why ipv4-fasttrack-active set to no ?
I set a fasttrack rule and there is no effect.
Could you explain why the ipv4-fasttrack-active is set to no and how can set it to yes or which are the conditions to have yes ?
ip setting print
              ip-forward: yes
          send-redirects: yes
     accept-source-route: no
        accept-redirects: no
        secure-redirects: yes
               rp-filter: no
          tcp-syncookies: no
    max-neighbor-entries: 8192
             arp-timeout: 30s
         icmp-rate-limit: 10
          icmp-rate-mask: 0x1818
             route-cache: yes
         allow-fast-path: yes
   ipv4-fast-path-active: no
  ipv4-fast-path-packets: 0
    ipv4-fast-path-bytes: 0
   ipv4-fasttrack-active: no
  ipv4-fasttrack-packets: 0
    ipv4-fasttrack-bytes: 0
Have you read the manual?
https://wiki.mikrotik.com/wiki/Manual:Fast_Path
https://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack
Yes. :sunglasses:
CCR support
conditions are met
Does the position of the rule important ? (for me dummy=0, fasttrack=1)
/ip firewall filter> print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    chain=forward action=fasttrack-connection
      connection-state=established,related log=no log-prefix=""
 2    ;;; Accept all establish related connection
      chain=input action=accept connection-state=established,related log=no
      log-prefix=""
 3    ;;; Drop all invalid connection
      chain=input action=drop connection-state=invalid log=yes log-prefix=""
 4    ;;; Drop all invalid connection to forward
      chain=forward action=drop connection-state=invalid connection-type=""
 5    ;;; Accept all establish related connection to forward
      chain=forward action=accept connection-state=established,related
      connection-type="" log=no log-prefix=""
 6    ;;; VOIP
      chain=forward action=accept protocol=tcp src-address-list=Peoplefone
      in-interface=combo1 src-port=5060 log=no log-prefix=""
 7    chain=forward action=accept protocol=udp src-address-list=Peoplefone
 8    chain=forward action=accept protocol=udp src-address-list=Peoplefone
      in-interface=combo1 src-port=8000-30000 log=no log-prefix=""
 9    chain=forward action=drop protocol=tcp in-interface=combo1 src-port=5060
      dst-port="" log=yes log-prefix=""
10    chain=forward action=drop protocol=udp in-interface=combo1 src-port=5060
11    chain=forward action=drop protocol=udp in-interface=combo1
      src-port=8000-30000 dst-port="" log=yes log-prefix=""
Is it possible that sniffer, torch, MAC telnet, IP scan or traffic generator is running?
No I checked it as mentionned in the manual.
But the log is set for drop rules
I had a glance at the forum and noted that many people have problem with fasttrack.
Shall I understand that this function is not yet operational ?
Did you tried to move your rule #5, to above the rule #2 for testing?
No, you should not. Fasttrack and FastPath work fine, and they are awesome. Most people complaining about fasttrack simply do not understand what it is, and what its limitations are (and then, for instance, complain that mangle or queues are not working with fasttracked traffic- whereas they do not for a reason, and that is fully documented). This does not seem to be your case, however.
I suggest you generating a supout.rif and emailing it to support@ asking for a help. I believe this should be something simple. Just not immediately obvious, and not something that experienced forum members ever faced themselves.
No because the forward chain is always empty
I am new to Mikrotik but will try and answer. Experts welcome to correct me if I am wrong.
My thinking is your forward chain will always be empty because you only allow related & Establsihed, you need a rule to allow “new” from LAN/INTERNAL
This is what I would suggest
  1. Move Rule 5 to Rule 2.
  2. Add rule to accept “new” connections only from LAN/INTERNAL in forward chain
