Why I can't use 5400Mhz by AX, if no choice country?
Why I can’t use 5400Mhz by AX, if no choice country?
Question for Mikrotik team, will superchanle be available at AX?
No country = Europe
If I have a license for frequency 5340, then I will not be able to use this frequency for the new driver?
PTP on DISC Lite5 ac
Normis, what do I do now if I don’t use Mikrotik in Europe, but in Kazakhstan and have a license for 5400MHz.
What solution will there be for me?
I bought 6 x L11UG-5HaxD for PtP, how can I now use my frequency 5400Mhz?
Set it to US?
https://en.wikipedia.org/wiki/List_of_WLAN_channels#5_GHz_(802.11a/h/n/ac/ax)
If set US, mikrotik say 5400Mhz no supported channels
Normis, please answer!
Set the frequency to 5400 and the mode to ‘superchannel’. Assuming the L11UG-5HaxD radios can physically do 5400 MHz, that should work: https://help.mikrotik.com/docs/display/ROS/Wireless+Interface#WirelessInterface-Generalinterfaceproperties
Wave2 does not have superchannel option. Contact support officially and open ticket.
I have the same problem, any solution?
they now have superchannel support.
Just select “superchannel” as the country
Yes but even using superchannel 5400MHz isn’t available
The U-NII-2B band is available nowhere in the world. See:
List of WLAN channels - Wikipedia
You can see the big void between 5350MHz and 5470MHz.
So are you telling me that there is no way to can use these frequencies? Really?
No, you can't use these frequencies legally anywhere on Earth ... unless you have a license. Since MT produces devices to be used by unlicensed owners, it's logical that devices are locked not to use illegal frequencies. If you have a license to use these channels, then you'll have to shell out a bit more money and purchase equipment with tailored capabilities.
There's "the lesser devil" with particular sub-bands and Tx powers which depend on countries ... where device owner has to set correct country not to violate local laws. No, the U-NII-2B is not in the same basket because very probably MT couldn't get approvals from any regulatory agency if this part was not blocked from factory.
MikroTik has been selling devices with this capability for years (and is still selling them), so “the regulatory authorities won’t approve it” argument doesn’t seem to go up.
To be fair, regulatory agencies have gradually but persistently become stricter with their compliance requirements and with enforcing them. And you only have to be certified once. (Even if a renewal is required, they rely heavily on the original.)
The usual solution to this for other (non-wifi) manufacturers is to provide additional "unlock packages" to distributors only. (I believe Mikrotik already does this in reverse: I think the US restrictions are actually installed as packages.)
We'll see if they're willing to do it. If there is a country that routinely issues permits for this band then maybe it's possible...
