Hi I’m having problems on 5.8 on wireless. The ping goes high to 1500 ms and goes back down to 1 ms works for 10 minutes and when the traffic goes to 13 Mbits the ping goes high and the traffic goes down to 4 Mbits . I have changed the wireless card and freq.. but still remain the same.
Here is the result of ping..
Reply from 10.84.64.4: bytes=32 time=10ms TTL=63
Reply from 10.84.64.4: bytes=32 time=12ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1ms TTL=63
Reply from 10.84.64.4: bytes=32 time=4ms TTL=63
Reply from 10.84.64.4: bytes=32 time=3ms TTL=63
Reply from 10.84.64.4: bytes=32 time=2ms TTL=63
Reply from 10.84.64.4: bytes=32 time<1ms TTL=63
Reply from 10.84.64.4: bytes=32 time=25ms TTL=63
Reply from 10.84.64.4: bytes=32 time=7ms TTL=63
Reply from 10.84.64.4: bytes=32 time=8ms TTL=63
Reply from 10.84.64.4: bytes=32 time=16ms TTL=63
Reply from 10.84.64.4: bytes=32 time=5ms TTL=63
Reply from 10.84.64.4: bytes=32 time=6ms TTL=63
Reply from 10.84.64.4: bytes=32 time=24ms TTL=63
Reply from 10.84.64.4: bytes=32 time=36ms TTL=63
Reply from 10.84.64.4: bytes=32 time=84ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1003ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1545ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1916ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1721ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1233ms TTL=63
Reply from 10.84.64.4: bytes=32 time=693ms TTL=63
Reply from 10.84.64.4: bytes=32 time=535ms TTL=63
Reply from 10.84.64.4: bytes=32 time=674ms TTL=63
Reply from 10.84.64.4: bytes=32 time=786ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1415ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1191ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1451ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1293ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1644ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1277ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1227ms TTL=63
Reply from 10.84.64.4: bytes=32 time=924ms TTL=63
Reply from 10.84.64.4: bytes=32 time=777ms TTL=63
Reply from 10.84.64.4: bytes=32 time=821ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1100ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1183ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1213ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1232ms TTL=63
Reply from 10.84.64.4: bytes=32 time=587ms TTL=63
Reply from 10.84.64.4: bytes=32 time=999ms TTL=63
Reply from 10.84.64.4: bytes=32 time=647ms TTL=63
Reply from 10.84.64.4: bytes=32 time=790ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1334ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1307ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1389ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1430ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1679ms TTL=63
Reply from 10.84.64.4: bytes=32 time=840ms TTL=63
Reply from 10.84.64.4: bytes=32 time=378ms TTL=63
Reply from 10.84.64.4: bytes=32 time=208ms TTL=63
Reply from 10.84.64.4: bytes=32 time=439ms TTL=63
Reply from 10.84.64.4: bytes=32 time=457ms TTL=63
Reply from 10.84.64.4: bytes=32 time=542ms TTL=63
Reply from 10.84.64.4: bytes=32 time=710ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1032ms TTL=63
Reply from 10.84.64.4: bytes=32 time=830ms TTL=63
Reply from 10.84.64.4: bytes=32 time=490ms TTL=63
Reply from 10.84.64.4: bytes=32 time=677ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1029ms TTL=63
Reply from 10.84.64.4: bytes=32 time=997ms TTL=63
Reply from 10.84.64.4: bytes=32 time=793ms TTL=63
Reply from 10.84.64.4: bytes=32 time=631ms TTL=63
Reply from 10.84.64.4: bytes=32 time=833ms TTL=63
Reply from 10.84.64.4: bytes=32 time=820ms TTL=63
Reply from 10.84.64.4: bytes=32 time=701ms TTL=63
Reply from 10.84.64.4: bytes=32 time=918ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1244ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1243ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1238ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1376ms TTL=63
Reply from 10.84.64.4: bytes=32 time=945ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1783ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1339ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1176ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1896ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1039ms TTL=63
Reply from 10.84.64.4: bytes=32 time=847ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1053ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1264ms TTL=63
Reply from 10.84.64.4: bytes=32 time=961ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1578ms TTL=63
Reply from 10.84.64.4: bytes=32 time=969ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1185ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1422ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1720ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1151ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1110ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1368ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1009ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1077ms TTL=63
Reply from 10.84.64.4: bytes=32 time=727ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1717ms TTL=63
Reply from 10.84.64.4: bytes=32 time=863ms TTL=63
Reply from 10.84.64.4: bytes=32 time=433ms TTL=63
Reply from 10.84.64.4: bytes=32 time=482ms TTL=63
Reply from 10.84.64.4: bytes=32 time=842ms TTL=63
Reply from 10.84.64.4: bytes=32 time=903ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1309ms TTL=63
Reply from 10.84.64.4: bytes=32 time=540ms TTL=63
Reply from 10.84.64.4: bytes=32 time=803ms TTL=63
Reply from 10.84.64.4: bytes=32 time=422ms TTL=63
Reply from 10.84.64.4: bytes=32 time=214ms TTL=63
Reply from 10.84.64.4: bytes=32 time=66ms TTL=63
Reply from 10.84.64.4: bytes=32 time=30ms TTL=63
Reply from 10.84.64.4: bytes=32 time=54ms TTL=63
Reply from 10.84.64.4: bytes=32 time=15ms TTL=63
Reply from 10.84.64.4: bytes=32 time=72ms TTL=63
Reply from 10.84.64.4: bytes=32 time=616ms TTL=63
Reply from 10.84.64.4: bytes=32 time=792ms TTL=63
Reply from 10.84.64.4: bytes=32 time=723ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1166ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1155ms TTL=63
Reply from 10.84.64.4: bytes=32 time=843ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1895ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1714ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1105ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1125ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1661ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1205ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1535ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1925ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1201ms TTL=63
Reply from 10.84.64.4: bytes=32 time=905ms TTL=63
Reply from 10.84.64.4: bytes=32 time=987ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1345ms TTL=63
Reply from 10.84.64.4: bytes=32 time=771ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1437ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1218ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1485ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1566ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1803ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1409ms TTL=63
Reply from 10.84.64.4: bytes=32 time=949ms TTL=63
Reply from 10.84.64.4: bytes=32 time=837ms TTL=63
Reply from 10.84.64.4: bytes=32 time=791ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1229ms TTL=63
Reply from 10.84.64.4: bytes=32 time=956ms TTL=63
Reply from 10.84.64.4: bytes=32 time=891ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1002ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1265ms TTL=63
Reply from 10.84.64.4: bytes=32 time=910ms TTL=63
Reply from 10.84.64.4: bytes=32 time=752ms TTL=63
Reply from 10.84.64.4: bytes=32 time=855ms TTL=63
Reply from 10.84.64.4: bytes=32 time=572ms TTL=63
Reply from 10.84.64.4: bytes=32 time=1162ms TTL=63
Reply from 10.84.64.4: bytes=32 time=796ms TTL=63
Reply from 10.84.64.4: bytes=32 time=884ms TTL=63
If someone can help me out , is really urgent.
thx selim ..
