Why tool "Ping" in app "Mikrotik" on iOS not work properly?
Hello, there!
I spended a lot time for debug network problem with an host from my localnet. Testing it host via tool “Ping” in app “Mikrotik” (v.1.2.17 and v.1.2.18) on iOS and got always “Timeout”. And checked all level OSI. Then I testing all hosts my network from it tool, and got "Timeout". Only gateway pinged properly. Then I run “Winbox” (v.4.0beta33) on Windows 11 and use the same tool “Ping” and it ping problem host properly! And other host my net too! What’s it? How-it work? What I did not it?
Does WiFi allows interdevice connections or just traffic to the router?
WOW! Nice answer! WiFi clients are in a guest network. And it’s not access to localnet. But if I connect from cellular not ping too. I made bad config… Thanks!
