WHY Does One Thread LOCKUP my Firefox
I can enter any thread and add posts etc, but this post locks up my computer, anyone else have this issue??
Sometimes the thread is half visible, and certainly cannot enter any new posts.
http://forum.mikrotik.com/t/disconnected-from-lan-port-and-all-other-connections-loose-ip/165468/1
I use Firefox 64 111.0.1 and Canvas style, and apparently is working ok…
Try to clear Firefox “last day” cache…
That doesnt explain why every other thread works fine including this one… will try
Well my firefox is zippier and all thread works except that one…
I’m going to paste here the same 15000 lines export…
See if this topic still working…
Ok, I must delete the export of this topic do not longer works, is the 15k lines export the problem…
Sounds like that chaps firefox is super sensitive LOL
It’s not Firefox. Works fine here…
You missed the point entirely, the OP had a gazillion lines on his config ( think entire blacklist of addresses ) - since removed.
Noted. @anav use Lynk…
