Can anybody spot a problem in configuration of wireless interface which prevents clients and AP from connecting at 2x2 MIMO?
My AP is RB951G, clients are typical 1-3 years old smart phones and tabs. Here’s running config:
1 R name="wifi-42" mtu=1500 l2mtu=1600 mac-address=E4:8D:8C:49:EE:4F arp=enabled disable-running-check=no interface-type=Atheros AR9300
radio-name="E48D8C49EE4F" mode=ap-bridge ssid="<redacted>" area="" frequency-mode=regulatory-domain country=brazil installation=indoor
antenna-gain=4 frequency=2472 band=2ghz-g/n channel-width=20mhz secondary-channel="" scan-list=default wireless-protocol=802.11
rate-set=configured supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=12Mbps,18Mbps max-station-count=50 distance=indoors tx-power-mode=default
noise-floor-threshold=default nv2-noise-floor-offset=default vlan-mode=use-tag vlan-id=42 wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 wmm-support=disabled hide-ssid=no
security-profile=mkxNet wps-mode=disabled station-roaming=enabled disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=short
compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ampdu-priorities=0,1 guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,
mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 tx-chains=0,1 rx-chains=0,1 amsdu-limit=8192 amsdu-threshold=8192
tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key=""
nv2-mode=dynamic-downlink nv2-downlink-ratio=50 nv2-sync-secret="" hw-retries=7 frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=rts-cts hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced
multicast-helper=default multicast-buffering=enabled keepalive-frames=enabled skip-dfs-channels=disabled
And statistics for the client while running speedtest (DL part):
1 interface=wifi-42 mac-address=E0:AA:96:F0:C1:22 ap=no wds=no bridge=no rx-rate="72.2Mbps-20MHz/1S/SGI" tx-rate="72.2Mbps-20MHz/1S/SGI"
packets=40177,26373 bytes=46275354,10338242 frames=40177,26375 frame-bytes=46355734,10180240 hw-frames=42957,26986
hw-frame-bytes=50014144,11253016 tx-frames-timed-out=0 uptime=6m24s last-activity=0ms signal-strength=-51dBm@12Mbps signal-to-noise=56dB
signal-strength-ch0=-56dBm signal-strength-ch1=-53dBm
strength-at-rates=-47dBm@1Mbps 4m54s550ms,-51dBm@12Mbps 70ms,-55dBm@HT20-4 6m22s470ms,-55dBm@HT20-5 6m22s170ms,-54dBm@HT20-6 6m21s890ms,-
53dBm@HT20-7 0ms
tx-ccq=97% p-throughput=64108 last-ip=192.168.42.144 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm
group-encryption=aes-ccm management-protection=no wmm-enabled=yes tx-rate-set="OFDM:12-54 BW:1x SGI:1x HT:0-7"
As to other traffic in the area: AP is not exactly isolated from the rest of wireless networks, but it’s not too bad:
CHANNEL USE BW NET-COUNT NOISE-FLOOR STA-COUNT
2442/20/gn/P(26dBm) 0.1% 0bps 0 -106 0
2412/20/gn/P(26dBm) 1.2% 11.5kbps 1 -105 1
2417/20/gn/P(26dBm) 0% 0bps 0 -105 0
2422/20/gn/P(26dBm) 0% 0bps 0 -106 0
2427/20/gn/P(26dBm) 0% 0bps 0 -107 0
2432/20/gn/P(26dBm) 0.4% 41.8kbps 2 -106 2
2437/20/gn/P(26dBm) 0% 0bps 3 -106 5
2447/20/gn/P(26dBm) 0.7% 0bps 0 -106 1
2452/20/gn/P(26dBm) 57.6% 31.0Mbps 1 -106 6
2457/20/gn/P(26dBm) 15% 0bps 0 -106 0
2462/20/gn/P(26dBm) 3.8% 0bps 2 -107 2
2467/20/gn/P(26dBm) 0% 0bps 0 -107 0
2472/20/gn/P(26dBm) 0% 0bps 0 -108 0
