Why metal 2shpn interrupt signal when the top of the tower height ?
If, however, at the bottom of the tower A reference will continue without interruption
is there a solution ? Please
What are the results of a spectrum scan at the top height? There are too many factors to list that could cause this - what do you know about the site and any neighbouring sites? That may be a start.
I developed by the top of the building, up 10 meters
Signal inside my house and received from the mobile laptop directly between me and metal 2shpn almost 8 meters only
At the beginning of a signal metal 2shpn it appeared minutes later disappear completely problem here
I want to send the signal to my neighbors from me almost 30 meters
What is the solution
I hope to help me
Are you using an omni antenna?
The dispersion pattern of an omni looks a bit like a donut, so there’s a huge signal loss directly underneath and on top of it.
What is your TX power?
With TX power set too high, chances are good to completely saturize your client’s WiFi card. This can result in sudden connection drops or inability to connect at all.
-Chris
metal 2shpn with antena 6dbi‬‏
