Why no Internet access?
Hello, Im sorry but Im a bit of a Mikrotik noob but I set up a static IP on my SFP port to my ISP and was able to ping google.com but on my 192.168.1.0/24 LAN I have no internet access. My DHCP server is handing out IP’s but I can’t access the internet. can’t ping google or even a direct IP like 8.8.8.8. I know ive done something wrong I just don’t know what it is. And sorry if my formating is wrong Ive never posted to this forum before. Any Help would be greatly appreciated! Heres the config:
# 2024-09-27 18:12:04 by RouterOS 7.15.2
# software id = **ELIDED**
# model = L009UiGS
# serial number = **ELIDED**
add admin-mac=**ELIDED** auto-mac=no comment=defconf name=bridge \
    vlan-filtering=yes
/interface vlan
add interface=bridge name="Site 1 VLAN" vlan-id=11
add interface=bridge name="WAN VLAN" vlan-id=911
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=Site1VLAN ranges=192.168.1.200-192.168.1.253
add name=dhcp_pool2 ranges=192.168.1.200-192.168.1.253
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=dhcp_pool2 interface="Site 1 VLAN" name=dhcp1
/port
set 0 name=serial0
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether2 pvid=911
add bridge=bridge comment=defconf interface=ether3 pvid=11
add bridge=bridge comment=defconf interface=ether4 pvid=11
add bridge=bridge comment=defconf interface=ether5 pvid=11
add bridge=bridge comment=defconf interface=ether6 pvid=11
add bridge=bridge comment=defconf interface=ether7 pvid=11
add bridge=bridge comment=defconf interface=ether8 pvid=11
/interface bridge vlan
add bridge=bridge tagged=ether2,bridge untagged=\
    ether3,ether4,ether5,ether6,ether7,ether8 vlan-ids=11
add bridge=bridge tagged=bridge untagged=ether2 vlan-ids=911
add interface="Site 1 VLAN" list=LAN
add interface="WAN VLAN" list=LAN
    192.168.88.0
add address=192.168.1.254/24 interface="Site 1 VLAN" network=192.168.1.0
add address=172.16.254.1/28 interface="WAN VLAN" network=172.16.254.0
add address=**ELIDED**/30 interface=sfp1 network=**ELIDED**
/ip dhcp-client
add address=192.168.1.0/24 dns-server=192.168.1.254 gateway=192.168.1.254
    192.168.88.1
set allow-remote-requests=yes servers=**ELIDED**
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add disabled=no dst-address=192.168.2.0/24 gateway=172.16.254.2 \
    routing-table=main suppress-hw-offload=no
add disabled=no dst-address=192.168.3.0/24 gateway=172.16.254.3 \
add disabled=no dst-address=192.168.4.0/24 gateway=172.16.254.4 \
add disabled=no dst-address=0.0.0.0/0 gateway=**ELIDED** routing-table=\
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=America/Chicago
/system identity
set name="Covington Site 1"
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
The SFP port should be part of the WAN interface list in order for the NAT masquerade rule to work properly:
add interface=sfp1 list=WAN
Yep, I KNEW it would be something simple and stupid. Thanks!
