add admin-mac=D4:01:C3:F5:5B:EB auto-mac=no comment=defconf name=bridgeLocal
/interface wifiwave2 configuration
add name=sycn_wifi_config ssid=54of
/interface wifiwave2 datapath
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
managed by CAPsMAN
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap datapath=capdp disabled=no
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec1
set [ find default-name=wifi1 ] channel.band=5ghz-ac configuration.manager=local .mode=ap .ssid=SecondaryName datapath=capdp disabled=no security=sec1
add interface=bridgeLocal lease-time=1h name=dhcp1
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal interface=wifi1
add bridge=bridgeLocal interface=wifi2
/interface wifiwave2 cap
set discovery-interfaces=bridgeLocal enabled=yes slaves-datapath=capdp
/interface wifiwave2 capsman
set enabled=yes
/interface wifiwave2 provisioning
add action=create-enabled master-configuration=sycn_wifi_config
/ip dhcp-client
add comment=defconf interface=bridgeLocal
add address=192.168.1.0/24 gateway=192.168.1.1
in/out-interface matcher not possible when interface (ether2) is slave - use master instead (bridgeLocal)
add chain=srcnat out-interface=ether2
/system clock
set time-zone-name=Europe/Minsk
/system note
set show-at-login=no
Version is the same
Packages is the same too
Work perfectly fine (meaning - i have internet-ethernet connection, which sharing it with other interfaces in bridge ports), but when i try to import config.rsc to other device i - catch non-running state in wifi1 interface..also when i change location (plug in/out to different ethernet hole) of successful one, I'll fall to same case.
I'm new in this stuff. So strongly relay to community support
Appreciate any help or pieces of advice
