Why (no such command or directory( address)
[admin@MikroTik] > /interface ethernet print
[admin@MikroTik] > /interface ethernet set 0 name lan
[admin@MikroTik] > /ip address add address=192.168.1.1/24 interface=lan
[admin@MikroTik] > /ip dhcp-client add interface=wan use-peer-dns=yes disabled=no add-default-route=yes
[admin@MikroTik] > /ping 80.80.174.131
80.80.174.131 64 byte ping: ttl=47 time=192 ms
80.80.174.131 64 byte ping: ttl=47 time=183 ms
80.80.174.131 64 byte ping: ttl=47 time=188 ms
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 183/187.6/192 ms
[admin@MikroTik] > /ip dhcp-server network address=192.168.1.0/24 \ dns-server=192.168.1.1 gateway=192.168.1.1 disabled=no
But the last command display this message:
no such command or directory (address)
Why?
I just want to share internet without restrictions…
Type this;
/ip dhcp-server network add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
The router accept your command but until now I don’t have internet connectin from PC client.
in pc client I have write this IP:
192.168.1.22 (IP)
255.255.255.0 (SM)
1921168.1.1 (GW)
192.168.1.1 (dns)
please tell me wha to do…
You may need a masquerade rule if you only have a single IP address from your ISP.
chain=srcnat action=masquerade src-address=192.168.1.0/24 out-interface=your_pppoe
