Why is CAP AC wifi speed always lower than half of spec?
Hi All
I bought few CAP AC this month.
And I tested again and again.
CAP AC wifi speed 99% never over 350Mbps, sometime getting worse.
Only once speed over 400Mbps. Why?
Test Environment.
Registration Table
Computer 2 Server WIFI Status
Speed always below 350Mbps
A Miracle speed, never show again
My CAPsMAN Configuration
/caps-man datapath
add bridge=bridge name=cap_datapath
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=main_security passphrase=123456789
/caps-man channel
add name=5G_80Mhz_ch106_Ceee frequency=5500 extension-channel=Ceee band=5ghz-onlyac control-channel-width=20mhz
/caps-man configuration
add channel=5G_80Mhz_ch106_Ceee datapath=cap_datapath \
    mode=ap name=5G_3F_left_config security=main_security ssid=Yu_CAP_5G
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=no signal-range=\
    -90..120 ssid-regexp=""
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac identity-regexp=\
    3F_Left_CAP master-configuration=5G_3F_left_config name-format=\
    prefix-identity name-prefix=5G
What specs?
350-400mbit is actually very good performance as for cAP ac, as for PHY rate of 866Mbps in general.
Yes, I just learned it.
WIFI is half duplex,
so CAP AC max speed is 866 / 2 = 433Mhz
No its simply a matter of being fooled by advertising and not understanding wifi.
For one way Transmission and wifi losses you are better off using 1/3 to approximate expectations in the real world.
Aka 866/3 = 288. If you do better great!
IPerf3 Single client performance with a Cambium E410 access point which uses the same chipset as MikroTIk cAP ac, i.e. IPQ4018.
Upload and download:
source: https://www.batna24.com/en/great-ap-test-part3-cnpilote410
Multi client performance is another story, where MikroTik is simply bad in my experience, unfortunately
One can calculate what the performance can be. Indeed it is possible to do better buffer management than the current RouterOS implementation.
The 400-500 Mbps is not about the half duplex nature of wifi, it is about the wifi overhead, which is very important at high interface rates.
Bi-directional will be less than half of the unidirectional numbers. This speed is for single client greenfield performance only.
http://forum.mikrotik.com/t/ac2-vs-ac3-wifi-not-over-200mb/148289/1
