Why mark routing?
Hi!
I need to know what is use of mark routing in ip-firewall-mangle on RouterOS?
what can be done with this option?
Thanks again! :smiley:
It’s used to implement policy routing whereby you can have the router use different routing tables based on anything you can match in a mangle rule. For example, you could have SMTP traffic use a default router different from that of other traffic. Refer to the manual for examples.
I mark the connection then mark routing to send all http traffic via a different modem.
