Why is a l2tp rename in server side?
Hi everyone,
I have some l2tp vpn connected between a server and remotes stations, his names are: VPNABC, VPNDEF, etc.
Sometimes when l2tp is back after down , at server side (only) this vpn is rename by rather (his original name). Why this happens?
Best regards.
i think that’s a normal dynamic behavior since you didn’t put your l2tp clients as static.
for every dynamic interface links (such as pptp, pppoe etc) you will have that behavior.
hope this helps.
Thank you wiseroute for your time.
BTW, How Can I configure l2tp clients as static? (in order to l2tp client name don’t change).
Best regards.
hello
ups… wrong post.
— edit
you might want to read this first
https://wiki.mikrotik.com/wiki/Manual:Interface/L2TP
your requirements on the l2tp server profile section.
hope this helps.
