Do you think MT could make the watchdog turn off when I uncheck it and apply that change.
It’s sickening that something SO SIMPLE does not work properly when you turn it off.
I should not have to change the IP address to something else for it to turn off. Otherwise remove the stupid check box that lets you think you can turn it off.
