Why isn't DHCP working on my VLAN?
I am trying to set up ether2 as an access port on VLAN 10 with a DHCP server on that VLAN. I ran the following to create the VLAN and assign the access port:
set [find name=bridge] vlan-filtering=yes
/interface vlan
add interface=bridge name=vpn vlan-id=10
add name=vpn ranges=10.10.110.2-10.10.110.254
add address-pool=vpn interface=vpn lease-time=10m name=vpn
set [find bridge=bridge interface=ether2] frame-types=\
    admit-only-untagged-and-priority-tagged pvid=10
add address=10.10.110.1/24 interface=vpn network=10.10.110.0
add address=10.10.110.0/24 gateway=10.10.110.1
I was hoping this would allocate IPs in the 10.10.110.2-10.10.110.254 range on ether2, but I don’t get an IP allocated when connecting to this port.
I am running RouterOS 7.13 on a hAP ac². I’ve seen some guides showing adding ether2 as an untagged port on the bridge (under /interface bridge vlan), but it seems like this is already created dynamically by RouterOS.
I assume I’m missing something obvious. Here’s my full configuration as it is now (the majority of it is stock):
# 2023-12-27 20:33:27 by RouterOS 7.13
# software id = XXXX-XXXX
# model = RBD52G-5HacD2HnD
# serial number = XXXXXXXXXXXX
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf \
    ingress-filtering=no name=bridge port-cost-mode=short vlan-filtering=yes
/interface vlan
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add authentication-types=wpa2-psk mode=dynamic-keys name=XXX \
    supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="united kingdom" disabled=no distance=indoors frequency=2437 \
    installation=indoor mode=ap-bridge security-profile=XXX ssid=XXX \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
add disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wlanX mode=\
    station name=wlan3 ssid=XXX wds-default-bridge=bridge
add name=default-dhcp ranges=10.10.10.2-10.10.10.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf frame-types=\
    admit-only-untagged-and-priority-tagged ingress-filtering=no interface=\
    ether2 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 \
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2 \
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=wlan3 list=WAN
add address=10.10.10.1/24 interface=bridge network=10.10.10.0
/ip dhcp-client
add interface=wlan3
add address=10.10.10.0/24 comment=defconf gateway=10.10.10.1
set allow-remote-requests=yes
/ip dns static
add address=10.10.10.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
My current setup connects to another wireless AP using wlan3 (5GHz) and uses that as the WAN interface. Can anyone see what’s wrong with my configuration?
What you’re missing is to set bridge port to be a tagged member of VLAN 10. Which is needed because you created a vlan interface named vpn, anchored to bridge interface, with vlan-id set to 10. So bridge port has to be tagged member of that VLAN.
So something like this:
add bridge=bridge tagged=bridge vlan-ids=10
(1) Get rid of the ingress filtering=no on bridge setting… is there a reason you put that there?/
(2) As far as your configuration why bother with VPN vlan. There is no VPN attached?
Why not attache the subnet directly to the etherport2??
(3) You have no setting for bridge vlan
add bridge=bridge tagged=bridge untagged=ether2 vlan-ids=10
(4) The VLAN is not actually included in the LAN interface list either…
@mkx that fixed it, thanks!
@anav
I generated the list of commands I ran using export after setting it up in webfig. Not sure why it printed out ingress-filtering as no seems to be the default anyway.
I’m going to be setting up wireguard and a separate routing table to force all traffic on this VLAN down the tunnel, however I wanted to get the VLAN working first. I’m using a VLAN instead of just configuring a single port as I’m going to be adding other interfaces to it later (e.g. wireless).
Yep, that was the issue - thanks!
Good catch - I’ve added this which has fixed accessing the router from the VLAN.
Now that it’s working, I’ve noticed that I can communicate with devices not on VLAN 10 whilst on VLAN 10 - is this expected? Is it because the other devices aren’t on a VLAN?
What’s the best way to prevent this? Just put all other traffic in another VLAN?
Define “communicate”.
For example, I can ping and make HTTP requests to 10.10.10.11 from 10.10.110.254.
VLAN doesn’t separate at layer 3.
Use proper firewall rules to allow what can be done, drop all the rest from/to that VLAN.
As the rest already hinted at: your ROS device is a router which will happily pass packets between interfaces with IP address set (according to routing information it’s set up with).
If that doesn’t suit you, you can either use routing rules (pretty effective but not really flexible) or firewall rules (slower but much more flexible) to control which traffic can flow in which direction.
