why is it again necessary to be dug up in instructions, climb on the searching system that though that worked???
why from a box does work NOTHING ???
did conduct a test speed internet on wi-fi, mikrotik beginning to the swing 50 return 40, zuxel beginning to the swing 69, return 90, why so??? why by default nothing does work ???
to configure the device without technical support, the set of functions I do not see real, why do I have to configure ??? I gave the money for the device, not a headache
I without your advice a great deal, what do I device to buy. I can easily set up eoip, capsman, but I don’t understand why simple functions do not work in a configuration by default. router any other brand requires minimal settings, and Yes, it has Russian menu, to configure Mikrotik I need a dictionary to dig and it is not clear what set show it will earn, a lot of illogical and unnecessary settings, developers take up zuxel router, start it by default and you can compare your brick with the default settings
I’m sorry, I will not feel bad for you. If you didn’t research the product, then it’s your own fault.
The hardware is good, and fast. Even the cheap units are fast.
MikroTik can not predict what you need configured, so it is a very basic configuration. Even then, it will pass 200~500mbps. If it is slow, then it is because you did something wrong.
Coming here and complaining about how bad it is will not get anyone to help you.
I think the lower cost units (US $59) and the availability on Amazon and other sites is driving more “low end” users to the products.
I do wish that the marketing would state “Not for beginners”
Yup, I have no problem people being “beginners” or asking questions as long as they are polite, research their topic, and search for other posts before creating new threads.
Exactly. So far there are just few from all those hundreds thousands that have enough time to spend it abusing here. I believe we can handle them easily. I think that such people should have their voices here too, otherwise the picture about the mikrotik community could not be complete. Let everyone makes his own opinion (also about the product, but mainly about the authors) reading the angry nonsenses from those people.
Do a system reset. Leave default config. It works out of the box.
You don’t have to configure it, if you are not sure what each setting does. Just leave it at defaults and it will work. If your speed is lower than some other device, most likely it means you are comparing it to a different kind of device (bigger antennas, etc).
