Why Wireless Lan not responding to PPPoE Scan?
Hi Guys
I’m trying here to scan Wireless Client side (Wlan1) for Rouge PPPoE Servers
Using PPPoE Scanner Utility with Mikrotik
But nothing discovered although I run a Rouge PPPoE server on some clients
PC’s
My setup is:
Wlan1----Bridge1-----ether1
The scanner working correctly on Bridge1 and discover the rouge servers
on clients PC’s
But with wlan1 no luck
I need your help urgently please
There is not much sense to use bridged interfaces, you should use the bridge itself. Why don’t you use it if it’s already working?
