Why does masquerade send routers ip address to source
Hi there at the moment i am using a rb750g to relay dns requests from 172.16.3.0/24 and 172.16.4.0/24.
One of the statis relays is set to a samba server, the ip is 172.16.1.5.
I also had to add masquerade to the rb750g and i am able to conenct and ping the samba router.
But i have set the samba firewall to only allow 172.16.3.4.
I did some test and found that when samba firewall is active then i am unable to connect to it, but when i add 172.16.1.0/24 to allow list then it works. The rb750g has a ip address of 172.16.1.200 and i think that this ip is forwarded and not 172.16.3.4.
Is it possible to setup mikrotik to redirect source ip to dst-ip?
Here is what i would like to acomplish…
All requests is send to the rb750g and then it redirects the incomming ip address(172.16.3.4) to dst source without changing ip address.
I suppose you need to use DST-NAT.
Add rule to /ip firewall nat
Set src-address, action=dsnat and to-addresses (local IP address, where traffic should be redirected to).
Thank you. I tried this.
ip firewall nat add chain=dstnat src-address=172.16.3.0/24 action=dst-nat to-addresses=172.16.1.0/24
But it does not work.
When i putty to samba server then it says last login was from 172.16.1.200(rb750g ether1 address)
that’s because you’re using masquerading. remove that srcnat rule =)
p.s. for me, “Why does masquerade send routers ip address to source?” sounds like “Why does Sun shine?..”
masquerade DOES replace packet src-address with router’s address - it is for what it was introduced =)
Hi i did some test. And i am unable to fix this.
What i would like to know is..
  1. under action → dst-nat must the ip address be the address of a dns server? I tried to put the targer server address there but that does not work.
As others said: If your problem is that the source IP address is translated, stop source NAT’ing that traffic. That has nothing to do with destination NAT.
Edit: Generally speaking without seeing your configuration and what you’re trying to do (network diagram) you probably want to add an ‘out-interface=WAN-port’ to any NAT rules with an action of ‘masquerade’ in your configuration.
Edit 2: Add “Edit:” to above since there’s been a post since.
it should work. post your NAT config
Hi Chupaka! :smiley:
Ok here is what i currently have.
[admin@MikroTik] /ip firewall nat> print
 0   chain=srcnat action=masquerade src-address=172.23.128.0/24
 1   chain=dstnat action=dst-nat to-addresses=172.16.1.0-172.16.1.255
     src-address=172.16.3.0/28
PS: 172.23.128.0/24 is my wan ip address, i am also using the rb750g as time server and radius server
if you want to redirect DNS requests, you should use something like
chain=dstnat src-address=172.16.3.0/24 protocol=udp dst-port=53 action=dst-nat to-addresses=172.16.1.5
So that means that all request from 172.16.3.0/24 will be forwarded to 172.16.1.5 ?
or
when i putty to 172.16.1.5 then i will connect to server with the ip address of the computer that i am using?
that means that all DNS request from 172.16.3.0/24 will be forwarded to 172.16.1.5
Thank you. So all i need to do is to setup a dns server on the 172.16.1.0/24 side.
thank you
