So, I have 2 clients and both of them using RB433 (v 4.x), but i got report that they experience slow internet connection, for example: when their employees open a website, most of times, it just loading for moments and then connection time out. Same problem while sending email too (using SMTP).
But, when i disable the MikroTik internal proxy and the NAT to Proxy. Then everything just fine. I try to keep disable the rule for “NAT to Proxy” and then enable again the MikroTik Proxy, it getting slow again.
So i think this because MikroTik internal Proxy!
So do you have any sugestion for this problem? and have you fix it?
Thanks,
Yudi
Notes: below is example of ping result when the proxy is enabled (too many request timed out):
ping www.google.com -t
Pinging www.l.google.com [209.85.175.99] with 32 bytes of data:
Reply from 209.85.175.99: bytes=32 time=398ms TTL=53
Request timed out.
Request timed out.
Reply from 209.85.175.99: bytes=32 time=344ms TTL=53
Request timed out.
Reply from 209.85.175.99: bytes=32 time=570ms TTL=53
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 209.85.175.99: bytes=32 time=236ms TTL=54
Request timed out.
Reply from 209.85.175.99: bytes=32 time=475ms TTL=53
Reply from 209.85.175.99: bytes=32 time=269ms TTL=53
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 209.85.175.99: bytes=32 time=402ms TTL=53
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 209.85.175.99: bytes=32 time=431ms TTL=53
Reply from 209.85.175.99: bytes=32 time=242ms TTL=54
Reply from 209.85.175.99: bytes=32 time=387ms TTL=53
Reply from 209.85.175.99: bytes=32 time=270ms TTL=54
Request timed out.
Reply from 209.85.175.99: bytes=32 time=258ms TTL=54
Reply from 209.85.175.99: bytes=32 time=390ms TTL=53
Reply from 209.85.175.99: bytes=32 time=432ms TTL=53
Reply from 209.85.175.99: bytes=32 time=381ms TTL=53
Request timed out.
Reply from 209.85.175.99: bytes=32 time=205ms TTL=54
Reply from 209.85.175.99: bytes=32 time=303ms TTL=53
Request timed out.
Reply from 209.85.175.99: bytes=32 time=385ms TTL=53
Request timed out.
Request timed out.
Request timed out.
Reply from 209.85.175.99: bytes=32 time=348ms TTL=53
Request timed out.
Reply from 209.85.175.99: bytes=32 time=436ms TTL=53
Request timed out.
Reply from 209.85.175.99: bytes=32 time=412ms TTL=53
Reply from 209.85.175.99: bytes=32 time=184ms TTL=54
Reply from 209.85.175.99: bytes=32 time=401ms TTL=53
Request timed out.
Reply from 209.85.175.99: bytes=32 time=441ms TTL=53
Request timed out.
Reply from 209.85.175.99: bytes=32 time=406ms TTL=53
Reply from 209.85.175.99: bytes=32 time=247ms TTL=54
Request timed out.
Reply from 209.85.175.99: bytes=32 time=284ms TTL=53
Request timed out.
Reply from 209.85.175.99: bytes=32 time=389ms TTL=53
Request timed out.
Ping statistics for 209.85.175.99:
Packets: Sent = 60, Received = 28, Lost = 32 (53% loss),
Approximate round trip times in milli-seconds:
Minimum = 184ms, Maximum = 570ms, Average = 354ms
Control-C
^C
