Why the value is zero, is there a problem in proxy
I Use the cash, are naturally do not work this value “RAM Cashe used” ??? Why is Zero
Have you checked the Option “Cache On Disk” , If YES, Just uncheck and see the result.
This is because you are cache’ing to the hard drive not the ram.
you have about 2gb cached if i read that right.
If you had it cache to ram you would need at least 2gb of ram, it could be faster in theory. But every time you reboot the router it would clear the whole cache becuase that’s how ram works.
Whin I checked the Option “Cache On Disk” yes or No there is no change
"RAM Cashe used " Keep the value is zero
In fact I did not note that there are remarkable speed, how can I improve speed to the maximum extent possible
look at
helllo ???
I wouldn’t worry about it.
As long as there is a Cache on a disc. as in “cache used” is more then 0 its working and is as fast as your going to get it.
I installed mikrotik 3.16 on a flash card. It has only 64MB space which is not suitable for Disk cache. But there is Zerp value in “RAM cache used”. The server has 2GB RAM, but it shows 1830MB free memory. How can I increase RAM cache utilization?
