Why I can see voltage imput with RB 600?
MT 3.0RC13
admin@MikroTik] > system health print
fan-mode: auto
use-fan: main
active-fan: auxiliary
[admin@MikroTik] >
Tks,
Ademir Peixoto
MT 3.0RC13
fan-mode: auto
use-fan: main
[admin@MikroTik] >
Tks,
Ademir Peixoto
I have the same problem…
Carlo
Has anybody a way to see the voltages on /system/health ?
Carlo
When using RB333:
[admin@TER Artistas1] > system health print
fan-mode: auto
use-fan: main
voltage: 13.4
When using RB600:
[admin@TER Fonte] > system health print
fan-mode: auto
use-fan: main
I do not understand why RB600 does not show power voltage…
I consider very important having voltage information.
Is it a bug or a feature not implemented in RB600? How do I have power voltage in RB600?
Who says that rb600 has a voltage monitor. AFAIK the only one is rb333.
regards
Well, I miss the voltage monitor in RB600 then !!! It is very usefull !!!
Is the RB600 voltage monitor a hardware or software related matter?
If software… will it ever be working?
Its a major help when you have sites that are 110km away from you… and the power company does not know when they will be onsite for repairs..
It is hardware feature with software support. If there don’t have necessary hardware you can’t do anything with software :))
