Why simple queue not works on 3.x?
I use transparents bridges with eoip-tunnels. On ROS 2.9x they works OK with simple queues. On 3.x all queues not works. Is this a bug?
Regards,
Ademir Peixoto
maybe you use default-small as a queue type and you have just target address set?
It´s the same configutation. Some times I install all in 2.9.51 (works ok…) then I upgrade the ROS to 3.14 and stop works.
Ragards,
Ademir Peixoto
because ROS 3.14 have different behaviour compared to 2.9.51
Try to uninstall nex (enx) package, if you have that.
xen :smiley:
thanks chupaka. Please can you read my post load balancing problem, i need helppppppp.
