Why is H323 "invalid"?
Trying to devise some QOS improvements for a deaf subscriber with a Sorenson
videophone.
Wanted to make some mangle rules trigger off the detection of an H323
connection. None of them trigger. Discovered that H323 helper in /ip
firewall service-ports is marked invalid (red). You can disable it, enable
it, or make the port something other than 1720, but nothing makes it valid.
H323 doesn’t appear in /ip services, and there’s no way to add anything
there.
The only time I’ve seen this sort of behavior is when the package for a
specific feature isn’t present. The old brown wiki talks about needing the
“telephony package” for H323, but that package doesn’t seem to exist anymore
and the new wiki still discusses H323, so it must have been folded into
something else.
How do I get this out of the invalid state?
