Why doesn't PCQ work correctly?
I’m trying to do some bandwith management for my home network. I’ve been told that PCQ is the simplest way to distribute bandwidth equally.
This is the tutorial that I followed: http://mum.mikrotik.com/presentations/CZ09/QoS_Megis.pdf
My network setup looks like this:
I want to add that PC1 sometimes runs a few VMs in bridged mode.
The ISP connection has 2mbps down/1mbps up external, and 100mbps down/20mbps up metropolitan, but these speeds sometimes vary a lot.
The problem is that when heavy downloading/uploading, the network 10.223.44.0/29 takes the whole bandwidth and the PC from 10.223.45.0/30 isn’t able to do anything online.
Here’s everything that I’ve done(inspired from tutorial):
Mangle
/ip firewall mangle print
0   chain=forward action=change-ttl new-ttl=increment:1
1   chain=forward action=change-ttl new-ttl=increment:1
2   chain=forward action=mark-connection new-connection-mark=44.0-con
     passthrough=yes src-address=10.223.44.0/29
3   chain=forward action=mark-connection new-connection-mark=44.0-con
     passthrough=yes dst-address=10.223.44.0/29
4   chain=forward action=mark-packet new-packet-mark=44.0_traffic
     passthrough=no connection-mark=44.0-con
5   chain=forward action=mark-packet new-packet-mark=44.0_traffic
     passthrough=no src-address=10.223.44.0/29
6   chain=forward action=mark-packet new-packet-mark=44.0_traffic
     passthrough=no dst-address=10.223.44.0/29
7   chain=forward action=mark-connection new-connection-mark=45.0-con
     passthrough=yes src-address=10.223.45.0/30
8   chain=forward action=mark-connection new-connection-mark=45.0-con
     passthrough=yes dst-address=10.223.45.0/30
9   chain=forward action=mark-packet new-packet-mark=45.0_traffic
     passthrough=yes connection-mark=45.0-con
10   chain=forward action=mark-packet new-packet-mark=45.0_traffic
     passthrough=no src-address=10.223.45.0/30
11   chain=forward action=mark-packet new-packet-mark=45.0_traffic
     passthrough=no dst-address=10.223.45.0/30
12   ;;; marking for apex
     chain=postrouting action=mark-packet new-packet-mark=port40100-3
     passthrough=no protocol=tcp port=40100-40103 packet-mark=44.0_traffic
13   chain=postrouting action=mark-packet new-packet-mark=port40100-3
     passthrough=no protocol=udp port=40100-40103 packet-mark=44.0_traffic
14   chain=postrouting action=mark-packet new-packet-mark=port40104-7
     passthrough=no protocol=tcp port=40104-40107 packet-mark=44.0_traffic
15   chain=postrouting action=mark-packet new-packet-mark=port40104-7
     passthrough=no protocol=udp port=40104-40107 packet-mark=44.0_traffic
16   chain=postrouting action=mark-packet new-packet-mark=port40108-11
     passthrough=no protocol=tcp port=40108-40111 packet-mark=44.0_traffic
17   chain=postrouting action=mark-packet new-packet-mark=port40108-11
     passthrough=no protocol=udp port=40108-40111 packet-mark=44.0_traffic
18   chain=postrouting action=mark-packet new-packet-mark=port60000-3
     passthrough=no protocol=tcp port=60000-60003 packet-mark=44.0_traffic
19   chain=postrouting action=mark-packet new-packet-mark=port60000-3
     passthrough=no protocol=udp port=60000-60003 packet-mark=44.0_traffic
20   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic_http
     passthrough=yes protocol=tcp src-address=10.223.44.0/29 dst-port=80
21   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic_http
     passthrough=yes protocol=tcp dst-address=10.223.44.0/29 src-port=80
22   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic_http
     passthrough=yes protocol=udp src-address=10.223.44.0/29 dst-port=80
23   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic_http
     passthrough=yes protocol=udp dst-address=10.223.44.0/29 src-port=80
24   chain=forward action=log log-prefix=""
Queue Tree
/queue tree> print
0   name="44.0_down" parent=ether2 limit-at=0 priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
1   name="45.0_up" parent=Upload limit-at=0 priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
2   name="44.0_up" parent=Upload limit-at=0 priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
3   name="45.0_down" parent=ether3 limit-at=0 priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
4   name="p40100-3_up" parent=44.0_up packet-mark=port40100-3 limit-at=32k queue=default-small priority=8 max-limit=32k burst-limit=32k burst-threshold=1k
     burst-time=1s
5   name="pcq-download" parent=44.0_down packet-mark=44.0_traffic limit-at=0 queue=default priority=7 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
6   name="pcq-upload" parent=44.0_up packet-mark=44.0_traffic limit-at=0 queue=default-small priority=1 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
7   name="pcq-upload-45.0" parent=45.0_up packet-mark=45.0_traffic limit-at=0 queue=default priority=1 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
8   name="pcq-download-45.0" parent=45.0_down packet-mark=45.0_traffic limit-at=0 queue=default priority=1 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
9   name="p40104-7_up" parent=44.0_up packet-mark=port40104-7 limit-at=32k queue=default-small priority=8 max-limit=32k burst-limit=32k burst-threshold=1k
     burst-time=1s
10   name="p60000-3_up" parent=44.0_up packet-mark=port60000-3 limit-at=32k queue=default-small priority=8 max-limit=32k burst-limit=32k burst-threshold=1k
     burst-time=1s
11   name="p40108-11_up" parent=44.0_up packet-mark=port40108-11 limit-at=32k queue=default-small priority=8 max-limit=32k burst-limit=32k burst-threshold=1k
     burst-time=1s
12   name="p40100-3_down" parent=44.0_down packet-mark=port40100-3 limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
13   name="p40104-7_down" parent=44.0_down packet-mark=port40104-7 limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
14   name="p40108-11_down" parent=44.0_down packet-mark=port40108-11 limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
15   name="Upload" parent=ether1 limit-at=0 priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
16   name="p60000-3_down" parent=44.0_down packet-mark=port60000-3 limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
17   name="pcq-download-http" parent=44.0_down packet-mark=44.0_traffic_http limit-at=0 queue=default priority=7 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
18   name="pcq-upload-http" parent=44.0_up packet-mark=44.0_traffic_http limit-at=0 queue=default priority=1 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
Queue Type
/queue type print
0 name="default" kind=pfifo pfifo-limit=50
1 name="ethernet-default" kind=pfifo pfifo-limit=1000
2 name="wireless-default" kind=sfq sfq-perturb=5 sfq-allot=1514
3 name="synchronous-default" kind=red red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 red-avg-packet=1000
4 name="hotspot-default" kind=sfq sfq-perturb=5 sfq-allot=1514
5 name="my_pcq_download" kind=pcq pcq-rate=0 pcq-limit=1 pcq-classifier=dst-address pcq-total-limit=200
6 name="my_pcq_upload" kind=pcq pcq-rate=0 pcq-limit=1 pcq-classifier=src-address pcq-total-limit=200
7 name="default-small" kind=pfifo pfifo-limit=10
Can someone tell me what am I doing wrong?
For starters queue tree priority will not work w/o max limit defined for the parent. Given that your maximum bandwidth fluctuates using priority queuing or PCQ may not be optimal.
I’d try SFQ first: disable everything and create one simple queue with target 10.233.0.0/16 and SFQ queue. See how that works out.
rmichael, thank you for your suggestion.
I’ve tried it but, unfortunately I didn’t get the expected results.
I’ve noticed an improvement in downloading streams, but pages still load with a large delay.
I read here[http://www.opalsoft.net/qos/DS-25.htm] that SFQ works well only when the queues are full. I don’t know how to achieve that, and more importantly, my external bandwidth varies a lot lately[from 2mbps to 0.5mbps].
This problem is becoming really frustrating, I’ve tried so many things and I still can’t manage to make 2 PC’s surf the internet decently.
Any other suggestions?
pcq-limit=1 is too small. Change that value to 50 and test again.
I’ve changed the value back to 50, but the problem persists.
I’ve set PC1 to download a few files, from external sources. It was downloading them at ~ 2mbps.
On PC2, I’ve opened 3 pages, a google search, an youtube clip, and an wikipedia page. All of them were moving painfully slow. After 30secs I’ve closed the wiki page because it hadn’t loaded at all.
It sounds like DNS requests are being dropped. Make sure that you prioritize small tcp packets (ACK) and DNS for good performance. Also you should shape TCP and UDP traffic in separate queues.
EDIT: btw, because your max bandwidth varies, PCQ and priorities are not the best solutions. Both only work when your internet connection is capable of max-limit at any given point in time. If you say that 2Mbps is the lowest speed your connection gets then for HTB to work you have to set max-limit to 2M. This is the limitation of MT HTB implementation. Theoretically you could run a ping test and decrease or increase max-limit via script depending on latency (caused by congestion) but it is not very accurate.
rmichael, I am going to separate UDP and TCP traffic, but there is one thing that I don’t really know how to do it. Do I have to add a mark-connection rule each time I add a new mark-packet rule?
For example, first I’d have to mark traffic for each network(44.0 and 45.0), and here I have mark-connection rules as well.
Then I’d have to mark it for UDP, or TCP. Do I have to add mark-connection rules for TCP and UDP again?
Also, there’s one thing that I find it really odd. Please check the Mangle image for rules 2,3,4,5,6.
2,3 are used to mark connections both src and dst for network 44.0.
5,6 are used to mark packets both src and dst for network 44.0.
but most of the traffic is on rule 4, which has no src and no dst.
This makes no sense, because traffic from 5 + traffic from 6 is a lot less compared to traffic that passes through 4(125GB vs 16MB).
If I don’t add that 4 rule, most of the traffic will end up unmarked, down to the last “log” rule.
Please help me out with this problem. I can’t continue like this. :frowning:
Here’s what I’ve done recently:
  1. implemented a metropolitan peering address-list(hopefully, these are the networks that my ISP has peering with)
  2. split traffic in metropolitan, extern, tcp, udp, other streams
    3)implemented the correspoding queue tree for these streams
Still, haven’t decided what kind of queue types to use for each queue of the queue tree.
 2   ;;; new packet marking
     chain=forward action=mark-connection new-connection-mark=44.0-con passthrough=yes src-address=10.223.44.0/29
 3   chain=forward action=mark-connection new-connection-mark=44.0-con passthrough=yes dst-address=10.223.44.0/29
 4   chain=forward action=mark-packet new-packet-mark=44.0_traffic passthrough=no src-address=10.223.44.0/29
 5   chain=forward action=mark-packet new-packet-mark=44.0_traffic passthrough=no dst-address=10.223.44.0/29
 6   chain=forward action=mark-connection new-connection-mark=45.0-con passthrough=yes src-address=10.223.45.0/30
 7   chain=forward action=mark-connection new-connection-mark=45.0-con passthrough=yes dst-address=10.223.45.0/30
 8   chain=forward action=mark-packet new-packet-mark=45.0_traffic passthrough=no src-address=10.223.45.0/30
 9   chain=forward action=mark-packet new-packet-mark=45.0_traffic passthrough=no dst-address=10.223.45.0/30
10   ;;; metro 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro passthrough=yes
     dst-address-list=metropolitan packet-mark=44.0_traffic
11   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro passthrough=yes
     src-address-list=metropolitan packet-mark=44.0_traffic
12   ;;; metro 45.0
     chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-metro passthrough=yes
     dst-address-list=metropolitan packet-mark=45.0_traffic
13   chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-metro passthrough=yes
     src-address-list=metropolitan packet-mark=45.0_traffic
14   ;;; ext 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext passthrough=yes
     dst-address-list=!metropolitan packet-mark=44.0_traffic
15   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext passthrough=yes
     src-address-list=!metropolitan packet-mark=44.0_traffic
16   ;;; ext 45.0
     chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-ext passthrough=yes
     dst-address-list=!metropolitan packet-mark=45.0_traffic
17   chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-ext passthrough=yes
     src-address-list=!metropolitan packet-mark=45.0_traffic
18   ;;; metro other+tcp+udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-other passthrough=yes
19   ;;; metro tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-tcp passthrough=yes protocol=tcp
20   ;;; metro udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-udp passthrough=yes protocol=udp
21   ;;; ext other+tcp+udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-other passthrough=yes
22   ;;; ext tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-tcp passthrough=yes protocol=tcp
23   ;;; ext udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-udp passthrough=yes protocol=udp
24   ;;; metro other+tcp+udp 45.0
     chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-metro-other passthrough=yes
25   ;;; metro tcp 45.0
     chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-metro-tcp passthrough=yes protocol=tcp
26   ;;; metro udp 45.0
     chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-metro-udp passthrough=yes protocol=udp
27   ;;; ext other+tcp+udp 45.0
     chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-ext-other passthrough=yes
28   ;;; ext tcp 45.0
     chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-ext-tcp passthrough=yes protocol=tcp
29   ;;; ext udp 45.0
     chain=postrouting action=mark-packet new-packet-mark=45.0_traffic-ext-udp passthrough=yes protocol=udp
30   ;;; adc1 metro tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-tcp-adc1 passthrough=yes protocol=tcp
     src-address=10.223.44.0/29 src-port=40100-40103 packet-mark=44.0_traffic-metro-tcp
31   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-tcp-adc1 passthrough=yes protocol=tcp
     dst-address=10.223.44.0/29 dst-port=40100-40103 packet-mark=44.0_traffic-metro-tcp
32   ;;; adc1 metro udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-udp-adc1 passthrough=yes protocol=udp
     src-address=10.223.44.0/29 src-port=40100-40103 packet-mark=44.0_traffic-metro-udp
33   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-udp-adc1 passthrough=yes protocol=udp
     dst-address=10.223.44.0/29 dst-port=40100-40103 packet-mark=44.0_traffic-metro-udp
34   ;;; adc1 ext tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-tcp-adc1 passthrough=yes protocol=tcp
     src-address=10.223.44.0/29 src-port=40100-40103 packet-mark=44.0_traffic-ext-tcp
35   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-tcp-adc1 passthrough=yes protocol=tcp
     dst-address=10.223.44.0/29 dst-port=40100-40103 packet-mark=44.0_traffic-ext-tcp
36   ;;; adc1 ext udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-ext-adc1 passthrough=yes protocol=udp
     src-address=10.223.44.0/29 src-port=40100-40103 packet-mark=44.0_traffic-ext-udp
37   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-udp-adc1 passthrough=yes protocol=udp
     dst-address=10.223.44.0/29 dst-port=40100-40103 packet-mark=44.0_traffic-ext-udp
38   ;;; adc2 metro tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-tcp-adc2 passthrough=yes protocol=tcp
     src-address=10.223.44.0/29 src-port=40104-40107 packet-mark=44.0_traffic-metro-tcp
39   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-tcp-adc2 passthrough=yes protocol=tcp
     dst-address=10.223.44.0/29 dst-port=40104-40107 packet-mark=44.0_traffic-metro-tcp
40   ;;; adc2 metro udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-udp-adc2 passthrough=yes protocol=udp
     src-address=10.223.44.0/29 src-port=40104-40107 packet-mark=44.0_traffic-metro-udp
41   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-udp-adc2 passthrough=yes protocol=udp
     dst-address=10.223.44.0/29 dst-port=40104-40107 packet-mark=44.0_traffic-metro-udp
42   ;;; adc2 ext tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-tcp-adc2 passthrough=yes protocol=tcp
     src-address=10.223.44.0/29 src-port=40104-40107 packet-mark=44.0_traffic-ext-tcp
43   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-tcp-adc2 passthrough=yes protocol=tcp
     dst-address=10.223.44.0/29 dst-port=40104-40107 packet-mark=44.0_traffic-ext-tcp
44   ;;; adc2 ext udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-ext-adc2 passthrough=yes protocol=udp
     src-address=10.223.44.0/29 src-port=40104-40107 packet-mark=44.0_traffic-ext-udp
45   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-udp-adc2 passthrough=yes protocol=udp
     dst-address=10.223.44.0/29 dst-port=40104-40107 packet-mark=44.0_traffic-ext-udp
46   ;;; adc3 metro tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-tcp-adc3 passthrough=yes protocol=tcp
     src-address=10.223.44.0/29 src-port=40108-40111 packet-mark=44.0_traffic-metro-tcp
47   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-tcp-adc3 passthrough=yes protocol=tcp
     dst-address=10.223.44.0/29 dst-port=40108-40111 packet-mark=44.0_traffic-metro-tcp
48   ;;; adc3 metro udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-udp-adc3 passthrough=yes protocol=udp
     src-address=10.223.44.0/29 src-port=40108-40111 packet-mark=44.0_traffic-metro-udp
49   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-udp-adc3 passthrough=yes protocol=udp
     dst-address=10.223.44.0/29 dst-port=40108-40111 packet-mark=44.0_traffic-metro-udp
50   ;;; adc3 ext tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-tcp-adc3 passthrough=yes protocol=tcp
     src-address=10.223.44.0/29 src-port=40108-40111 packet-mark=44.0_traffic-ext-tcp
51   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-tcp-adc3 passthrough=yes protocol=tcp
     dst-address=10.223.44.0/29 dst-port=40108-40111 packet-mark=44.0_traffic-ext-tcp
52   ;;; adc3 ext udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-ext-adc3 passthrough=yes protocol=udp
     src-address=10.223.44.0/29 src-port=40108-40111 packet-mark=44.0_traffic-ext-udp
53   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-udp-adc3 passthrough=yes protocol=udp
     dst-address=10.223.44.0/29 dst-port=40108-40111 packet-mark=44.0_traffic-ext-udp
54   ;;; adc4 metro tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-tcp-adc4 passthrough=yes protocol=tcp
     src-address=10.223.44.5 src-port=40108-40111 packet-mark=44.0_traffic-metro-tcp
55   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-tcp-adc4 passthrough=yes protocol=tcp
     dst-address=10.223.44.5 dst-port=40108-40111 packet-mark=44.0_traffic-metro-tcp
56   ;;; adc4 metro udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-udp-adc4 passthrough=yes protocol=udp
     src-address=10.223.44.5 src-port=40108-40111 packet-mark=44.0_traffic-metro-udp
57   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-udp-adc4 passthrough=yes protocol=udp
     dst-address=10.223.44.5 dst-port=40108-40111 packet-mark=44.0_traffic-metro-udp
58   ;;; adc4 ext tcp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-tcp-adc4 passthrough=yes protocol=tcp
     src-address=10.223.44.5 src-port=40108-40111 packet-mark=44.0_traffic-ext-tcp
59   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-tcp-adc4 passthrough=yes protocol=tcp
     dst-address=10.223.44.5 dst-port=40108-40111 packet-mark=44.0_traffic-ext-tcp
60   ;;; adc4 ext udp 44.0
     chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-metro-ext-adc4 passthrough=yes protocol=udp
     src-address=10.223.44.5 src-port=40108-40111 packet-mark=44.0_traffic-ext-udp
61   chain=postrouting action=mark-packet new-packet-mark=44.0_traffic-ext-udp-adc4 passthrough=yes protocol=udp
     dst-address=10.223.44.5 dst-port=40108-40111 packet-mark=44.0_traffic-ext-udp
62   chain=forward action=log log-prefix=""
 0   name="44.0_down_METRO" parent=ether2 limit-at=0 priority=4 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
 1   name="44.0_down_metro_tcp" parent=44.0_down_METRO packet-mark=44.0_traffic-metro-tcp limit-at=0 queue=default
     priority=4 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
 2   name="44.0_down_metro_udp" parent=44.0_down_METRO packet-mark=44.0_traffic-metro-udp limit-at=0 queue=default
 3   name="44.0_down_metro_other" parent=44.0_down_METRO packet-mark=44.0_traffic-metro-other limit-at=0 queue=default
 4   name="44.0_down_ext_other" parent=44.0_down_EXT packet-mark=44.0_traffic-ext-other limit-at=0 queue=default
 5   name="44.0_up_ext_tcp" parent=44.0_up_EXT packet-mark=44.0_traffic-ext-tcp limit-at=0 queue=default priority=4
 6   name="44.0_down_ext_udp" parent=44.0_down_EXT packet-mark=44.0_traffic-ext-udp limit-at=0 queue=default priority=4
 7   name="44.0_down_EXT" parent=ether2 limit-at=0 priority=4 max-limit=1150k burst-limit=0 burst-threshold=0
     burst-time=0s
 8   name="adc_down_ext_tcp" parent=44.0_down_EXT limit-at=0 priority=4 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
 9   name="adc1_down_ext_tcp" parent=adc_down_ext_tcp packet-mark=44.0_traffic-ext-tcp-adc1 limit-at=0 queue=default
10   name="adc_down_metro_tcp" parent=44.0_down_METRO limit-at=0 priority=4 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
11   name="adc1_down_metro_tcp" parent=adc_down_metro_tcp packet-mark=44.0_traffic-metro-tcp-adc1 limit-at=0
     queue=default priority=4 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
12   name="45.0_down_EXT" parent=ether3 limit-at=0 priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
13   name="45.0_down_METRO" parent=ether3 limit-at=0 priority=1 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
14   name="45.0_down_ext_other" parent=45.0_down_EXT packet-mark=45.0_traffic-ext-other limit-at=0 queue=default
15   name="45.0_down_ext_tcp" parent=45.0_down_EXT packet-mark=45.0_traffic-ext-tcp limit-at=0 queue=default priority=1
16   name="45.0_down_ext_udp" parent=45.0_down_EXT packet-mark=45.0_traffic-ext-udp limit-at=0 queue=default priority=1
17   name="adc_down_ext_udp" parent=44.0_down_EXT limit-at=0 priority=4 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
18   name="adc1_down_ext_udp" parent=adc_down_ext_udp packet-mark=44.0_traffic-ext-udp-adc1 limit-at=0 queue=default
19   name="45.0_down_metro_other" parent=45.0_down_METRO packet-mark=45.0_traffic-metro-other limit-at=0 queue=default
20   name="45.0_down_metro_tcp" parent=45.0_down_METRO packet-mark=45.0_traffic-metro-tcp limit-at=0 queue=default
21   name="45.0_down_metro_udp" parent=45.0_down_METRO packet-mark=45.0_traffic-metro-udp limit-at=0 queue=default
22   name="Upload_2" parent=ether1 limit-at=0 priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
23   name="44.0_up_EXT" parent=Upload_2 limit-at=0 priority=4 max-limit=900k burst-limit=0 burst-threshold=0
     burst-time=0s
24   name="44.0_up_METRO" parent=Upload_2 limit-at=0 priority=4 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
25   name="45.0_up_EXT" parent=Upload_2 limit-at=0 priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
26   name="45.0_up_METRO" parent=Upload_2 limit-at=0 priority=1 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
27   name="adc_down_metro_udp" parent=44.0_down_METRO limit-at=0 priority=4 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
28   name="adc1_down_metro_udp" parent=adc_down_metro_udp packet-mark=44.0_traffic-metro-udp-adc1 limit-at=0
29   name="45.0_up_ext_other" parent=45.0_up_EXT packet-mark=45.0_traffic-ext-other limit-at=0 queue=default priority=1
30   name="45.0_up_metro_tcp" parent=45.0_up_METRO packet-mark=45.0_traffic-metro-tcp limit-at=0 queue=default
31   name="45.0_up_ext_tcp" parent=45.0_up_EXT packet-mark=45.0_traffic-ext-tcp limit-at=0 queue=default priority=1
32   name="45.0_up_metro_udp" parent=45.0_up_METRO packet-mark=45.0_traffic-metro-udp limit-at=0 queue=default
33   name="45.0_up_ext_udp" parent=45.0_up_EXT packet-mark=45.0_traffic-ext-udp limit-at=0 queue=default priority=1
34   name="45.0_up_metro_other" parent=45.0_up_METRO packet-mark=45.0_traffic-metro-other limit-at=0 queue=default
35   name="44.0_up_ext_other" parent=44.0_up_EXT packet-mark=44.0_traffic-ext-other limit-at=0 queue=default priority=4
36   name="44.0_down_ext_tcp" parent=44.0_down_EXT packet-mark=44.0_traffic-ext-tcp limit-at=0 queue=default priority=4
37   name="44.0_up_ext_udp" parent=44.0_up_EXT packet-mark=44.0_traffic-ext-udp limit-at=0 queue=default priority=1
38   name="adc_up_ext_tcp" parent=44.0_up_EXT limit-at=0 priority=4 max-limit=32k burst-limit=0 burst-threshold=0
     burst-time=0s
39   name="adc1_up_ext_tcp" parent=adc_up_ext_tcp packet-mark=44.0_traffic-ext-tcp-adc1 limit-at=0 queue=default
40   name="adc_up_ext_udp" parent=44.0_up_EXT limit-at=0 priority=4 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
41   name="adc1_up_ext_udp" parent=adc_up_ext_udp packet-mark=44.0_traffic-ext-udp-adc1 limit-at=0 queue=default
42   name="44.0_up_metro_other" parent=44.0_up_METRO packet-mark=44.0_traffic-metro-other limit-at=0 queue=default
43   name="44.0_up_metro_tcp" parent=44.0_up_METRO packet-mark=44.0_traffic-metro-tcp limit-at=0 queue=default
44   name="44.0_up_metro_udp" parent=44.0_up_METRO packet-mark=44.0_traffic-metro-udp limit-at=0 queue=default
45   name="adc_up_metro_tcp" parent=44.0_up_METRO limit-at=0 priority=4 max-limit=32k burst-limit=0 burst-threshold=0
     burst-time=0s
46   name="adc1_up_metro_tcp" parent=adc_up_metro_tcp packet-mark=44.0_traffic-metro-tcp-adc1 limit-at=0 queue=default
47   name="adc_up_metro_udp" parent=44.0_up_METRO limit-at=0 priority=4 max-limit=0 burst-limit=0 burst-threshold=0
     burst-time=0s
48   name="adc1_up_metro_udp" parent=adc_up_metro_udp packet-mark=44.0_traffic-metro-udp-adc1 limit-at=0 queue=default
49   name="adc2_down_ext_tcp" parent=adc_down_ext_tcp packet-mark=44.0_traffic-ext-tcp-adc2 limit-at=0 queue=default
50   name="adc2_down_metro_tcp" parent=adc_down_metro_tcp packet-mark=44.0_traffic-metro-tcp-adc2 limit-at=0
51   name="adc2_down_ext_udp" parent=adc_down_ext_udp packet-mark=44.0_traffic-ext-udp-adc2 limit-at=0 queue=default
52   name="adc2_down_metro_udp" parent=adc_down_metro_udp packet-mark=44.0_traffic-metro-udp-adc2 limit-at=0
53   name="adc3_down_ext_tcp" parent=adc_down_ext_tcp packet-mark=44.0_traffic-ext-tcp-adc3 limit-at=0 queue=default
54   name="adc3_down_metro_tcp" parent=adc_down_metro_tcp packet-mark=44.0_traffic-metro-tcp-adc3 limit-at=0
55   name="adc3_down_ext_udp" parent=adc_down_ext_udp packet-mark=44.0_traffic-ext-udp-adc3 limit-at=0 queue=default
56   name="adc3_down_metro_udp" parent=adc_down_metro_udp packet-mark=44.0_traffic-metro-udp-adc3 limit-at=0
57   name="adc4_down_ext_tcp" parent=adc_down_ext_tcp packet-mark=44.0_traffic-ext-tcp-adc4 limit-at=0 queue=default
58   name="adc4_down_metro_tcp" parent=adc_down_metro_tcp packet-mark=44.0_traffic-metro-tcp-adc4 limit-at=0
59   name="adc4_down_ext_udp" parent=adc_down_ext_udp packet-mark=44.0_traffic-ext-udp-adc4 limit-at=0 queue=default
60   name="adc4_down_metro_udp" parent=adc_down_metro_udp packet-mark=44.0_traffic-metro-udp-adc4 limit-at=0
61   name="adc2_up_ext_tcp" parent=adc_up_ext_tcp packet-mark=44.0_traffic-ext-tcp-adc2 limit-at=0 queue=default
62   name="adc2_up_ext_udp" parent=adc_up_ext_udp packet-mark=44.0_traffic-ext-udp-adc2 limit-at=0 queue=default
63   name="adc2_up_metro_tcp" parent=adc_up_metro_tcp packet-mark=44.0_traffic-metro-tcp-adc2 limit-at=0 queue=default
64   name="adc3_up_ext_tcp" parent=adc_up_ext_tcp packet-mark=44.0_traffic-ext-tcp-adc3 limit-at=0 queue=default
65   name="adc3_up_ext_udp" parent=adc_up_ext_udp packet-mark=44.0_traffic-ext-udp-adc3 limit-at=0 queue=default
66   name="adc3_up_metro_tcp" parent=adc_up_metro_tcp packet-mark=44.0_traffic-metro-tcp-adc3 limit-at=0 queue=default
67   name="adc4_up_ext_tcp" parent=adc_up_ext_tcp packet-mark=44.0_traffic-ext-tcp-adc4 limit-at=0 queue=default
68   name="adc4_up_ext_udp" parent=adc_up_ext_udp packet-mark=44.0_traffic-ext-udp-adc4 limit-at=0 queue=default
69   name="adc4_up_metro_tcp" parent=adc_up_metro_tcp packet-mark=44.0_traffic-metro-tcp-adc4 limit-at=0 queue=default
70   name="adc2_up_metro_udp" parent=adc_up_metro_udp packet-mark=44.0_traffic-metro-udp-adc2 limit-at=0 queue=default
71   name="adc3_up_metro_udp" parent=adc_up_metro_udp packet-mark=44.0_traffic-metro-udp-adc3 limit-at=0 queue=default
72   name="adc4_up_metro_udp" parent=adc_up_metro_udp packet-mark=44.0_traffic-metro-udp-adc4 limit-at=0 queue=default
last picture.
It doesn’t work right because it seems that there are subnets in the metropolitan address-list that my ISP doesnt’ have peering with, rendering the whole thing(queue+mangle rules) useless.
I really don’t know what else to do.
Should I conclude that with RouterOS you can’t share the bandwidth for 2 subnets that are NAT-ed behind the router without having a guaranteed bandwidth internet connection?
