuality, how can I add links and their online status manually?
thx 4 all! rgds
I had to add all wireless links manually. If Dude has detected RouterOS on the device you can select which wireless interfaces can be monitored.
To add a link click the red + and draw it between devices.
ok guy, i done by own…
thx the same…
even me i had to add manually all, but now it’s ok!
thx
