Why my balance rr bonding in winbox cannot work?
Hi everyone!
I am a new bird to RouterOS and it is really fun to learn from you guys. I do have a problem that I cannot solve it by myself:
I want to set a bonding using QNAP NAS 451 which has two 1000m lan ports. But it does not work for now.
First, I connect QNAP 451 to port 21 and port 24 of Mikrotik CRS125-24G-1S-2HnD-IN and set QNAP 451 to a “balance rr” mode. QNAP 451 gets a new IP address which is accessable but wiredly very slow: normally with one lan I can get 100MB/s speed. But this way, I only get 24MB/s.
Secondly, I try to set bonding in RouterOS. I set the port 21 and port 24 to “Master port: none” instead of “ether2”. Then I set the bonding as in the attached graph. Now, everything is fine but I cannot access to the bonding and there is no data at all in the bonding.
Please help: is there a tutorial which tells us step by step how to setup a bonding with winbox? Thank you so much!
Best,
colamonkey
