As we all know, huawei E5331 single linkage design, wifi access simple. General design can let you be clear at a glance, but my huawei E5331 display signal is full, strong. But often got disconnected, at first I thought it was a weak current problems, then I try several times are the same situation, why is this so? How to solve got disconnected problem?
Your post isn’t making a whole lot of sense. Please type your question in Google Translate, in your native language, and then post the English-translated version here.
Are you trying to use your Huawei E5331 MiFi device as a 3G modem interface for your Routerboard?
Is this possible at all?
To use Huawei E5331 MiFi device as a 3G modem interface for the Mikrotik Routerboard?
I don’t see it on compatibility list but it is still hope. If you plug it into your Mikrotik router (I assume you own a model with USB port or x86 machine), does it create a ppp-out interface automatically? If you check /system routerboard usb, do you see the device listed? What kind of RoS version are you using?
Yes it creates ppp-out interface when plugged in,
Yes there is an USB listing for it when plugged in
RoS details…
/system> routerboard print
routerboard: yes
model: 751G-2HnD
serial-number: 3A6502CFECC5
current-firmware: 2.38
upgrade-firmware: 2.38
Guess all its left is to try using it.. ![]()
You may only need to play a bit with channels and you should be set to go.
