WHy ROS 5.26 x86 write alot to disk
Here’s the report:
uptime: 13h35m56s
version: 5.26
free-memory: 1894076KiB
total-memory: 1943372KiB
cpu: AMD
cpu-count: 2
cpu-frequency: 2793MHz
cpu-load: 0%
free-hdd-space: 3729784KiB
total-hdd-space: 3850320KiB
write-sect-since-reboot: 548408
write-sect-total: 548408
architecture-name: x86
board-name: x86
platform: MikroTik
I’ve disabled dhcp write to disk, graphing store every 24 hours, web proxy disabled, dns server 10240kb. Why write sector written still so high? It count up about 30 sectors every 2-3 seconds. Anything wrong?
edit: Written sectors reached 1 million in 23 hours 54 minutes. I tried to reset configuration and do nothing, sector written remain the same for more than an hour. But when I reconfig hotspot, dhcp client for wan, dhcp server for hotspot interface, radius + user manager, no connected client at all, the written sectors start rising again about 30 sectors every 2-3 seconds.
So, my question is: IF I continue to use CF, when some clients connected, running, how long my CF can stand? Thanks.
Thanks for your post.
I experienced a high CPU load when users logged in on the hotspot. While googling on this I came across your post.
I compared the disk writes with my other ROS 5.24 server and cam to the same conclusion.
Server 1: ROS 5.24 / 119 days online / 8 mill. sector writes
Server 2: ROS 5.26 / 2 days online / 6 mill. sector writes
Thanks, M
Well here’s the latest update:
uptime: 3w2d14h34m56s
version: 5.26
free-memory: 1888372KiB
cpu: AMD
cpu-count: 2
cpu-frequency: 2794MHz
cpu-load: 0%
free-hdd-space: 3726292KiB
write-sect-since-reboot: 23783512
write-sect-total: 23783512
board-name: x86
platform: MikroTik
Overall calculation: 1 day = 1 millions write. 365 days = throw off NAND Flash lol
About your high CPU load, Hotspot and Wireless requires alot of CPU resources. Combine both in a system resulting high CPU load.
That’s why I prefer to use x86 Mikrotik OS as Hotspot Server, output to managed switch, then use standalone wireless access points.
