Hello ,
I’m trying to build a simple windows foarm in C#
enter IP - press enter button - show my the uptime \ ROS of the unit
the enter IP and user\password is working
I can see I enter the router only after I press the button
but when I want to read information from it - “uptime”
I get error :
Severity Code Description Project File Line Suppression State
Error CS0103 The name ‘mikrotik’ does not exist in the current context WindowsFormsApplication1 C:\Users\Computer\Documents\Visual Studio 2015\Projects\WindowsFormsApplication1\WindowsFormsApplication1\Form1.cs 125 Active
this is what I have :
using System;
using System.Windows.Forms;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.IO;
using System.Net.Sockets;
using System.Net;
using System.Net.NetworkInformation;
namespace WindowsFormsApplication1
public partial class Form1 : Form
string IP;
string password;
public Form1()
InitializeComponent();
private void textBox1_TextChanged(object sender, EventArgs e)
IP = textBox1.Text;
public void button1_Click(object sender, EventArgs e)
button1.Text = "Click Here"; //change the button name after press
textBox2.Text = ("you have enter the router");
//textBox2.Text = ("this is what you have press " + IP +password ); //display saved value in another textbox
MK mikrotik = new MK(IP);
if (!mikrotik.Login("admin", password))
textBox2.Text = ("Could not log in - Wrong Password");
mikrotik.Close();
return;
private void radioButton1_CheckedChanged(object sender, EventArgs e)
password = "123456";
private void radioButton2_CheckedChanged(object sender, EventArgs e)
password = "MyPassword";
public void textBox3_TextChanged(object sender, EventArgs e)
mikrotik.Send("/system/resource/print");
mikrotik.Send("=.proplist=version,uptime", true);
class MK
Stream connection;
TcpClient con;
public MK(string ip)
con = new TcpClient();
con.Connect(ip, 8728);
connection = (Stream)con.GetStream();
public void Close()
connection.Close();
con.Close();
public bool Login(string username, string password)
Send("/login", true);
string hash = Read()[0].Split(new string[] { "ret=" }, StringSplitOptions.None)[1];
Send("/login");
Send("=name=" + username);
Send("=response=00" + EncodePassword(password, hash), true);
if (Read()[0] == "!done")
return true;
else
return false;
public void Send(string co)
byte[] bajty = Encoding.ASCII.GetBytes(co.ToCharArray());
byte[] velikost = EncodeLength(bajty.Length);
connection.Write(velikost, 0, velikost.Length);
connection.Write(bajty, 0, bajty.Length);
public void Send(string co, bool endsentence)
connection.WriteByte(0);
public List<string> Read()
List<string> output = new List<string>();
string o = "";
byte[] tmp = new byte[4];
long count;
while (true)
tmp[3] = (byte)connection.ReadByte();
//if(tmp[3] == 220) tmp[3] = (byte)connection.ReadByte(); it sometimes happend to me that
//mikrotik send 220 as some kind of "bonus" between words, this fixed things, not sure about it though
if (tmp[3] == 0)
output.Add(o);
if (o.Substring(0, 5) == "!done")
break;
else
o = "";
continue;
else
if (tmp[3] < 0x80)
count = tmp[3];
else
if (tmp[3] < 0xC0)
int tmpi = BitConverter.ToInt32(new byte[] { (byte)connection.ReadByte(), tmp[3], 0, 0 }, 0);
count = tmpi ^ 0x8000;
else
if (tmp[3] < 0xE0)
tmp[2] = (byte)connection.ReadByte();
int tmpi = BitConverter.ToInt32(new byte[] { (byte)connection.ReadByte(), tmp[2], tmp[3], 0 }, 0);
count = tmpi ^ 0xC00000;
else
if (tmp[3] < 0xF0)
tmp[1] = (byte)connection.ReadByte();
int tmpi = BitConverter.ToInt32(new byte[] { (byte)connection.ReadByte(), tmp[1], tmp[2], tmp[3] }, 0);
count = tmpi ^ 0xE0000000;
else
if (tmp[3] == 0xF0)
tmp[0] = (byte)connection.ReadByte();
count = BitConverter.ToInt32(tmp, 0);
else
//Error in packet reception, unknown length
break;
for (int i = 0; i < count; i++)
o += (Char)connection.ReadByte();
return output;
byte[] EncodeLength(int delka)
if (delka < 0x80)
byte[] tmp = BitConverter.GetBytes(delka);
return new byte[1] { tmp[0] };
if (delka < 0x4000)
byte[] tmp = BitConverter.GetBytes(delka | 0x8000);
return new byte[2] { tmp[1], tmp[0] };
if (delka < 0x200000)
byte[] tmp = BitConverter.GetBytes(delka | 0xC00000);
return new byte[3] { tmp[2], tmp[1], tmp[0] };
if (delka < 0x10000000)
byte[] tmp = BitConverter.GetBytes(delka | 0xE0000000);
return new byte[4] { tmp[3], tmp[2], tmp[1], tmp[0] };
else
return new byte[5] { 0xF0, tmp[3], tmp[2], tmp[1], tmp[0] };
public string EncodePassword(string Password, string hash)
byte[] hash_byte = new byte[hash.Length / 2];
for (int i = 0; i <= hash.Length - 2; i += 2)
hash_byte[i / 2] = Byte.Parse(hash.Substring(i, 2), System.Globalization.NumberStyles.HexNumber);
byte[] heslo = new byte[1 + Password.Length + hash_byte.Length];
heslo[0] = 0;
Encoding.ASCII.GetBytes(Password.ToCharArray()).CopyTo(heslo, 1);
hash_byte.CopyTo(heslo, 1 + Password.Length);
Byte[] hotovo;
System.Security.Cryptography.MD5 md5;
md5 = new System.Security.Cryptography.MD5CryptoServiceProvider();
hotovo = md5.ComputeHash(heslo);
//Convert encoded bytes back to a 'readable' string
string navrat = "";
foreach (byte h in hotovo)
navrat += h.ToString("x2");
return navrat;
I guess it’s something easy and stupid
Thanks,
