Hello!
We have a strange wireless issue that we couldn’t find the origin.
In some devices (appeared on Linux, Android and iOS so far, we didn’t have a feedback of the issue on Windows), the wireless connection is disconnected, and the wireless (AP and virtual AP) disappear from the list of available wireless AP for a while (some minutes) and then come back.
So far we could see theses conditions:
- Does the same issue on RB951G-2HnD and hAP ac
- The issue is present only on 2.4 GHz, the devices that have issues in 2.4 GHz don’t have any issue with the 5 GHz (hAP ac)
- The issue was found on multiple RB951G-2HnD devices not only a specific one
- Not sure, but we didn’t see the issue with CAPsMAN, only when it’s a unique router
Maybe it’s our configuration (they are similar in all our devices), any idea?
To help, this is our configuration:
/interface wireless print advanced
name="wlan01-home" mtu=1500 l2mtu=1600 mac-address=4C:5E:0C:XX:XX:XX arp=reply-only disable-running-check=no interface-type=Atheros AR9300 radio-name="Home" mode=ap-bridge ssid="WiFi-Home" area="" frequency-mode=regulatory-domain country=OurCountry installation=any antenna-gain=3 frequency=auto band=2ghz-onlyn channel-width=20mhz secondary-channel="" scan-list=default wireless-protocol=802.11 rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=20 distance=dynamic tx-power-mode=default noise-floor-threshold=default nv2-noise-floor-offset=default vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled default-authentication=no default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 wmm-support=enabled hide-ssid=no security-profile=security-wpa2pskaes wps-mode=disabled station-roaming=enabled disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ampdu-priorities=0 guard-interval=any ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 tx-chains=0,1 rx-chains=0,1 amsdu-limit=8192 amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key="" nv2-mode=dynamic-downlink nv2-downlink-ratio=50 nv2-sync-secret="" hw-retries=7 frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced multicast-helper=default multicast-buffering=enabled keepalive-frames=enabled
/interface wireless security-profiles print detail
name="security-wpa2pskaes" mode=dynamic-keys authentication-types=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key="WPA2SecretKey" supplicant-identity="MikroTik" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none mschapv2-username="" mschapv2-password="" disable-pmkid=yes static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username radius-called-format=mac:ssid radius-mac-caching=disabled group-key-update=5m management-protection=allowed management-protection-key="ManagementSecretKey"
Wireless Keys are in /interface wireless access-list
Thanks for your help!
