Why is there a "*" in front of the interface number
The following command logs the number of each of the interfaces and produces the output below:
:foreach k in=[/interface find] do={:log info $k}
Why is there a “*” in front of each number? It doesn’t appear to do any harm because this lists the names of the scripts:
:foreach k in=[/interface find] do={:log info [/interface get $k name]}
However, if you try this command you get an error “no such item”:
:log info [/interface get $1 name]
= for each interfae you find, put the “.id” on the log
= for each interfae you find, put the interface name with the id “.id” on the log
= log the name of interface named same as “$1” variable
(and on this case “name” and $1 are the same thing, like “how is named John?”, the name is on the question…)
you must add something in the $1 var like:
:global 1 "ether1"
*1 = database entry ID on the database interface list
array of interface ID (the right name is “.id”)
:put [/interface find]
for example, if you do on CLI:
:put [/interface get *1]
you get something like:
.id=*1;actual-mtu=1500;default-name=ether1; ...etc...
You can use “name” of the interface for retrieve something:
:log info [/interface get ether1 disabled]
Or you can use the “.id”:
:log info [/interface get *1 disabled]
5 post in 20 minutes :slight_smile:
You know you can use the Edit button.
Mikrotik does not write why they add a * in front of an ID, but here you see some info.
https://wiki.mikrotik.com/wiki/Manual:Scripting
id (internal ID) - hexadecimal value prefixed by ‘*’ sign. Each menu item has assigned unique number - internal ID;
So that you’ll never confuse internal ids with temporary ids generated by console print.
