Please help me.
0 R name=“wlan1” mtu=1500 mac-address=00:02:6F:35:94:A8 arp=enabled disable-running-check=no interface-type=Prism
prism-cardtype=200mW radio-name=“RedeVox” mode=ap-bridge ssid=“RedeVox” area=“” frequency-mode=manual-txpower
country=no_country_set antenna-gain=0 frequency=2452 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps basic-rates-b=1Mbps,2Mbps max-station-count=200 tx-power-mode=default
periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=15s on-fail-retry-time=100ms
compression=no allow-sharedkey=no
Logs::
system,info log rule added by admin in 4-May 18:26:1.20 from 192.168.254.103
wireless,info 00:0E:8B:FF:BD:33@wlan1: connected in 4-May 18:26:21.76 from 192.168.254.103
system,info log rule changed by admin in 4-May 18:26:30.54 from 192.168.254.103
system,info log rule changed by admin in 4-May 18:26:35.9 from 192.168.254.103
system,info log rule changed by admin in 4-May 18:26:38.89 from 192.168.254.103
system,info log rule changed by admin in 4-May 18:26:42.84 from 192.168.254.103
wireless,info 00:0E:8B:FF:BD:33@wlan1: disconnected, got disassoc: sending station leaving (8) in 4-May 18:27:12.14 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BD:33 attempts to connect in 4-May 18:27:12.15 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BD:33 in local ACL, accept in 4-May 18:27:12.15 from 192.168.254.103
wireless,info 00:0E:8B:FF:BD:33@wlan1: connected in 4-May 18:27:12.15 from 192.168.254.103
system,info log rule changed by admin in 4-May 18:27:36.78 from 192.168.254.103
system,info log rule changed by admin in 4-May 18:27:45.4 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 18:27:47.29 from 192.168.254.103
system,info log rule changed by admin in 4-May 18:27:47.82 from 192.168.254.103
system,info log rule changed by admin in 4-May 18:27:55.3 from 192.168.254.103
system,info log rule added by admin in 4-May 18:28:8.1 from 192.168.254.103
system,info log rule added by admin in 4-May 18:28:27.40 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 attempts to connect in 4-May 18:28:36.32 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 not in local ACL, by default accept in 4-May 18:28:36.32 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: connected in 4-May 18:28:36.32 from 192.168.254.103
system,info log rule added by admin in 4-May 18:28:40.64 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 18:28:58.43 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 18:28:58.43 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 18:28:58.45 from 192.168.254.103
system,info log rule added by admin in 4-May 18:29:1.67 from 192.168.254.103
system,info log rule added by admin in 4-May 18:29:10.59 from 192.168.254.103
system,info log rule added by admin in 4-May 18:29:21.31 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: disconnected, reassociating in 4-May 18:29:28.96 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A attempts to connect in 4-May 18:29:28.96 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A in local ACL, accept in 4-May 18:29:28.96 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: connected in 4-May 18:29:28.96 from 192.168.254.103
system,info log rule added by admin in 4-May 18:29:38.6 from 192.168.254.103
system,info log rule added by admin in 4-May 18:29:47.89 from 192.168.254.103
system,info,account user admin logged out from 192.168.254.200 via winbox in 4-May 18:30:17.73 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: disconnected, extensive data loss in 4-May 18:30:32.25 from 192.168.254.103
wireless,info wlan1: data from unknown device 00:0E:8B:FF:9F:9A, sent deauth in 4-May 18:30:36.73 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A attempts to connect in 4-May 18:30:37.46 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A in local ACL, accept in 4-May 18:30:37.46 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: connected in 4-May 18:30:37.46 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: disconnected, extensive data loss in 4-May 18:31:27.79 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A attempts to connect in 4-May 18:31:40.45 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A in local ACL, accept in 4-May 18:31:40.45 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: connected in 4-May 18:31:40.45 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: disconnected, reassociating in 4-May 18:32:12.92 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A attempts to connect in 4-May 18:32:12.92 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A in local ACL, accept in 4-May 18:32:12.92 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: connected in 4-May 18:32:12.92 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: disconnected, extensive data loss in 4-May 18:33:52.20 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A attempts to connect in 4-May 18:33:54.92 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A in local ACL, accept in 4-May 18:33:54.92 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: connected in 4-May 18:33:54.92 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: disconnected, reassociating in 4-May 18:35:32.92 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A attempts to connect in 4-May 18:35:32.92 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A in local ACL, accept in 4-May 18:35:32.92 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: connected in 4-May 18:35:32.92 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: disconnected, reassociating in 4-May 18:36:21.65 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A attempts to connect in 4-May 18:36:21.67 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A in local ACL, accept in 4-May 18:36:21.67 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: connected in 4-May 18:36:21.67 from 192.168.254.103
system,info,account user admin logged out from 192.168.254.200 via winbox in 4-May 18:37:51.43 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: disconnected, extensive data loss in 4-May 18:37:51.71 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 attempts to connect in 4-May 18:38:2.64 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 not in local ACL, by default accept in 4-May 18:38:2.64 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: connected in 4-May 18:38:2.65 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 18:38:32.85 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 18:39:40.64 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 18:39:40.65 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 18:39:40.65 from 192.168.254.103
wireless,debug wlan1: 00:12:F0:56:B4:EF attempts to connect in 4-May 18:45:41.89 from 192.168.254.103
wireless,debug wlan1: 00:12:F0:56:B4:EF not in local ACL, by default accept in 4-May 18:45:41.89 from 192.168.254.103
wireless,info 00:12:F0:56:B4:EF@wlan1: connected in 4-May 18:45:41.90 from 192.168.254.103
wireless,info 00:12:F0:56:B4:EF@wlan1: disconnected, got disassoc: unspecified (1) in 4-May 18:46:56.73 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: disconnected, extensive data loss in 4-May 18:49:52.68 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 attempts to connect in 4-May 18:50:0.21 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 not in local ACL, by default accept in 4-May 18:50:0.21 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: connected in 4-May 18:50:0.21 from 192.168.254.103
wireless,debug wlan1: 00:14:A4:36:1B:9D attempts to connect in 4-May 18:50:53.48 from 192.168.254.103
wireless,debug wlan1: 00:14:A4:36:1B:9D not in local ACL, by default accept in 4-May 18:50:53.48 from 192.168.254.103
wireless,info 00:14:A4:36:1B:9D@wlan1: connected in 4-May 18:50:53.50 from 192.168.254.103
wireless,info 00:14:A4:36:1B:9D@wlan1: disconnected, extensive data loss in 4-May 18:51:23.70 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: disconnected, got disassoc: unspecified (55888) in 4-May 18:59:58.67 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 19:0:46.64 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB attempts to connect in 4-May 19:1:6.78 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB not in local ACL, by default accept in 4-May 19:1:6.79 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: connected in 4-May 19:1:6.79 from 192.168.254.103
wireless,debug wlan1: 00:30:4F:30:A3:73 attempts to connect in 4-May 19:1:38.90 from 192.168.254.103
wireless,debug wlan1: 00:30:4F:30:A3:73 in local ACL, accept in 4-May 19:1:38.90 from 192.168.254.103
wireless,info 00:30:4F:30:A3:73@wlan1: connected in 4-May 19:1:38.90 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: disconnected, extensive data loss in 4-May 19:1:54.64 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 19:1:56.75 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 19:1:56.76 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 19:1:56.76 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 attempts to connect in 4-May 19:2:4.84 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 not in local ACL, by default accept in 4-May 19:2:4.85 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: connected in 4-May 19:2:4.85 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: disconnected, extensive data loss in 4-May 19:7:26.67 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 19:8:28.9 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 19:10:34.50 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 19:10:34.50 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 19:10:34.50 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: disconnected, got disassoc: unspecified (14587) in 4-May 19:14:56.7 from 192.168.254.103
wireless,info 00:30:4F:30:A3:73@wlan1: disconnected, extensive data loss in 4-May 19:34:6.56 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 19:46:29.15 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 19:47:30.67 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 19:47:30.67 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 19:47:30.67 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 19:56:5.65 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 19:57:8.85 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 19:57:8.85 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 19:57:8.85 from 192.168.254.103
wireless,debug wlan1: 00:13:46:7A:26:B1 attempts to connect in 4-May 20:15:2.90 from 192.168.254.103
wireless,info 00:13:46:7A:26:B1@wlan1: connected in 4-May 20:15:2.92 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:42:FF:B2 attempts to connect in 4-May 20:29:44.54 from 192.168.254.103
wireless,info 00:0E:2E:42:FF:B2@wlan1: connected in 4-May 20:29:44.54 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 20:29:54.79 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 20:30:59.40 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 20:30:59.40 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 20:30:59.40 from 192.168.254.103
wireless,debug wlan1: 00:40:F4:C4:72:FC attempts to connect in 4-May 20:32:45.90 from 192.168.254.103
wireless,debug wlan1: 00:40:F4:C4:72:FC in local ACL, accept in 4-May 20:32:45.90 from 192.168.254.103
wireless,info 00:40:F4:C4:72:FC@wlan1: connected in 4-May 20:32:45.90 from 192.168.254.103
wireless,info 00:40:F4:C4:72:FC@wlan1: disconnected, extensive data loss in 4-May 20:33:9.34 from 192.168.254.103
system,info,account user admin logged in from 192.168.254.200 via winbox in 4-May 20:36:16.29 from 192.168.254.103
wireless,debug wlan1: 00:02:78:49:53:14 attempts to connect in 4-May 20:37:21.40 from 192.168.254.103
wireless,debug wlan1: 00:02:78:49:53:14 in local ACL, accept in 4-May 20:37:21.42 from 192.168.254.103
wireless,info 00:02:78:49:53:14@wlan1: connected in 4-May 20:37:21.42 from 192.168.254.103
wireless,debug wlan1: 00:30:4F:32:6C:44 attempts to connect in 4-May 20:37:21.54 from 192.168.254.103
wireless,debug wlan1: 00:30:4F:32:6C:44 in local ACL, accept in 4-May 20:37:21.54 from 192.168.254.103
wireless,info 00:30:4F:32:6C:44@wlan1: connected in 4-May 20:37:21.54 from 192.168.254.103
wireless,debug wlan1: 00:0A:52:00:10:6F attempts to connect in 4-May 20:37:22.62 from 192.168.254.103
wireless,debug wlan1: 00:0A:52:00:10:6F not in local ACL, by default accept in 4-May 20:37:22.62 from 192.168.254.103
wireless,info 00:0A:52:00:10:6F@wlan1: connected in 4-May 20:37:22.62 from 192.168.254.103
wireless,debug wlan1: 00:13:46:7A:26:B1 attempts to connect in 4-May 20:37:26.31 from 192.168.254.103
wireless,debug wlan1: 00:13:46:7A:26:B1 not in local ACL, by default accept in 4-May 20:37:26.31 from 192.168.254.103
wireless,info 00:13:46:7A:26:B1@wlan1: connected in 4-May 20:37:26.32 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 attempts to connect in 4-May 20:37:28.78 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 in local ACL, accept in 4-May 20:37:28.78 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:D7@wlan1: connected in 4-May 20:37:28.78 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BD:33 attempts to connect in 4-May 20:37:29.18 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BD:33 in local ACL, accept in 4-May 20:37:29.18 from 192.168.254.103
wireless,info 00:0E:8B:FF:BD:33@wlan1: connected in 4-May 20:37:29.18 from 192.168.254.103
wireless,info wlan1: data from unknown device 00:06:F4:0A:D6:9F, sent deauth in 4-May 20:37:31.0 from 192.168.254.103
wireless,info wlan1: data from unknown device 00:06:F4:0A:D6:9F, sent deauth in 4-May 20:37:33.29 from 192.168.254.103
wireless,debug wlan1: 00:06:F4:0A:D6:9F attempts to connect in 4-May 20:37:34.84 from 192.168.254.103
wireless,debug wlan1: 00:06:F4:0A:D6:9F in local ACL, accept in 4-May 20:37:34.84 from 192.168.254.103
wireless,info 00:06:F4:0A:D6:9F@wlan1: connected in 4-May 20:37:34.84 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A attempts to connect in 4-May 20:37:41.37 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:9F:9A in local ACL, accept in 4-May 20:37:41.37 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: connected in 4-May 20:37:41.37 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:42:FF:B2 attempts to connect in 4-May 20:37:57.56 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:42:FF:B2 in local ACL, accept in 4-May 20:37:57.56 from 192.168.254.103
wireless,info 00:0E:2E:42:FF:B2@wlan1: connected in 4-May 20:37:57.56 from 192.168.254.103
wireless,debug wlan1: 00:40:F4:C4:72:FC attempts to connect in 4-May 20:38:6.46 from 192.168.254.103
wireless,debug wlan1: 00:40:F4:C4:72:FC in local ACL, accept in 4-May 20:38:6.46 from 192.168.254.103
wireless,info 00:40:F4:C4:72:FC@wlan1: connected in 4-May 20:38:6.46 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 20:38:6.89 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 20:38:6.89 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 20:38:6.89 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:37:38 attempts to connect in 4-May 20:40:1.67 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:37:38 not in local ACL, by default accept in 4-May 20:40:1.67 from 192.168.254.103
wireless,info 00:0E:8B:FF:37:38@wlan1: connected in 4-May 20:40:1.67 from 192.168.254.103
wireless,info 00:0E:8B:FF:9F:9A@wlan1: disconnected, got disassoc: sending station leaving (8) in 4-May 20:50:26.34 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 20:52:53.73 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 20:53:54.48 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 20:53:54.48 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 20:53:54.48 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 attempts to connect in 4-May 20:54:50.50 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 not in local ACL, by default accept in 4-May 20:54:50.51 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: connected in 4-May 20:54:50.51 from 192.168.254.103
wireless,info 00:02:78:49:53:14@wlan1: disconnected, got disassoc: reserved (0) in 4-May 20:58:54.95 from 192.168.254.103
wireless,debug wlan1: 00:02:78:49:53:14 attempts to connect in 4-May 20:58:57.20 from 192.168.254.103
wireless,debug wlan1: 00:02:78:49:53:14 in local ACL, accept in 4-May 20:58:57.20 from 192.168.254.103
wireless,info 00:02:78:49:53:14@wlan1: connected in 4-May 20:58:57.21 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 20:59:15.31 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 20:59:49.84 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 20:59:49.84 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 20:59:49.84 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 21:6:13.21 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB attempts to connect in 4-May 21:6:50.23 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB not in local ACL, by default accept in 4-May 21:6:50.23 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: connected in 4-May 21:6:50.23 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 21:6:53.39 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 21:6:53.39 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 21:6:53.39 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: disconnected, extensive data loss in 4-May 21:8:26.14 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: disconnected, extensive data loss in 4-May 21:8:33.31 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 attempts to connect in 4-May 21:8:54.85 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 not in local ACL, by default accept in 4-May 21:8:54.85 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: connected in 4-May 21:8:54.85 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB attempts to connect in 4-May 21:10:24.25 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB not in local ACL, by default accept in 4-May 21:10:24.26 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: connected in 4-May 21:10:24.26 from 192.168.254.103
system,info device changed by admin in 4-May 21:17:50.73 from 192.168.254.103
wireless,info wlan1: data from unknown device 00:0E:2E:42:FF:B2, sent deauth in 4-May 21:17:50.73 from 192.168.254.103
wireless,debug wlan1: 00:40:F4:C4:72:FC attempts to connect in 4-May 21:17:50.92 from 192.168.254.103
wireless,debug wlan1: 00:40:F4:C4:72:FC in local ACL, accept in 4-May 21:17:50.93 from 192.168.254.103
wireless,info 00:40:F4:C4:72:FC@wlan1: connected in 4-May 21:17:50.93 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 attempts to connect in 4-May 21:17:51.53 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 not in local ACL, by default accept in 4-May 21:17:51.53 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: connected in 4-May 21:17:51.54 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:42:FF:B2 attempts to connect in 4-May 21:17:51.64 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:42:FF:B2 in local ACL, accept in 4-May 21:17:51.64 from 192.168.254.103
wireless,info 00:0E:2E:42:FF:B2@wlan1: connected in 4-May 21:17:51.64 from 192.168.254.103
wireless,debug wlan1: 00:13:46:7A:26:B1 attempts to connect in 4-May 21:17:52.17 from 192.168.254.103
wireless,debug wlan1: 00:13:46:7A:26:B1 not in local ACL, by default accept in 4-May 21:17:52.18 from 192.168.254.103
wireless,info 00:13:46:7A:26:B1@wlan1: connected in 4-May 21:17:52.18 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BD:33 attempts to connect in 4-May 21:17:53.6 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BD:33 in local ACL, accept in 4-May 21:17:53.6 from 192.168.254.103
wireless,info 00:0E:8B:FF:BD:33@wlan1: connected in 4-May 21:17:53.6 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB attempts to connect in 4-May 21:17:53.98 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB not in local ACL, by default accept in 4-May 21:17:53.98 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: connected in 4-May 21:17:53.98 from 192.168.254.103
wireless,debug wlan1: 00:02:78:49:53:14 attempts to connect in 4-May 21:17:54.59 from 192.168.254.103
wireless,debug wlan1: 00:02:78:49:53:14 in local ACL, accept in 4-May 21:17:54.59 from 192.168.254.103
wireless,info 00:02:78:49:53:14@wlan1: connected in 4-May 21:17:54.59 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 21:17:54.70 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 21:17:54.70 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 21:17:54.70 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:37:38 attempts to connect in 4-May 21:17:56.4 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:37:38 not in local ACL, by default accept in 4-May 21:17:56.4 from 192.168.254.103
wireless,info 00:0E:8B:FF:37:38@wlan1: connected in 4-May 21:17:56.4 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 attempts to connect in 4-May 21:17:56.4 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 in local ACL, accept in 4-May 21:17:56.4 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:D7@wlan1: connected in 4-May 21:17:56.4 from 192.168.254.103
wireless,debug wlan1: 00:0A:52:00:10:6F attempts to connect in 4-May 21:17:58.0 from 192.168.254.103
wireless,debug wlan1: 00:0A:52:00:10:6F not in local ACL, by default accept in 4-May 21:17:58.0 from 192.168.254.103
wireless,info 00:0A:52:00:10:6F@wlan1: connected in 4-May 21:17:58.0 from 192.168.254.103
system,info device changed by admin in 4-May 21:18:0.57 from 192.168.254.103
wireless,info wlan1: data from unknown device 00:0E:2E:42:FF:B2, sent deauth in 4-May 21:18:0.57 from 192.168.254.103
wireless,debug wlan1: 00:40:F4:C4:72:FC attempts to connect in 4-May 21:18:0.78 from 192.168.254.103
wireless,debug wlan1: 00:40:F4:C4:72:FC in local ACL, accept in 4-May 21:18:0.78 from 192.168.254.103
wireless,info 00:40:F4:C4:72:FC@wlan1: connected in 4-May 21:18:0.78 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:42:FF:B2 attempts to connect in 4-May 21:18:1.59 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:42:FF:B2 in local ACL, accept in 4-May 21:18:1.59 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 attempts to connect in 4-May 21:18:1.59 from 192.168.254.103
wireless,debug wlan1: 00:0E:2E:43:04:E3 not in local ACL, by default accept in 4-May 21:18:1.59 from 192.168.254.103
wireless,info 00:0E:2E:42:FF:B2@wlan1: connected in 4-May 21:18:1.59 from 192.168.254.103
wireless,info 00:0E:2E:43:04:E3@wlan1: connected in 4-May 21:18:1.59 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BD:33 attempts to connect in 4-May 21:18:3.12 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BD:33 in local ACL, accept in 4-May 21:18:3.12 from 192.168.254.103
wireless,info 00:0E:8B:FF:BD:33@wlan1: connected in 4-May 21:18:3.12 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB attempts to connect in 4-May 21:18:3.73 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB not in local ACL, by default accept in 4-May 21:18:3.73 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: connected in 4-May 21:18:3.75 from 192.168.254.103
wireless,debug wlan1: 00:13:46:7A:26:B1 attempts to connect in 4-May 21:18:4.50 from 192.168.254.103
wireless,debug wlan1: 00:13:46:7A:26:B1 not in local ACL, by default accept in 4-May 21:18:4.50 from 192.168.254.103
wireless,info 00:13:46:7A:26:B1@wlan1: connected in 4-May 21:18:4.50 from 192.168.254.103
wireless,debug wlan1: 00:02:78:49:53:14 attempts to connect in 4-May 21:18:4.60 from 192.168.254.103
wireless,debug wlan1: 00:02:78:49:53:14 in local ACL, accept in 4-May 21:18:4.60 from 192.168.254.103
wireless,info 00:02:78:49:53:14@wlan1: connected in 4-May 21:18:4.60 from 192.168.254.103
wireless,debug wlan1: 00:06:F4:0A:D6:9F attempts to connect in 4-May 21:18:4.89 from 192.168.254.103
wireless,debug wlan1: 00:06:F4:0A:D6:9F in local ACL, accept in 4-May 21:18:4.90 from 192.168.254.103
wireless,info 00:06:F4:0A:D6:9F@wlan1: connected in 4-May 21:18:4.90 from 192.168.254.103
wireless,debug wlan1: 00:0A:52:00:10:6F attempts to connect in 4-May 21:18:5.65 from 192.168.254.103
wireless,debug wlan1: 00:0A:52:00:10:6F not in local ACL, by default accept in 4-May 21:18:5.65 from 192.168.254.103
wireless,info 00:0A:52:00:10:6F@wlan1: connected in 4-May 21:18:5.67 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:37:38 attempts to connect in 4-May 21:18:5.79 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:37:38 not in local ACL, by default accept in 4-May 21:18:5.79 from 192.168.254.103
wireless,info 00:0E:8B:FF:37:38@wlan1: connected in 4-May 21:18:5.79 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 attempts to connect in 4-May 21:18:5.87 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 in local ACL, accept in 4-May 21:18:5.89 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:D7@wlan1: connected in 4-May 21:18:5.89 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 21:18:13.56 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 21:18:13.56 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 21:18:13.57 from 192.168.254.103
system,info,account user admin logged out from 192.168.254.200 via winbox in 4-May 21:18:46.93 from 192.168.254.103
system,info,account user admin logged in from 192.168.254.200 via winbox in 4-May 21:19:19.64 from 192.168.254.103
system,info,account user admin logged out from 192.168.254.200 via winbox in 4-May 21:19:47.37 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: disconnected, reassociating in 4-May 21:20:14.42 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB attempts to connect in 4-May 21:20:14.42 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:B9:CB not in local ACL, by default accept in 4-May 21:20:14.42 from 192.168.254.103
wireless,info 00:0E:8B:FF:B9:CB@wlan1: connected in 4-May 21:20:14.42 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:D7@wlan1: disconnected, got disassoc: sending station leaving (8) in 4-May 21:21:15.46 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 attempts to connect in 4-May 21:21:17.59 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 in local ACL, accept in 4-May 21:21:17.59 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:D7@wlan1: connected in 4-May 21:21:17.60 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:D7@wlan1: disconnected, got disassoc: sending station leaving (8) in 4-May 21:22:20.79 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 attempts to connect in 4-May 21:22:22.89 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 in local ACL, accept in 4-May 21:22:22.89 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:D7@wlan1: connected in 4-May 21:22:22.89 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:D7@wlan1: disconnected, reassociating in 4-May 21:25:36.17 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 attempts to connect in 4-May 21:25:36.17 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:D7 in local ACL, accept in 4-May 21:25:36.17 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:D7@wlan1: connected in 4-May 21:25:36.18 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: disconnected, extensive data loss in 4-May 21:26:51.21 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD attempts to connect in 4-May 21:27:22.50 from 192.168.254.103
wireless,debug wlan1: 00:0E:8B:FF:BB:DD in local ACL, accept in 4-May 21:27:22.50 from 192.168.254.103
wireless,info 00:0E:8B:FF:BB:DD@wlan1: connected in 4-May 21:27:22.50 from 192.168.254.103
wireless,info wlan1: data from unknown device 00:30:4F:32:6C:44, sent deauth (9 events suppressed, 2 deauths suppressed) in 4-May 21:27:22.67 from 192.168.254.103
