Wi-Fi and Android Phone HighScreen Boost
Please help me.
Phone:
android 4.1.2 HighScreen Boost Rev. A (1Gb) Stock 2.9
Router:
mAP, RB951G 6.20 wireless-fp
Radio config: http://pastebin.com/kRw4uTib
high ping!
Stock and D-Link DIR300 nru b5/b6 - ok ping!
HighScreen Boost - cyanogenmod and Mikrotik - ok ping!
Stock and Mikrotik - high ping!
please paste full config, not just wireless. don’t use pastebin, paste here, using the “select syntax → RouterOS” dropdown
mAP 6.20
jan/02/1970 01:23:25 by RouterOS 6.20
add admin-mac=4C:5E:0C:6C:5B:86 auto-mac=no name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce
disabled=no distance=indoors l2mtu=1600 mode=ap-bridge ssid=
MikroTik-6C5B87
/ip neighbor discovery
set ether1-gateway discover=no
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
/system logging action
set 2 remember=yes
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=
bridge-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=
no interface=ether1-gateway
add address=192.168.88.0/24 comment="default configuration" dns-server=
192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=
ether1-gateway
add chain=forward comment="default configuration" connection-state=
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration"
connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway
/ip upnp
set allow-disable-external-interface=no
/snmp
set trap-community=public
/system leds
set 3 interface=ether1-gateway
/system routerboard settings
set cpu-frequency=400MHz
/tool mac-server
add interface=ether2
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
Other devices are working properly. On Androyd tablet - ok (Android 4.4)! Other phones on android - ok...
Only problem with the phone for stock firmware. With other manufacturers of routers operating normally. (DLink, TP-Link, ASUS)
With firmware cyanogenmod problem disappears!
Wiphy phy0
Band 1:
Capabilities: 0x20
HT20
Static SM Power Save
RX HT20 SGI
No RX STBC
Max AMSDU length: 3839 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 8191 bytes (exponent: 0x000)
Minimum RX AMPDU time spacing: No restriction (0x00)
HT RX MCS rate indexes supported: 0-7
HT TX MCS rate indexes are undefined
Frequencies:
  • 2412 MHz [1] (20.0 dBm)
  • 2417 MHz [2] (20.0 dBm)
  • 2422 MHz [3] (20.0 dBm)
  • 2427 MHz [4] (20.0 dBm)
  • 2432 MHz [5] (20.0 dBm)
  • 2437 MHz [6] (20.0 dBm)
  • 2442 MHz [7] (20.0 dBm)
  • 2447 MHz [8] (20.0 dBm)
  • 2452 MHz [9] (20.0 dBm)
  • 2457 MHz [10] (20.0 dBm)
  • 2462 MHz [11] (20.0 dBm)
  • 2467 MHz [12] (20.0 dBm)
  • 2472 MHz [13] (20.0 dBm)
  • 2484 MHz [14] (disabled)
    Bitrates (non-HT):
  • 1.0 Mbps
  • 2.0 Mbps
  • 5.5 Mbps
  • 11.0 Mbps
  • 6.0 Mbps
  • 9.0 Mbps
  • 12.0 Mbps
  • 18.0 Mbps
  • 24.0 Mbps
  • 36.0 Mbps
  • 48.0 Mbps
  • 54.0 Mbps
    Band 2:
    Capabilities: 0x62
    HT20/HT40
    RX HT20 SGI
    RX HT40 SGI
    No RX STBC
    No DSSS/CCK HT40
    Frequencies:
  • 5170 MHz [34] (disabled)
  • 5180 MHz [36] (20.0 dBm)
  • 5190 MHz [38] (20.0 dBm)
  • 5200 MHz [40] (20.0 dBm)
  • 5210 MHz [42] (20.0 dBm)
  • 5220 MHz [44] (20.0 dBm)
  • 5230 MHz [46] (20.0 dBm)
  • 5240 MHz [48] (20.0 dBm)
  • 5260 MHz [52] (20.0 dBm) (radar detection)
  • 5280 MHz [56] (20.0 dBm) (radar detection)
  • 5300 MHz [60] (20.0 dBm) (radar detection)
  • 5320 MHz [64] (20.0 dBm) (radar detection)
  • 5500 MHz [100] (27.0 dBm) (radar detection)
  • 5520 MHz [104] (27.0 dBm) (radar detection)
  • 5540 MHz [108] (27.0 dBm) (radar detection)
  • 5560 MHz [112] (27.0 dBm) (radar detection)
  • 5580 MHz [116] (27.0 dBm) (radar detection)
  • 5600 MHz [120] (27.0 dBm) (radar detection)
  • 5620 MHz [124] (27.0 dBm) (radar detection)
  • 5640 MHz [128] (27.0 dBm) (radar detection)
  • 5660 MHz [132] (27.0 dBm) (radar detection)
  • 5680 MHz [136] (27.0 dBm) (radar detection)
  • 5700 MHz [140] (27.0 dBm) (radar detection)
  • 5745 MHz [149] (disabled)
  • 5765 MHz [153] (disabled)
  • 5785 MHz [157] (disabled)
  • 5805 MHz [161] (disabled)
  • 5825 MHz [165] (disabled)
  • 5920 MHz [184] (disabled)
  • 5940 MHz [188] (disabled)
  • 5960 MHz [192] (disabled)
  • 5980 MHz [196] (disabled)
  • 6000 MHz [200] (disabled)
  • 6020 MHz [204] (disabled)
  • 6040 MHz [208] (disabled)
  • 6060 MHz [212] (disabled)
  • 6080 MHz [216] (disabled)
    Bitrates (non-HT):
  • 6.0 Mbps
  • 9.0 Mbps
  • 12.0 Mbps
  • 18.0 Mbps
  • 24.0 Mbps
  • 36.0 Mbps
  • 48.0 Mbps
  • 54.0 Mbps
    max # scan SSIDs: 16
    max scan IEs length: 1000 bytes
    Coverage class: 0 (up to 0m)
    Supported Ciphers:
  • WEP40 (00-0f-ac:1)
  • WEP104 (00-0f-ac:5)
  • TKIP (00-0f-ac:2)
  • CCMP (00-0f-ac:4)
  • 00-40-96:255
  • WPI-SMS4 (00-14-72:1)
    Available Antennas: TX 0 RX 0
    Supported interface modes:
  • IBSS
  • managed
  • AP
  • P2P-client
  • P2P-GO
    software interface modes (can always be added):
    interface combinations are not supported
    Supported commands:
  • new_interface
  • set_interface
  • new_key
  • new_beacon
  • join_ibss
  • set_pmksa
  • del_pmksa
  • flush_pmksa
  • remain_on_channel
  • set_tx_bitrate_mask
  • action
  • set_channel
  • Unknown command (75)
  • connect
  • disconnect
    Supported TX frame types:
  • managed: 0x0050 0x00d0
  • AP: 0x0050 0x00d0
  • P2P-client: 0x0050 0x00d0
  • P2P-GO: 0x0050 0x00d0
    Supported RX frame types:
  • managed: 0x0040 0x00d0
  • AP: 0x0040 0x00d0
  • P2P-client: 0x0040 0x00d0
  • P2P-GO: 0x0040 0x00d0
    WoWLAN support:
  • wake up on disconnect
  • wake up on magic packet
  • wake up on pattern match, up to 4 patterns of 1-64 bytes
  • can do GTK rekeying
  • wake up on GTK rekey failure
  • wake up on EAP identity request
  • wake up on 4-way handshake
    Device supports roaming.
I would like to confirm that the issue happens with Mikrotik devices only.
Tested on:
RB951G
CRS125
mAP 2n
Going to test with:
RB951Ui
RB951-2n
I have attempted to change almost every option with no luck.
Any updates on the status?
This problem is pretty serious. It should be the Mikrotik Wi-fi fault and it need to be debugged!
