Wi-Fi disconnection/reconnection (hap lite)
Hello!
I use hap lite to share wi-fi at home. There are 2 laptops, 2 iphones and a TV usually in the network.
For a while, the router is working correctly, but on some days, the network falls off every 10-15 minutes, and then reconnects.
I tried to reset the settings, change the channels, but the problem remained.
Firmware 6.39.2, protocol PPPoE.
I used the following instructions to configure: https://habrahabr.ru/post/265387/
Config:
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed \
    mode=dynamic-keys name=wpa2-protect supplicant-identity="" wpa-pre-shared-key=\
    rocking69 wpa2-pre-shared-key=rocking69
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no hw-retries=4 mode=\
    ap-bridge security-profile=wpa2-protect ssid=SORRY_FOR_PARTY tx-power-mode=\
    all-rates-fixed wireless-protocol=802.11 wps-mode=disabled
/interface wireless nstreme
set wlan1 enable-polling=no
