Why is 5.21 mising from development site?
I need download it ![]()
It may have been dangerous. Have you tried 6.0rc2 that is on there ? I think it works… except if some Ethernet drivers are not in it for x86 platform.
I need 5.21 due NV2 Wireless fix. I do not know whether this fix is included in 6.0RC2?
I hope that MT support read forum and give us an explanation?
Try this one http://www.sendspace.com/file/6lqbn9 Package Built Oct/10/2012 12:19:33 if something breaks - the person who installed it will take responsibility because this is a development test version which has not been released. I’ve tested it only on RB450G.
btw when 5.21 released? because I never see. I need upgrade from 5.20 because my RB1200 if I Click reboot in winbox, my RB1200 can’t work ![]()
no download all packages torrent http://www.mikrotik.com/download/routeros-ALL-5.21.torrent
fake files http://download.mikrotik.com/all_packages-mipsbe-5.21.zip
-//- http://download.mikrotik.com/routeros-mipsbe-5.21.npk
FAKE all packages RouterOS 5.21 download is link mikrotik.com
Why doing to us?
lol dont worry man its not a problem that those empty files (fake as you put it) exist on the server and we can hit their URLs by manually requesting it
5.21 is not released
no one is forcing us download empty files
Monday normal work time someone will fix that stuff. And rebuild/release/put on development page in mikrotik.com account.
I’m looking forward to the new features and improvements that will be able to routerboard.
What is fake? Both addresses are official mikrotik download sites!
We removed the files when v5.21 was released on official download page
Hi Guys,
this is my first post and its due to lack of info from google. I’ve had a number of issues with the new routerOS 5.21. We use the RB750GL to bond pppoe connections using the mlppp functionality of the mikrotik. I’m currently using OS firmware v 5.19 because the traditional scripting I do for them fails horribly on 5.21. Is any one else having issues creating a pppoe interface on the RB750GL?
Everytime I use a command like:
/interface pppoe-client add user="insert random pppoe username here"password=“random password” add-default-route=yes allow=pap dial-on-demand=no max-mru=1480 max-mtu=1480 mrru=1480 use-peer-dns=yes disabled=no name=pppoe-out1 interface=eth1-mdm1,eth2-mdm2
I get:
bad command name pppoe-client (line 1 column 12)
Even when trying to add the interface manually via winbox the options simply are not there.
I’ve checked the change logs and for some reason can find nothing on this. Anyone else having similar issues?
Thanks in Advance,
James
TIP: do not post in other topics, make your own. It will be easier to see your post by others
You are missing some RouterOS packages. Make sure you upload this file to your router: http://download.mikrotik.com/routeros-mipsbe-5.21.npk then reboot it.
