Why Fast Path not supported with hardware accelerated IPsec?
Packets of a fast-track-ed connection bypasses a lot of packet processing which is needed for ipsec.
IPSec processes (de- & encapsulation) each packet as it traverses the router, something that fast-track tries to avoid.
EoIP, GRE, IPIP, L2TP, PPPoE also do (de- & encapsulation), but FastPath/FastTrack supported
SNAT, DNAT also do packet processing, but FastPath/FastTrack supported
In that case, why not support FastTrack with hardware accelerated IPsec?
I don’t know if anything changed since 2019, but on my hAP ac^2, ROS v6.49 Fast Path and IPsec with hw. offload seems to work.
> ip ipsec installed-sa print brief
Flags: H - hw-aead, A - AH, E - ESP
# SPI SRC-ADDRESS DST-ADDRESS AUTH-ALGORITHM ENC-ALGORITHM ENC-KEY-SIZE
0 HE 0xB9B496E xx.xx.xx.xx:4500 yy.yy.yy.yy:4500 sha256 aes-cbc 256
1 HE 0xCA97F92B yy.yy.yy.yy:4500 xx.xx.xx.xx:4500 sha256 aes-cbc 256
> interface bridge settings print
use-ip-firewall: no
use-ip-firewall-for-vlan: no
use-ip-firewall-for-pppoe: no
allow-fast-path: yes
bridge-fast-path-active: yes
bridge-fast-path-packets: 13523898
bridge-fast-path-bytes: 10433833975
bridge-fast-forward-packets: 0
bridge-fast-forward-bytes: 0
