sioux
1
hi all
suppose that i have clear router configuration and pinging for example google.com from host which is behind router I get this:
Badanie google.com [72.14.207.99] z użyciem 32 bajtów danych:
Odpowiedź z 72.14.207.99: bajtów=32 czas=161ms TTL=242
Odpowiedź z 72.14.207.99: bajtów=32 czas=142ms TTL=242
and when I add this rule to firewall configuration
ip firewall filter add chan=forward dst-port=80 action=drop
I don’t recives echo-replays!?
why? what dst-port=80 has to icmp protocol??
when I add protocol=tcp to rule above everything is ok.
normis
2
you HAVE TO add protocol, or the port setting won’t take effect, and will block google altogether
sioux
3
so you are saying that my rule
add chain=forward dst-port=80 adtion=drop
is actually
add chan=forward action=drop
Anytime when you specify port destination/source protocol is required, otherwise rule does not work correctly.
alone
5
you need to add the protocol tcp or whatever you need
add chain forward protocol (TCP ) dst port (80) action=accept
