Wi-Fi issue
Hello everyone,
we have recently moved to a new office where we have rolled out Wi-Fi network with Mikrotik equipment. I have 2 CAP AC access points on the second floor and everything works perfect except one particular user who’s sitting right between 2 APs. He experiences voice quality degradation during Teams calls on both iphone and laptops devices though antenna is full. Network settings show up 5GHz range is used. Whenever it starts he needs to move across the office a bit and it becomes better. Please advise on what can be the problem? All of our users also use Teams on a daily basis without any problems
Both routers have the same SSID on 5Ghz interface?
Perhaps you can share some settings:
/interface/wireless/export hide-sensitive
And the LOG of both AP’s. Is the client roaming (flapping) between the 2 AP’s ?
Space your channels.
Good afternoon,
sorry for the late reply. I'm still struggling with some abnormal behavior with Wi-Fiespecially when making Teams calls. I'm attaching the config file for wireless interface.
# feb/15/2022 14:48:11 by RouterOS 6.47.9
# software id = J6V8-S047
# model = CRS326-24G-2S+
# serial number = DA720E12EC93
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2412 name=\
    channel2.4MHZ tx-power=20
add band=5ghz-n/ac frequency=5180 name=channel5.0MHZ tx-power=20
add name=bridge
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes name=datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security1
/caps-man configuration
add channel=channel2.4MHZ country=uzbekistan datapath=datapath1 mode=ap name=\
    cfg2.4 rx-chains=0,1,2,3 security=security1 ssid=TCA5 tx-chains=0,1,2,3
add channel=channel5.0MHZ country=uzbekistan datapath=datapath1 mode=ap name=\
    cfg5.0 rx-chains=0,1,2,3 security=security1 ssid=TCA5 tx-chains=0,1,2,3
add name=dhcp_pool0 ranges=10.11.12.2-10.11.12.254
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=b,g,gn \
    master-configuration=cfg2.4
add action=create-dynamic-enabled hw-supported-modes=ac,an \
    master-configuration=cfg5.0
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether6
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
add bridge=bridge interface=ether10
add bridge=bridge interface=ether11
add bridge=bridge interface=ether12
add bridge=bridge interface=ether13
add bridge=bridge interface=ether14
add bridge=bridge interface=ether15
add bridge=bridge interface=ether16
add bridge=bridge interface=ether17
add bridge=bridge interface=ether18
add bridge=bridge interface=ether19
add bridge=bridge interface=ether20
add bridge=bridge interface=ether21
add bridge=bridge interface=ether22
add bridge=bridge interface=ether23
add bridge=bridge interface=ether24
/ip dhcp-client
add disabled=no interface=bridge
/ip dhcp-relay
add dhcp-server=10.11.11.1 disabled=no interface=bridge name=relay1
add address=10.11.12.0/24 gateway=10.11.12.1
/system clock
set time-zone-name=Asia/Tashkent
/system routerboard settings
set boot-os=router-os
Good afternoon,
do yo mean this log?
http://prntscr.com/26w5lop
You seem to have both caps on the same channels, first adjustment should be choosing non=overlapping channels.
Could you please check (with a wifi analyzer) if both caps are running the same channel (or use capsman to confirm)?
Due to CAPsMAN the connection and registration logging is probably only visible on the CAPsMAN controller.
Add “/system logging topics=wireless,caps” for more info in the log.
Watching the situation during the past few weeks I figured out that other users also experience quality degradation during Teams calls and it frustrates me even more. Our office is an open space area 30 X 18m large with few meeting rooms of glass in the corners. I’m running 2 CAP ACs on this floor. Packet loss starts unpredictably for different users. At the same time other participants of the same meeting and sitting on the same floor can be fine. On the screenshots below you can see the same time interval for 2 participants of one Teams meeting today. Both were sitting on the same floor and in the same part of the office. It is visible that one has experienced failure in quality since 11:39 though the second one has not.
http://prntscr.com/26w5ro3
http://prntscr.com/26w5sp5
Please find attached.
# feb/15/2022 15:36:58 by RouterOS 6.47.9
13:07:34 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:08:13 caps,info 86:2D:C8:62:56:17@cap1 disconnected, extensive data loss
13:08:15 caps,info 42:F7:D8:0E:4A:AD@cap10 connected, signal strength -59
13:08:15 caps,info 42:F7:D8:0E:4A:AD@cap8 disconnected, registered to other interface
13:08:38 caps,info 08:71:90:8B:62:1C@cap10 connected, signal strength -63
13:08:38 caps,info 08:71:90:8B:62:1C@cap8 disconnected, registered to other interface
13:08:38 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -73
13:08:38 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
13:09:04 caps,info 0E:C5:65:F1:90:E2@cap9 disconnected, group key timeout
13:09:38 caps,info 86:2D:C8:62:56:17@cap2 connected, signal strength -71
13:10:06 caps,info 42:F7:D8:0E:4A:AD@cap9 connected, signal strength -53
13:10:06 caps,info 42:F7:D8:0E:4A:AD@cap10 disconnected, registered to other interface
13:10:33 caps,info 86:2D:C8:62:56:17@cap1 connected, signal strength -67
13:10:33 caps,info 86:2D:C8:62:56:17@cap2 disconnected, registered to other interface
13:10:43 caps,info 42:F7:D8:0E:4A:AD@cap10 connected, signal strength -58
13:10:43 caps,info 42:F7:D8:0E:4A:AD@cap9 disconnected, registered to other interface
13:10:46 caps,info 4C:79:6E:49:56:A6@cap10 connected, signal strength -47
13:10:51 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -72
13:10:51 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:10:58 caps,info 0E:C5:65:F1:90:E2@cap9 connected, signal strength -57
13:11:04 caps,info 5A:38:0F:3C:50:38@cap9 connected, signal strength -44
13:11:28 caps,info 86:2D:C8:62:56:17@cap2 connected, signal strength -63
13:11:28 caps,info 86:2D:C8:62:56:17@cap1 disconnected, registered to other interface
13:12:04 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -75
13:12:04 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
13:12:44 caps,info 4A:9C:46:7B:7F:47@cap9 connected, signal strength -58
13:12:44 caps,info 4A:9C:46:7B:7F:47@cap10 disconnected, registered to other interface
13:12:54 caps,info A6:04:4B:D1:CD:70@cap1 disconnected, extensive data loss
13:13:32 caps,info 86:2D:C8:62:56:17@cap1 connected, signal strength -73
13:13:32 caps,info 86:2D:C8:62:56:17@cap2 disconnected, registered to other interface
13:13:44 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -66
13:13:44 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:14:04 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, group key timeout
13:14:04 caps,info 0E:C5:65:F1:90:E2@cap9 disconnected, group key timeout
13:14:12 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -71
13:14:22 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -54
13:14:22 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, registered to other interface
13:14:29 caps,info 86:2D:C8:62:56:17@cap2 connected, signal strength -71
13:14:29 caps,info 86:2D:C8:62:56:17@cap1 disconnected, registered to other interface
13:14:38 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -65
13:14:38 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:15:00 caps,info 22:38:75:6F:2E:9D@cap2 connected, signal strength -55
13:15:00 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
13:15:11 caps,info 0E:C5:65:F1:90:E2@cap9 connected, signal strength -51
13:15:50 caps,info A6:04:4B:D1:CD:70@cap2 connected, signal strength -87
13:15:55 caps,info A6:04:4B:D1:CD:70@cap2 disconnected, extensive data loss
13:16:04 caps,info 38:00:25:0E:E6:38@cap7 connected, signal strength -59
13:16:04 caps,info 38:00:25:0E:E6:38@cap8 disconnected, registered to other interface
13:17:26 caps,info EA:9D:12:DD:72:C2@cap10 connected, signal strength -54
13:17:26 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
13:18:33 caps,info 04:B1:67:62:7C:80@cap1 connected, signal strength -77
13:19:04 caps,info 38:00:25:0E:E6:38@cap9 connected, signal strength -45
13:19:04 caps,info 38:00:25:0E:E6:38@cap7 disconnected, registered to other interface
13:19:04 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, group key timeout
13:19:04 caps,info 0E:C5:65:F1:90:E2@cap9 disconnected, group key timeout
13:19:10 caps,info 0E:C5:65:F1:90:E2@cap9 connected, signal strength -51
13:19:20 caps,info 50:3E:AA:97:3C:E5@cap7 disconnected, received disassoc: sending station leaving (8)
13:19:32 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -74
13:20:59 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -74
13:20:59 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
13:21:01 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -68
13:21:01 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:21:03 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -74
13:21:03 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
13:21:10 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -67
13:21:10 caps,info 68:5A:CF:EB:1F:17@cap8 disconnected, registered to other interface
13:21:12 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -65
13:21:12 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
13:21:13 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -71
13:21:13 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
13:21:15 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -82
13:21:15 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
13:21:18 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -79
13:21:18 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
13:21:18 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -82
13:21:18 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
13:21:19 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -76
13:21:19 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
13:21:21 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -75
13:21:21 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
13:21:21 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -59
13:21:21 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
13:21:29 caps,info 66:90:37:5D:41:CE@cap2 connected, signal strength -70
13:21:30 caps,info 4C:79:6E:4F:15:D7@cap10 connected, signal strength -54
13:21:30 caps,info 4C:79:6E:4F:15:D7@cap8 disconnected, registered to other interface
13:21:32 caps,info 86:2D:C8:62:56:17@cap1 connected, signal strength -69
13:21:32 caps,info 86:2D:C8:62:56:17@cap2 disconnected, registered to other interface
13:21:36 caps,info 86:2D:C8:62:56:17@cap2 connected, signal strength -73
13:21:36 caps,info 86:2D:C8:62:56:17@cap1 disconnected, registered to other interface
13:21:58 caps,info 38:00:25:0E:E6:65@cap8 connected, signal strength -57
13:21:59 caps,info 66:90:37:5D:41:CE@cap7 connected, signal strength -66
13:21:59 caps,info 66:90:37:5D:41:CE@cap2 disconnected, registered to other interface
13:22:04 caps,info 5A:38:0F:3C:50:38@cap2 connected, signal strength -61
13:22:04 caps,info 5A:38:0F:3C:50:38@cap9 disconnected, registered to other interface
13:22:05 caps,info 66:9C:14:9E:17:73@cap10 disconnected, group key timeout
13:22:05 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, group key timeout
13:22:25 caps,info 66:9C:14:9E:17:73@cap9 connected, signal strength -49
13:22:25 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -69
13:22:26 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
13:22:51 caps,info 5A:38:0F:3C:50:38@cap1 connected, signal strength -60
13:22:51 caps,info 5A:38:0F:3C:50:38@cap2 disconnected, registered to other interface
13:23:07 caps,info 5A:38:0F:3C:50:38@cap8 connected, signal strength -48
13:23:07 caps,info 5A:38:0F:3C:50:38@cap1 disconnected, registered to other interface
13:23:09 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -57
13:23:09 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, registered to other interface
13:23:21 caps,info 6C:C7:EC:6A:27:E8@cap8 connected, signal strength -86
13:23:22 caps,info 6C:C7:EC:6A:27:E8@cap9 disconnected, registered to other interface
13:23:30 caps,info 6C:C7:EC:6A:27:E8@cap2 connected, signal strength -79
13:23:30 caps,info 6C:C7:EC:6A:27:E8@cap8 disconnected, registered to other interface
13:23:43 caps,info 5A:38:0F:3C:50:38@cap10 connected, signal strength -48
13:23:43 caps,info 5A:38:0F:3C:50:38@cap8 disconnected, registered to other interface
13:23:53 caps,info 6C:C7:EC:6A:27:E8@cap1 connected, signal strength -84
13:23:53 caps,info 6C:C7:EC:6A:27:E8@cap2 disconnected, registered to other interface
13:23:56 caps,info 6C:C7:EC:6A:27:E8@cap8 connected, signal strength -83
13:23:56 caps,info 6C:C7:EC:6A:27:E8@cap1 disconnected, registered to other interface
13:24:01 caps,info 6C:C7:EC:6A:27:E8@cap7 connected, signal strength -74
13:24:04 caps,info 0E:C5:65:F1:90:E2@cap9 disconnected, group key timeout
13:24:11 caps,info 6C:C7:EC:6A:27:E8@cap7 disconnected, extensive data loss
13:24:21 caps,info 66:90:37:5D:41:CE@cap10 connected, signal strength -61
13:24:21 caps,info 66:90:37:5D:41:CE@cap7 disconnected, registered to other interface
13:24:25 caps,info 6C:C7:EC:6A:27:E8@cap8 disconnected, extensive data loss
13:24:31 caps,info A6:71:EB:C0:6E:57@cap8 connected, signal strength -56
13:24:31 caps,info A6:71:EB:C0:6E:57@cap7 disconnected, registered to other interface
13:24:42 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -61
13:24:43 caps,info 68:5A:CF:EB:1F:17@cap2 disconnected, registered to other interface
13:25:08 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -78
13:25:09 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -74
13:25:09 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
13:25:14 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, 4-way handshake timeout
13:25:17 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -52
13:25:17 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
13:26:01 caps,info 22:38:75:6F:2E:9D@cap2 connected, signal strength -59
13:26:01 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
13:26:04 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -72
13:26:16 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -46
13:26:16 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
13:27:14 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -56
13:27:15 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, registered to other interface
13:27:30 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -49
13:27:36 caps,info 66:9C:14:9E:17:73@cap10 connected, signal strength -59
13:27:36 caps,info 66:9C:14:9E:17:73@cap9 disconnected, registered to other interface
13:28:05 caps,info 66:90:37:5D:41:CE@cap7 connected, signal strength -60
13:28:05 caps,info 66:90:37:5D:41:CE@cap10 disconnected, registered to other interface
13:28:21 caps,info 86:2D:C8:62:56:17@cap1 connected, signal strength -81
13:28:21 caps,info 86:2D:C8:62:56:17@cap2 disconnected, registered to other interface
13:28:29 caps,info 22:38:75:6F:2E:9D@cap2 connected, signal strength -55
13:28:29 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
13:28:42 caps,info A6:71:EB:C0:6E:57@cap7 connected, signal strength -49
13:28:42 caps,info A6:71:EB:C0:6E:57@cap8 disconnected, registered to other interface
13:28:45 caps,info 86:2D:C8:62:56:17@cap2 connected, signal strength -54
13:28:45 caps,info 86:2D:C8:62:56:17@cap1 disconnected, registered to other interface
13:29:06 caps,info 08:71:90:8B:61:D1@cap8 connected, signal strength -52
13:29:12 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -74
13:29:12 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
13:29:38 caps,info 4A:9C:46:7B:7F:47@cap7 connected, signal strength -61
13:29:38 caps,info 4A:9C:46:7B:7F:47@cap9 disconnected, registered to other interface
13:29:40 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -70
13:29:40 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:29:50 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -74
13:29:50 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
13:30:55 caps,info 86:2D:C8:62:56:17@cap1 connected, signal strength -67
13:30:55 caps,info 86:2D:C8:62:56:17@cap2 disconnected, registered to other interface
13:32:05 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, group key timeout
13:32:16 caps,info 86:2D:C8:62:56:17@cap2 connected, signal strength -55
13:32:16 caps,info 86:2D:C8:62:56:17@cap1 disconnected, registered to other interface
13:32:17 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -70
13:32:53 caps,info 4C:79:6E:4F:24:96@cap10 connected, signal strength -47
13:32:56 caps,info 4C:79:6E:4F:24:96@cap10 disconnected, received deauth: unspecified (1)
13:33:00 caps,info 4C:79:6E:4F:24:96@cap10 connected, signal strength -49
13:33:04 caps,info 5A:38:0F:3C:50:38@cap9 connected, signal strength -36
13:33:04 caps,info 5A:38:0F:3C:50:38@cap10 disconnected, registered to other interface
13:33:12 caps,info 38:00:25:19:42:45@cap7 connected, signal strength -60
13:33:12 caps,info 38:00:25:19:42:45@cap10 disconnected, registered to other interface
13:33:45 caps,info C6:16:7A:FF:FE:99@cap9 connected, signal strength -57
13:33:45 caps,info C6:16:7A:FF:FE:99@cap10 disconnected, registered to other interface
13:33:51 caps,info 42:F7:D8:0E:4A:AD@cap7 connected, signal strength -55
13:33:51 caps,info 42:F7:D8:0E:4A:AD@cap10 disconnected, registered to other interface
13:35:45 caps,info 86:2D:C8:62:56:17@cap1 connected, signal strength -62
13:35:45 caps,info 86:2D:C8:62:56:17@cap2 disconnected, registered to other interface
13:36:19 caps,info 04:B1:67:62:7C:80@cap1 disconnected, extensive data loss
13:36:28 caps,info A6:71:EB:C0:6E:57@cap8 connected, signal strength -58
13:36:28 caps,info A6:71:EB:C0:6E:57@cap7 disconnected, registered to other interface
13:36:30 caps,info 04:B1:67:62:7C:80@cap1 connected, signal strength -63
13:37:05 caps,info 38:00:25:0D:ED:82@cap9 connected, signal strength -35
13:37:05 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, group key timeout
13:37:19 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -75
13:37:24 caps,info 80:4E:70:97:A9:CA@cap10 connected, signal strength -55
13:37:25 caps,info 86:2D:C8:62:56:17@cap2 connected, signal strength -64
13:37:25 caps,info 86:2D:C8:62:56:17@cap1 disconnected, registered to other interface
13:37:34 caps,info 04:B1:67:62:7C:80@cap1 reassociating
13:37:34 caps,info 04:B1:67:62:7C:80@cap1 connected, signal strength -54
13:37:44 caps,info 86:2D:C8:62:56:17@cap1 connected, signal strength -60
13:37:44 caps,info 86:2D:C8:62:56:17@cap2 disconnected, registered to other interface
13:39:09 caps,info 5A:38:0F:3C:50:38@cap8 connected, signal strength -59
13:39:09 caps,info 5A:38:0F:3C:50:38@cap9 disconnected, registered to other interface
13:39:19 caps,info 5A:38:0F:3C:50:38@cap7 connected, signal strength -56
13:39:19 caps,info 5A:38:0F:3C:50:38@cap8 disconnected, registered to other interface
13:39:46 caps,info 50:3E:AA:97:3C:E5@cap7 connected, signal strength -36
13:40:15 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -46
13:40:15 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, registered to other interface
13:40:30 caps,info 42:F7:D8:0E:4A:AD@cap8 connected, signal strength -59
13:40:30 caps,info 42:F7:D8:0E:4A:AD@cap7 disconnected, registered to other interface
13:40:34 caps,info A6:71:EB:C0:6E:57@cap7 connected, signal strength -50
13:40:34 caps,info A6:71:EB:C0:6E:57@cap8 disconnected, registered to other interface
13:41:01 caps,info 86:2D:C8:62:56:17@cap2 connected, signal strength -54
13:41:01 caps,info 86:2D:C8:62:56:17@cap1 disconnected, registered to other interface
13:41:35 caps,info 0E:C5:65:F1:90:E2@cap1 connected, signal strength -69
13:41:35 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, registered to other interface
13:42:05 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, group key timeout
13:42:15 caps,info 22:38:75:6F:2E:9D@cap2 connected, signal strength -52
13:42:15 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
13:42:30 caps,info 42:F7:D8:0E:4A:AD@cap7 connected, signal strength -50
13:42:30 caps,info 42:F7:D8:0E:4A:AD@cap8 disconnected, registered to other interface
13:42:37 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -62
13:42:38 caps,info 0E:C5:65:F1:90:E2@cap1 disconnected, registered to other interface
13:42:55 caps,info 4C:79:6E:4F:24:96@cap10 disconnected, received deauth: unspecified (1)
13:43:14 caps,info 50:3E:AA:97:3C:E5@cap7 disconnected, received disassoc: sending station leaving (8)
13:43:14 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -73
13:43:34 caps,info 4C:79:6E:4F:24:96@cap10 connected, signal strength -52
13:43:51 caps,info A6:71:EB:C0:6E:57@cap8 connected, signal strength -45
13:43:51 caps,info A6:71:EB:C0:6E:57@cap7 disconnected, registered to other interface
13:44:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
13:44:05 caps,info A6:71:EB:C0:6E:57@cap7 connected, signal strength -64
13:44:05 caps,info A6:71:EB:C0:6E:57@cap8 disconnected, registered to other interface
13:44:07 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -50
13:44:44 caps,info C6:16:7A:FF:FE:99@cap7 connected, signal strength -58
13:44:44 caps,info C6:16:7A:FF:FE:99@cap9 disconnected, registered to other interface
13:45:16 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -62
13:45:16 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:45:20 caps,info B6:C6:77:2C:66:9C@cap10 connected, signal strength -62
13:45:20 caps,info B6:C6:77:2C:66:9C@cap9 disconnected, registered to other interface
13:45:28 caps,info B6:C6:77:2C:66:9C@cap9 connected, signal strength -66
13:45:28 caps,info B6:C6:77:2C:66:9C@cap10 disconnected, registered to other interface
13:46:13 caps,info B6:C6:77:2C:66:9C@cap10 connected, signal strength -63
13:46:13 caps,info B6:C6:77:2C:66:9C@cap9 disconnected, registered to other interface
13:46:25 caps,info B6:C6:77:2C:66:9C@cap9 connected, signal strength -64
13:46:25 caps,info B6:C6:77:2C:66:9C@cap10 disconnected, registered to other interface
13:47:05 caps,info 66:9C:14:9E:17:73@cap10 disconnected, group key timeout
13:47:33 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -74
13:47:33 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
13:47:48 caps,info C6:16:7A:FF:FE:99@cap9 connected, signal strength -54
13:47:48 caps,info C6:16:7A:FF:FE:99@cap7 disconnected, registered to other interface
13:47:49 caps,info 42:F7:D8:0E:4A:AD@cap10 connected, signal strength -58
13:47:49 caps,info 42:F7:D8:0E:4A:AD@cap7 disconnected, registered to other interface
13:47:51 caps,info 66:9C:14:9E:17:73@cap10 connected, signal strength -58
13:49:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
13:49:09 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -54
13:49:33 caps,info 08:71:90:8B:61:C7@cap9 connected, signal strength -57
13:50:39 caps,info 4A:9C:46:7B:7F:47@cap10 connected, signal strength -73
13:50:39 caps,info 4A:9C:46:7B:7F:47@cap7 disconnected, registered to other interface
13:50:42 caps,info 4A:9C:46:7B:7F:47@cap9 connected, signal strength -62
13:50:42 caps,info 4A:9C:46:7B:7F:47@cap10 disconnected, registered to other interface
13:50:57 caps,info 1A:23:5D:74:FD:5F@cap1 connected, signal strength -85
13:51:20 caps,info 1A:23:5D:74:FD:5F@cap1 disconnected, extensive data loss
13:51:21 caps,info 1A:23:5D:74:FD:5F@cap8 connected, signal strength -62
13:52:05 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, group key timeout
13:52:27 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -74
13:52:42 caps,info 2E:2E:10:AE:B7:68@cap2 connected, signal strength -74
13:52:52 caps,info 4A:9C:46:7B:7F:47@cap10 connected, signal strength -72
13:52:52 caps,info 4A:9C:46:7B:7F:47@cap9 disconnected, registered to other interface
13:52:53 caps,info 2E:2E:10:AE:B7:68@cap1 connected, signal strength -69
13:52:53 caps,info 2E:2E:10:AE:B7:68@cap2 disconnected, registered to other interface
13:52:53 caps,info 86:2D:C8:62:56:17@cap1 connected, signal strength -62
13:52:53 caps,info 86:2D:C8:62:56:17@cap2 disconnected, registered to other interface
13:53:00 caps,info 4A:9C:46:7B:7F:47@cap9 connected, signal strength -67
13:53:00 caps,info 4A:9C:46:7B:7F:47@cap10 disconnected, registered to other interface
13:53:17 interface,info ether10 link down
13:53:22 caps,info 2E:2E:10:AE:B7:68@cap7 connected, signal strength -61
13:53:22 caps,info 2E:2E:10:AE:B7:68@cap1 disconnected, registered to other interface
13:53:22 caps,info 3E:B3:93:EC:8B:27@cap7 connected, signal strength -72
13:53:33 caps,info 3E:B3:93:EC:8B:27@cap10 connected, signal strength -64
13:53:33 caps,info 3E:B3:93:EC:8B:27@cap7 disconnected, registered to other interface
13:53:43 caps,info 62:7C:CD:B1:86:51@cap10 connected, signal strength -63
13:53:45 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -63
13:53:45 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, registered to other interface
13:54:02 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -55
13:54:02 caps,info EA:9D:12:DD:72:C2@cap10 disconnected, registered to other interface
13:54:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
13:54:14 caps,info 50:3E:AA:97:3C:E5@cap7 connected, signal strength -37
13:54:19 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -55
13:54:20 caps,info 2E:2E:10:AE:B7:68@cap10 connected, signal strength -54
13:54:20 caps,info 2E:2E:10:AE:B7:68@cap7 disconnected, registered to other interface
13:54:22 caps,info 60:AB:67:F4:4A:39@cap8 connected, signal strength -59
13:54:22 caps,info 60:AB:67:F4:4A:39@cap7 disconnected, registered to other interface
13:54:25 caps,info 60:AB:67:F4:4A:39@cap9 connected, signal strength -63
13:54:25 caps,info 60:AB:67:F4:4A:39@cap8 disconnected, registered to other interface
13:54:30 caps,info 22:38:75:6F:2E:9D@cap2 connected, signal strength -51
13:54:30 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
13:55:03 caps,info 3E:B3:93:EC:8B:27@cap8 connected, signal strength -50
13:55:03 caps,info 3E:B3:93:EC:8B:27@cap10 disconnected, registered to other interface
13:55:08 caps,info 2E:2E:10:AE:B7:68@cap8 connected, signal strength -58
13:55:08 caps,info 2E:2E:10:AE:B7:68@cap10 disconnected, registered to other interface
13:55:10 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -72
13:55:10 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:55:12 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -55
13:55:12 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
13:55:32 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -69
13:55:32 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
13:55:33 caps,info 22:38:75:6F:2E:9D@cap7 connected, signal strength -79
13:55:33 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, registered to other interface
13:55:45 caps,info 60:AB:67:F4:4A:39@cap7 connected, signal strength -54
13:55:45 caps,info 60:AB:67:F4:4A:39@cap9 disconnected, registered to other interface
13:55:49 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -66
13:55:49 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:55:55 caps,info 42:F1:52:9C:BE:83@cap1 disconnected, extensive data loss
13:55:58 caps,info 3E:B3:93:EC:8B:27@cap7 connected, signal strength -61
13:55:58 caps,info 3E:B3:93:EC:8B:27@cap8 disconnected, registered to other interface
13:56:07 caps,info 2E:2E:10:AE:B7:68@cap7 connected, signal strength -66
13:56:07 caps,info 2E:2E:10:AE:B7:68@cap8 disconnected, registered to other interface
13:56:34 caps,info 2E:2E:10:AE:B7:68@cap8 connected, signal strength -61
13:56:35 caps,info 2E:2E:10:AE:B7:68@cap8 reassociating
13:56:35 caps,info 2E:2E:10:AE:B7:68@cap8 connected, signal strength -62
13:56:35 caps,info 2E:2E:10:AE:B7:68@cap7 disconnected, registered to other interface
13:56:41 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -73
13:56:41 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
13:56:58 caps,info 2E:2E:10:AE:B7:68@cap7 connected, signal strength -70
13:56:58 caps,info 2E:2E:10:AE:B7:68@cap8 disconnected, registered to other interface
13:57:02 caps,info 9E:50:10:7F:BF:C3@cap7 connected, signal strength -77
13:57:05 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, group key timeout
13:57:12 caps,info 22:38:75:6F:2E:9D@cap7 disconnected, extensive data loss
13:57:28 caps,info FA:21:F9:5D:2B:57@cap10 connected, signal strength -76
13:57:36 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -68
13:57:36 caps,info FA:21:F9:5D:2B:57@cap10 disconnected, registered to other interface
13:58:02 caps,info 9E:50:10:7F:BF:C3@cap7 disconnected, extensive data loss
13:59:04 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, group key timeout
13:59:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
13:59:05 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -72
13:59:23 caps,info 3E:B3:93:EC:8B:27@cap8 connected, signal strength -65
13:59:23 caps,info 3E:B3:93:EC:8B:27@cap7 disconnected, registered to other interface
14:00:12 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -62
14:00:16 caps,info B6:C6:77:2C:66:9C@cap10 connected, signal strength -55
14:00:16 caps,info B6:C6:77:2C:66:9C@cap9 disconnected, registered to other interface
14:00:23 caps,info 2E:2E:10:AE:B7:68@cap10 connected, signal strength -56
14:00:23 caps,info 2E:2E:10:AE:B7:68@cap7 disconnected, registered to other interface
14:00:23 caps,info 9E:50:10:7F:BF:C3@cap10 connected, signal strength -68
14:00:27 caps,info 3E:B3:93:EC:8B:27@cap7 connected, signal strength -66
14:00:27 caps,info 3E:B3:93:EC:8B:27@cap8 disconnected, registered to other interface
14:00:35 caps,info 3E:B3:93:EC:8B:27@cap10 connected, signal strength -58
14:00:35 caps,info 3E:B3:93:EC:8B:27@cap7 disconnected, registered to other interface
14:00:40 caps,info 2E:2E:10:AE:B7:68@cap9 connected, signal strength -51
14:00:40 caps,info 2E:2E:10:AE:B7:68@cap10 disconnected, registered to other interface
14:00:42 caps,info 3E:B3:93:EC:8B:27@cap7 connected, signal strength -69
14:00:42 caps,info 3E:B3:93:EC:8B:27@cap10 disconnected, registered to other interface
14:00:45 caps,info 3E:B3:93:EC:8B:27@cap9 connected, signal strength -52
14:00:46 caps,info 3E:B3:93:EC:8B:27@cap7 disconnected, registered to other interface
14:00:46 caps,info 5A:38:0F:3C:50:38@cap2 connected, signal strength -65
14:00:46 caps,info 5A:38:0F:3C:50:38@cap7 disconnected, registered to other interface
14:00:53 caps,info E4:70:B8:CC:F6:C3@cap10 connected, signal strength -47
14:01:39 caps,info 5A:38:0F:3C:50:38@cap1 connected, signal strength -66
14:01:39 caps,info 5A:38:0F:3C:50:38@cap2 disconnected, registered to other interface
14:02:07 caps,info 5A:38:0F:3C:50:38@cap2 connected, signal strength -68
14:02:07 caps,info 5A:38:0F:3C:50:38@cap1 disconnected, registered to other interface
14:02:19 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -56
14:02:19 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
14:03:10 caps,info 5A:38:0F:3C:50:38@cap7 connected, signal strength -72
14:03:11 caps,info 5A:38:0F:3C:50:38@cap2 disconnected, extensive data loss
14:03:18 caps,info 5A:38:0F:3C:50:38@cap9 connected, signal strength -54
14:03:18 caps,info 5A:38:0F:3C:50:38@cap7 disconnected, registered to other interface
14:04:04 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, group key timeout
14:04:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
14:04:29 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -62
14:04:37 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -52
14:04:47 caps,info 8A:01:82:9B:92:D1@cap2 connected, signal strength -64
14:04:47 caps,info 5A:38:0F:3C:50:38@cap10 connected, signal strength -54
14:04:47 caps,info 5A:38:0F:3C:50:38@cap9 disconnected, registered to other interface
14:04:50 caps,info 8A:01:82:9B:92:D1@cap2 disconnected, received disassoc: sending station leaving (8)
14:05:11 caps,info 8A:01:82:9B:92:D1@cap2 connected, signal strength -72
14:05:17 caps,info 8A:01:82:9B:92:D1@cap2 disconnected, 4-way handshake timeout
14:05:32 caps,info B8:53:AC:16:64:DA@cap8 connected, signal strength -52
14:05:38 caps,info B8:53:AC:16:64:DA@cap8 disconnected, received deauth: 4-way handshake timeout (15)
14:05:49 caps,info B8:53:AC:16:64:DA@cap10 connected, signal strength -65
14:05:55 caps,info B8:53:AC:16:64:DA@cap10 disconnected, 4-way handshake timeout
14:05:58 caps,info B8:53:AC:16:64:DA@cap10 connected, signal strength -68
14:06:04 caps,info B8:53:AC:16:64:DA@cap10 disconnected, 4-way handshake timeout
14:06:23 caps,info B8:53:AC:16:64:DA@cap8 connected, signal strength -63
14:06:29 caps,info B8:53:AC:16:64:DA@cap8 disconnected, received deauth: 4-way handshake timeout (15)
14:07:30 caps,info 38:00:25:0E:E6:38@cap8 connected, signal strength -45
14:07:30 caps,info 38:00:25:0E:E6:38@cap9 disconnected, registered to other interface
14:09:04 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, group key timeout
14:09:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
14:09:08 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -60
14:09:37 caps,info 38:47:BC:57:4F:41@cap9 connected, signal strength -81
14:09:43 caps,info 38:47:BC:57:4F:41@cap9 disconnected, 4-way handshake timeout
14:09:46 caps,info 60:AB:67:F4:4A:39@cap1 connected, signal strength -58
14:09:46 caps,info 60:AB:67:F4:4A:39@cap7 disconnected, registered to other interface
14:09:47 caps,info 38:47:BC:57:4F:41@cap1 connected, signal strength -59
14:09:47 caps,info 38:47:BC:57:4F:41@cap7 disconnected, registered to other interface
14:10:04 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -42
14:10:04 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
14:10:15 caps,info 38:47:BC:57:4F:41@cap7 connected, signal strength -49
14:10:15 caps,info 38:47:BC:57:4F:41@cap1 disconnected, registered to other interface
14:10:19 caps,info 60:AB:67:F4:4A:39@cap8 connected, signal strength -56
14:10:19 caps,info 60:AB:67:F4:4A:39@cap1 disconnected, registered to other interface
14:10:24 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -42
14:10:50 caps,info 60:AB:67:F4:4A:39@cap10 connected, signal strength -62
14:10:50 caps,info 60:AB:67:F4:4A:39@cap8 disconnected, registered to other interface
14:11:03 caps,info 60:AB:67:F4:4A:39@cap9 connected, signal strength -74
14:11:07 caps,info 60:AB:67:F4:4A:39@cap9 disconnected, extensive data loss
14:11:09 caps,info 60:AB:67:F4:4A:39@cap9 connected, signal strength -81
14:11:10 caps,info 60:AB:67:F4:4A:39@cap10 disconnected, registered to other interface
14:11:16 caps,info 60:AB:67:F4:4A:39@cap2 connected, signal strength -63
14:11:16 caps,info 60:AB:67:F4:4A:39@cap9 disconnected, registered to other interface
14:11:17 caps,info 38:47:BC:57:4F:41@cap1 connected, signal strength -61
14:11:17 caps,info 38:47:BC:57:4F:41@cap7 disconnected, registered to other interface
14:11:28 caps,info 60:AB:67:F4:4A:39@cap1 connected, signal strength -66
14:11:28 caps,info 60:AB:67:F4:4A:39@cap2 disconnected, registered to other interface
14:11:57 caps,info 08:71:90:8B:61:D1@cap8 disconnected, received deauth: unspecified (1)
14:12:11 caps,info 4E:C4:88:D3:89:1E@cap9 connected, signal strength -39
14:12:11 caps,info 4E:C4:88:D3:89:1E@cap7 disconnected, registered to other interface
14:12:21 caps,info 3A:A1:73:54:DF:E7@cap9 connected, signal strength -52
14:12:22 caps,info 3A:A1:73:54:DF:E7@cap7 disconnected, registered to other interface
14:12:30 caps,info 38:47:BC:57:4F:41@cap1 disconnected, extensive data loss
14:12:54 caps,info 3A:A1:73:54:DF:E7@cap7 connected, signal strength -78
14:12:54 caps,info 3A:A1:73:54:DF:E7@cap9 disconnected, registered to other interface
14:12:55 caps,info 3A:A1:73:54:DF:E7@cap1 connected, signal strength -60
14:12:55 caps,info 3A:A1:73:54:DF:E7@cap7 disconnected, registered to other interface
14:12:55 caps,info 66:90:37:5D:41:CE@cap2 connected, signal strength -67
14:12:56 caps,info 66:90:37:5D:41:CE@cap7 disconnected, registered to other interface
14:13:12 caps,info 66:90:37:5D:41:CE@cap2 disconnected, extensive data loss
14:13:17 caps,info 66:90:37:5D:41:CE@cap1 connected, signal strength -84
14:13:21 caps,info 66:90:37:5D:41:CE@cap1 disconnected, received disassoc: sending station leaving (8)
14:13:28 caps,info 60:AB:67:F4:4A:39@cap1 disconnected, received deauth: class 3 frame received (7)
14:13:37 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -52
14:13:37 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
14:13:52 caps,info 3A:A1:73:54:DF:E7@cap7 connected, signal strength -87
14:13:52 caps,info 3A:A1:73:54:DF:E7@cap1 disconnected, registered to other interface
14:14:04 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, group key timeout
14:14:04 caps,info 3A:A1:73:54:DF:E7@cap7 disconnected, group key timeout
14:14:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
14:14:04 caps,info A6:71:EB:C0:6E:57@cap7 disconnected, group key timeout
14:14:13 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -47
14:14:20 caps,info A6:71:EB:C0:6E:57@cap7 connected, signal strength -60
14:14:21 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -59
14:16:21 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -50
14:16:21 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
14:16:46 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -45
14:16:46 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
14:16:51 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -51
14:16:51 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
14:16:57 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -60
14:16:57 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
14:16:59 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -71
14:16:59 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
14:16:59 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -71
14:16:59 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
14:17:00 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -78
14:17:00 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
14:17:00 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -61
14:17:00 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
14:17:01 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -77
14:17:01 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
14:17:01 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -66
14:17:01 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
14:17:02 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -69
14:17:02 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
14:17:04 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -69
14:17:04 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
14:17:04 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -75
14:17:04 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
14:17:06 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -72
14:17:06 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
14:17:09 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -74
14:17:09 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
14:17:11 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -71
14:17:11 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
14:17:43 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -68
14:17:43 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
14:18:20 caps,info 22:38:75:6F:2E:9D@cap7 connected, signal strength -81
14:18:23 caps,info 22:38:75:6F:2E:9D@cap9 connected, signal strength -80
14:18:23 caps,info 22:38:75:6F:2E:9D@cap7 disconnected, received deauth: class 3 frame received (7)
14:18:23 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -59
14:18:24 caps,info 68:5A:CF:EB:1F:17@cap2 disconnected, registered to other interface
14:18:29 caps,info 22:38:75:6F:2E:9D@cap9 disconnected, 4-way handshake timeout
14:19:04 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, group key timeout
14:19:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
14:19:24 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -57
14:19:39 caps,info 42:F1:52:9C:BE:83@cap2 connected, signal strength -68
14:19:40 caps,info 8E:E9:70:DC:98:DA@cap1 connected, signal strength -64
14:19:41 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -50
14:19:41 caps,info 42:F1:52:9C:BE:83@cap1 connected, signal strength -59
14:19:41 caps,info 42:F1:52:9C:BE:83@cap2 disconnected, registered to other interface
14:20:02 caps,info 96:B1:2F:2A:0E:6D@cap1 connected, signal strength -61
14:20:13 caps,info 96:B1:2F:2A:0E:6D@cap2 connected, signal strength -64
14:20:13 caps,info 96:B1:2F:2A:0E:6D@cap1 disconnected, registered to other interface
14:20:22 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -88
14:20:22 caps,info 68:5A:CF:EB:1F:17@cap2 reassociating
14:20:22 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -89
14:20:22 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 reassociating
14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -89
14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -88
14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -90
14:20:42 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -74
14:20:46 caps,info 68:5A:CF:EB:1F:17@cap2 disconnected, extensive data loss
14:20:47 caps,info 86:2D:C8:62:56:17@cap2 connected, signal strength -59
14:20:47 caps,info 86:2D:C8:62:56:17@cap1 disconnected, registered to other interface
14:20:55 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -79
14:20:55 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
14:20:55 caps,info 68:5A:CF:EB:1F:17@cap9 reassociating
14:20:55 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -78
14:20:56 caps,info 68:5A:CF:EB:1F:17@cap9 reassociating
14:20:56 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -84
14:20:57 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -84
14:20:57 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
14:20:58 caps,info 68:5A:CF:EB:1F:17@cap8 connected, signal strength -85
14:20:59 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
14:21:04 caps,info 68:5A:CF:EB:1F:17@cap8 disconnected, extensive data loss
14:21:04 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -83
14:21:04 caps,info 68:5A:CF:EB:1F:17@cap9 reassociating
14:21:04 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -85
14:21:34 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, extensive data loss
14:21:35 caps,info 96:B1:2F:2A:0E:6D@cap2 disconnected, extensive data loss
14:21:51 caps,info 96:B1:2F:2A:0E:6D@cap1 connected, signal strength -49
14:22:00 caps,info 96:B1:2F:2A:0E:6D@cap7 connected, signal strength -61
14:22:00 caps,info 96:B1:2F:2A:0E:6D@cap1 disconnected, registered to other interface
14:22:29 caps,info 22:38:75:6F:2E:9D@cap7 connected, signal strength -63
14:22:37 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -53
14:22:37 caps,info 22:38:75:6F:2E:9D@cap7 disconnected, registered to other interface
14:23:04 caps,info 96:B1:2F:2A:0E:6D@cap7 disconnected, received deauth: no activity (4)
14:23:06 caps,info 08:C5:E1:A4:48:E2@cap9 connected, signal strength -53
14:23:06 caps,info 08:C5:E1:A4:48:E2@cap7 disconnected, registered to other interface
14:23:10 caps,info 22:38:75:6F:2E:9D@cap2 connected, signal strength -52
14:23:10 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
14:23:57 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -47
14:23:57 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
14:23:58 caps,info 66:DC:47:30:C6:DC@cap7 connected, signal strength -74
14:24:04 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, group key timeout
14:24:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
14:24:04 caps,info FA:21:F9:5D:2B:57@cap9 connected, signal strength -52
14:24:11 caps,info 6A:05:AA:5A:C7:29@cap2 connected, signal strength -79
14:24:12 caps,info 66:DC:47:30:C6:DC@cap1 connected, signal strength -69
14:24:12 caps,info 66:DC:47:30:C6:DC@cap7 disconnected, registered to other interface
14:24:18 caps,info D0:7F:A0:07:90:C3@cap9 connected, signal strength -53
14:24:21 caps,info D0:7F:A0:07:90:C3@cap9 disconnected, received disassoc: sending station leaving (8)
14:24:35 caps,info 6A:05:AA:5A:C7:29@cap1 connected, signal strength -68
14:24:35 caps,info 6A:05:AA:5A:C7:29@cap2 disconnected, registered to other interface
14:24:46 caps,info 66:DC:47:30:C6:DC@cap7 connected, signal strength -83
14:24:46 caps,info 66:DC:47:30:C6:DC@cap1 disconnected, registered to other interface
14:24:57 caps,info 36:27:4F:C9:6F:0B@cap7 connected, signal strength -53
14:24:58 caps,info 88:75:98:9B:14:B0@cap10 connected, signal strength -67
14:25:06 caps,info 36:27:4F:C9:6F:0B@cap10 connected, signal strength -48
14:25:06 caps,info 36:27:4F:C9:6F:0B@cap7 disconnected, registered to other interface
14:25:13 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -59
14:25:17 caps,info 88:75:98:9B:14:B0@cap7 connected, signal strength -49
14:25:17 caps,info 88:75:98:9B:14:B0@cap10 disconnected, registered to other interface
14:25:24 caps,info 6A:05:AA:5A:C7:29@cap7 connected, signal strength -64
14:25:24 caps,info 6A:05:AA:5A:C7:29@cap1 disconnected, registered to other interface
14:25:27 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -63
14:25:27 caps,info 6A:05:AA:5A:C7:29@cap7 disconnected, registered to other interface
14:25:31 caps,info 66:DC:47:30:C6:DC@cap10 connected, signal strength -50
14:25:31 caps,info 66:DC:47:30:C6:DC@cap7 disconnected, registered to other interface
14:25:34 caps,info 88:75:98:9B:14:B0@cap7 disconnected, received deauth: sending station leaving (3)
14:26:14 caps,info 52:57:80:8B:17:88@cap2 connected, signal strength -63
14:26:35 caps,info 52:57:80:8B:17:88@cap1 connected, signal strength -70
14:26:35 caps,info 52:57:80:8B:17:88@cap2 disconnected, registered to other interface
14:26:41 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, received deauth: sending station leaving (8)
14:26:50 caps,info 52:57:80:8B:17:88@cap7 connected, signal strength -67
14:26:50 caps,info 52:57:80:8B:17:88@cap1 disconnected, registered to other interface
14:26:53 caps,info 42:F7:D8:0E:4A:AD@cap9 connected, signal strength -53
14:26:53 caps,info 42:F7:D8:0E:4A:AD@cap10 disconnected, registered to other interface
14:27:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
14:27:23 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -56
14:28:05 caps,info FA:21:F9:5D:2B:57@cap8 connected, signal strength -57
14:28:05 caps,info FA:21:F9:5D:2B:57@cap9 disconnected, registered to other interface
14:28:51 caps,info C6:16:7A:FF:FE:99@cap10 connected, signal strength -56
14:28:51 caps,info C6:16:7A:FF:FE:99@cap9 disconnected, registered to other interface
14:29:05 caps,info 96:B1:2F:2A:0E:6D@cap1 connected, signal strength -75
14:29:09 caps,info E4:70:B8:D1:07:18@cap9 connected, signal strength -52
14:29:26 caps,info FA:21:F9:5D:2B:57@cap8 disconnected, received deauth: sending station leaving (8)
14:29:27 caps,info FA:21:F9:5D:2B:57@cap7 connected, signal strength -56
14:29:51 caps,info 86:2D:C8:62:56:17@cap1 connected, signal strength -63
14:29:51 caps,info 86:2D:C8:62:56:17@cap2 disconnected, registered to other interface
14:30:00 caps,info 96:B1:2F:2A:0E:6D@cap1 disconnected, extensive data loss
14:30:05 caps,info 62:7C:CD:B1:86:51@cap9 connected, signal strength -63
14:30:06 caps,info 62:7C:CD:B1:86:51@cap10 disconnected, registered to other interface
14:30:18 caps,info 38:00:25:0D:ED:82@cap10 connected, signal strength -50
14:30:18 caps,info 38:00:25:0D:ED:82@cap9 disconnected, registered to other interface
14:30:21 caps,info A6:71:EB:C0:6E:57@cap8 connected, signal strength -55
14:30:21 caps,info A6:71:EB:C0:6E:57@cap7 disconnected, registered to other interface
14:30:28 caps,info A6:71:EB:C0:6E:57@cap7 connected, signal strength -56
14:30:28 caps,info A6:71:EB:C0:6E:57@cap8 disconnected, registered to other interface
14:30:39 caps,info B6:C6:77:2C:66:9C@cap9 connected, signal strength -58
14:30:39 caps,info B6:C6:77:2C:66:9C@cap10 disconnected, registered to other interface
14:30:55 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -50
14:30:55 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
14:31:09 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -57
14:31:09 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
14:31:11 caps,info B6:C6:77:2C:66:9C@cap8 connected, signal strength -61
14:31:11 caps,info B6:C6:77:2C:66:9C@cap9 disconnected, registered to other interface
14:31:27 caps,info 86:2D:C8:62:56:17@cap1 disconnected, extensive data loss
14:32:00 caps,info 8E:E9:70:DC:98:DA@cap1 disconnected, received deauth: sending station leaving (8)
14:32:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
14:32:16 caps,info 8E:E9:70:DC:98:DA@cap1 connected, signal strength -52
14:32:25 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -65
14:32:49 caps,info 0E:C5:65:F1:90:E2@cap9 connected, signal strength -56
14:32:52 caps,info 88:75:98:9B:14:B0@cap8 connected, signal strength -56
14:33:32 system,info,account user tcaadmin logged out from EC:79:49:4C:80:C0 via winbox
14:33:46 caps,info 36:27:4F:C9:6F:0B@cap9 connected, signal strength -47
14:33:46 caps,info 36:27:4F:C9:6F:0B@cap10 disconnected, registered to other interface
14:34:27 caps,info 88:75:98:9B:14:B0@cap8 disconnected, received deauth: sending station leaving (3)
14:34:36 system,info,account user tcaadmin logged in from EC:79:49:4C:80:C0 via winbox
14:34:42 system,info,account user tcaadmin logged in via local
14:35:07 caps,info 08:71:90:8B:62:1C@cap10 disconnected, received deauth: unspecified (1)
14:35:24 caps,info 88:75:98:9B:14:B0@cap10 connected, signal strength -74
14:35:25 caps,info 88:75:98:9B:14:B0@cap7 connected, signal strength -45
14:35:25 caps,info 88:75:98:9B:14:B0@cap10 disconnected, registered to other interface
14:35:33 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -51
14:35:34 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
14:36:06 caps,info 88:75:98:9B:14:B0@cap7 disconnected, received deauth: sending station leaving (3)
14:37:05 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, group key timeout
14:37:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
14:37:20 caps,info B6:C6:77:2C:66:9C@cap10 connected, signal strength -54
14:37:20 caps,info B6:C6:77:2C:66:9C@cap8 disconnected, registered to other interface
14:37:34 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -55
14:37:53 caps,info 2E:2E:10:AE:B7:68@cap10 connected, signal strength -60
14:37:53 caps,info 2E:2E:10:AE:B7:68@cap9 disconnected, registered to other interface
14:38:03 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -45
14:38:10 caps,info 62:7C:CD:B1:86:51@cap10 connected, signal strength -64
14:38:10 caps,info 62:7C:CD:B1:86:51@cap10 reassociating
14:38:11 caps,info 08:71:90:8B:61:B3@cap7 disconnected, received deauth: unspecified (1)
14:38:11 caps,info 62:7C:CD:B1:86:51@cap9 disconnected, registered to other interface
14:38:15 caps,info 08:C5:E1:A4:48:E2@cap7 connected, signal strength -49
14:38:15 caps,info 08:C5:E1:A4:48:E2@cap9 disconnected, registered to other interface
14:38:17 caps,info 42:F7:D8:0E:4A:AD@cap10 connected, signal strength -64
14:38:17 caps,info 42:F7:D8:0E:4A:AD@cap9 disconnected, registered to other interface
14:38:53 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -40
14:38:53 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
14:38:58 caps,info B6:C6:77:2C:66:9C@cap7 connected, signal strength -59
14:38:58 caps,info B6:C6:77:2C:66:9C@cap10 disconnected, registered to other interface
14:39:25 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -49
14:39:25 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
14:39:26 caps,info 1A:23:5D:74:FD:5F@cap7 connected, signal strength -46
14:39:26 caps,info 1A:23:5D:74:FD:5F@cap8 disconnected, registered to other interface
14:39:30 caps,info 22:38:75:6F:2E:9D@cap2 connected, signal strength -55
14:39:30 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
14:39:51 caps,info 42:F7:D8:0E:4A:AD@cap9 connected, signal strength -52
14:39:51 caps,info 42:F7:D8:0E:4A:AD@cap10 disconnected, registered to other interface
14:41:48 caps,info B6:C6:77:2C:66:9C@cap10 connected, signal strength -62
14:41:48 caps,info B6:C6:77:2C:66:9C@cap7 disconnected, registered to other interface
14:42:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
14:42:23 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -53
14:43:37 caps,info 2E:2E:10:AE:B7:68@cap7 connected, signal strength -63
14:43:37 caps,info 2E:2E:10:AE:B7:68@cap10 disconnected, registered to other interface
14:44:04 caps,info 0E:C5:65:F1:90:E2@cap9 disconnected, group key timeout
14:44:38 caps,info 0E:C5:65:F1:90:E2@cap9 connected, signal strength -53
14:45:25 caps,info 08:71:90:8B:62:1C@cap10 connected, signal strength -54
14:45:41 system,info,account user tcaadmin logged in via local
14:45:53 caps,info 36:27:4F:C9:6F:0B@cap10 connected, signal strength -57
14:45:53 caps,info 36:27:4F:C9:6F:0B@cap9 disconnected, registered to other interface
14:47:02 caps,info 42:F7:D8:0E:4A:AD@cap10 connected, signal strength -58
14:47:02 caps,info 42:F7:D8:0E:4A:AD@cap9 disconnected, registered to other interface
14:47:05 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, group key timeout
14:47:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
14:47:15 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -49
14:47:38 caps,info 22:38:75:6F:2E:9D@cap7 connected, signal strength -70
14:47:40 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -52
14:47:40 caps,info 22:38:75:6F:2E:9D@cap7 disconnected, registered to other interface
14:48:14 smb,info created new share: pub
14:48:22 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -73
14:48:22 caps,info 0E:C5:65:F1:90:E2@cap9 disconnected, registered to other interface
14:48:42 caps,info 22:38:75:6F:2E:9D@cap2 connected, signal strength -59
14:48:42 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
14:49:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
14:49:22 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -58
14:49:26 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -53
14:49:26 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, registered to other interface
14:49:36 system,info,account user tcaadmin logged out via local
14:50:09 caps,info 1A:23:5D:74:FD:5F@cap8 connected, signal strength -55
14:50:09 caps,info 1A:23:5D:74:FD:5F@cap7 disconnected, registered to other interface
14:51:00 caps,info 4E:C4:88:D3:89:1E@cap8 connected, signal strength -51
14:51:00 caps,info 4E:C4:88:D3:89:1E@cap9 disconnected, registered to other interface
14:51:12 caps,info 22:38:75:6F:2E:9D@cap2 connected, signal strength -62
14:51:13 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
14:52:05 caps,info 6A:FD:44:8F:3A:52@cap2 disconnected, group key timeout
14:52:05 caps,info 4E:C4:88:D3:89:1E@cap8 disconnected, group key timeout
14:52:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
14:52:07 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -62
14:52:30 caps,info 4E:C4:88:D3:89:1E@cap7 connected, signal strength -47
14:52:39 caps,info 6A:FD:44:8F:3A:52@cap1 connected, signal strength -40
14:53:43 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -41
14:53:43 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
14:54:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
14:54:19 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -55
14:54:20 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
14:54:39 caps,info 4E:C4:88:D3:89:1E@cap9 connected, signal strength -47
14:54:40 caps,info 4E:C4:88:D3:89:1E@cap7 disconnected, registered to other interface
14:55:07 caps,info 6A:FD:44:8F:3A:52@cap2 connected, signal strength -58
14:55:08 caps,info 6A:FD:44:8F:3A:52@cap1 disconnected, registered to other interface
14:55:47 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -61
14:56:38 caps,info 42:F7:D8:0E:4A:AD@cap7 connected, signal strength -47
14:56:38 caps,info 42:F7:D8:0E:4A:AD@cap10 disconnected, registered to other interface
14:56:40 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -54
14:56:40 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
14:57:05 caps,info 22:38:75:6F:2E:9D@cap2 disconnected, group key timeout
14:57:05 caps,info 1A:23:5D:74:FD:5F@cap8 disconnected, group key timeout
14:57:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
14:57:06 caps,info 1A:23:5D:74:FD:5F@cap1 connected, signal strength -43
14:57:08 caps,info 22:38:75:6F:2E:9D@cap1 connected, signal strength -52
14:57:20 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -62
14:58:25 caps,info 8E:E9:70:DC:98:DA@cap1 disconnected, received deauth: sending station leaving (8)
14:58:27 caps,info 8E:E9:70:DC:98:DA@cap1 connected, signal strength -45
14:58:52 caps,info 2E:2E:10:AE:B7:68@cap10 connected, signal strength -56
14:58:52 caps,info 2E:2E:10:AE:B7:68@cap7 disconnected, registered to other interface
14:59:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
14:59:04 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -60
14:59:45 caps,info 42:F1:52:9C:BE:83@cap7 connected, signal strength -61
14:59:46 caps,info 42:F1:52:9C:BE:83@cap1 disconnected, registered to other interface
14:59:53 caps,info 1A:23:5D:74:FD:5F@cap8 connected, signal strength -54
14:59:53 caps,info 1A:23:5D:74:FD:5F@cap1 disconnected, registered to other interface
14:59:55 caps,info 22:38:75:6F:2E:9D@cap9 connected, signal strength -51
14:59:55 caps,info 22:38:75:6F:2E:9D@cap1 disconnected, registered to other interface
15:00:06 caps,info 22:38:75:6F:2E:9D@cap7 connected, signal strength -68
15:00:06 caps,info 22:38:75:6F:2E:9D@cap9 disconnected, registered to other interface
15:00:08 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -53
15:00:08 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
15:00:14 system,info,account user tcaadmin logged out via local
15:00:31 caps,info 22:38:75:6F:2E:9D@cap10 connected, signal strength -59
15:00:32 caps,info 22:38:75:6F:2E:9D@cap7 disconnected, registered to other interface
15:00:32 caps,info 8E:E9:70:DC:98:DA@cap1 disconnected, received deauth: sending station leaving (8)
15:00:34 system,info,account user tcaadmin logged out from EC:79:49:4C:80:C0 via winbox
15:00:53 caps,info 22:38:75:6F:2E:9D@cap9 connected, signal strength -62
15:00:53 caps,info 22:38:75:6F:2E:9D@cap10 disconnected, registered to other interface
15:00:54 caps,info 42:F1:52:9C:BE:83@cap9 connected, signal strength -55
15:00:54 caps,info 42:F1:52:9C:BE:83@cap7 disconnected, registered to other interface
15:01:13 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -40
15:01:13 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
15:01:24 caps,info 04:B1:67:62:7C:80@cap1 disconnected, received disassoc: unspecified (1)
15:01:24 caps,info 04:B1:67:62:7C:80@cap9 connected, signal strength -72
15:01:28 caps,info 04:B1:67:62:7C:80@cap1 connected, signal strength -67
15:01:28 caps,info 04:B1:67:62:7C:80@cap9 disconnected, registered to other interface
15:01:29 caps,info 96:B1:2F:2A:0E:6D@cap2 connected, signal strength -58
15:01:43 caps,info 96:B1:2F:2A:0E:6D@cap7 connected, signal strength -59
15:01:43 caps,info 96:B1:2F:2A:0E:6D@cap2 disconnected, registered to other interface
15:02:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
15:02:23 caps,info E4:70:B8:D1:10:5A@cap10 connected, signal strength -54
15:02:23 caps,info E4:70:B8:D1:10:5A@cap9 disconnected, registered to other interface
15:03:02 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -66
15:03:25 caps,info 6A:05:AA:5A:C7:29@cap9 connected, signal strength -59
15:03:25 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, registered to other interface
15:03:50 caps,info A6:71:EB:C0:6E:57@cap8 connected, signal strength -57
15:03:50 caps,info A6:71:EB:C0:6E:57@cap7 disconnected, registered to other interface
15:03:54 caps,info 96:B1:2F:2A:0E:6D@cap7 disconnected, extensive data loss
15:04:04 caps,info 6A:05:AA:5A:C7:29@cap9 disconnected, group key timeout
15:04:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
15:04:17 caps,info B6:C6:77:2C:66:9C@cap1 connected, signal strength -78
15:04:17 caps,info B6:C6:77:2C:66:9C@cap10 disconnected, registered to other interface
15:04:20 caps,info B6:C6:77:2C:66:9C@cap9 connected, signal strength -55
15:04:20 caps,info B6:C6:77:2C:66:9C@cap1 disconnected, registered to other interface
15:04:27 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -56
15:04:28 caps,info A6:71:EB:C0:6E:57@cap7 connected, signal strength -47
15:04:28 caps,info A6:71:EB:C0:6E:57@cap8 disconnected, registered to other interface
15:04:32 caps,info 6A:05:AA:5A:C7:29@cap9 connected, signal strength -42
15:04:40 caps,info 42:F7:D8:0E:4A:AD@cap8 connected, signal strength -57
15:04:40 caps,info 42:F7:D8:0E:4A:AD@cap7 disconnected, registered to other interface
15:04:49 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -50
15:04:49 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
15:06:03 caps,info 22:38:75:6F:2E:9D@cap10 connected, signal strength -53
15:06:03 caps,info 22:38:75:6F:2E:9D@cap9 disconnected, registered to other interface
15:06:05 caps,info 8E:E9:70:DC:98:DA@cap9 connected, signal strength -53
15:06:12 caps,info 22:38:75:6F:2E:9D@cap7 connected, signal strength -64
15:06:12 caps,info 22:38:75:6F:2E:9D@cap10 disconnected, registered to other interface
15:06:22 caps,info 22:38:75:6F:2E:9D@cap9 connected, signal strength -62
15:06:22 caps,info 22:38:75:6F:2E:9D@cap7 disconnected, registered to other interface
15:06:41 caps,info 52:57:80:8B:17:88@cap9 connected, signal strength -50
15:06:41 caps,info 52:57:80:8B:17:88@cap7 disconnected, registered to other interface
15:06:44 caps,info 22:38:75:6F:2E:9D@cap10 connected, signal strength -69
15:06:44 caps,info 22:38:75:6F:2E:9D@cap9 disconnected, registered to other interface
15:06:47 caps,info 22:38:75:6F:2E:9D@cap9 connected, signal strength -72
15:06:47 caps,info 22:38:75:6F:2E:9D@cap10 disconnected, registered to other interface
15:06:57 caps,info 52:57:80:8B:17:88@cap10 connected, signal strength -64
15:06:57 caps,info 52:57:80:8B:17:88@cap9 disconnected, registered to other interface
15:07:05 caps,info 52:57:80:8B:17:88@cap9 connected, signal strength -49
15:07:05 caps,info 52:57:80:8B:17:88@cap10 disconnected, registered to other interface
15:07:23 caps,info 6C:C7:EC:6A:27:E8@cap8 connected, signal strength -65
15:07:24 caps,info 42:F7:D8:0E:4A:AD@cap7 connected, signal strength -53
15:07:24 caps,info 42:F7:D8:0E:4A:AD@cap8 disconnected, registered to other interface
15:07:28 caps,info 6C:C7:EC:6A:27:E8@cap9 connected, signal strength -60
15:07:28 caps,info 6C:C7:EC:6A:27:E8@cap8 disconnected, registered to other interface
15:07:53 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -38
15:07:53 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
15:07:55 caps,info 6C:C7:EC:6A:27:E8@cap8 connected, signal strength -50
15:07:55 caps,info 6C:C7:EC:6A:27:E8@cap9 disconnected, registered to other interface
15:07:56 caps,info B6:C6:77:2C:66:9C@cap10 connected, signal strength -61
15:07:56 caps,info B6:C6:77:2C:66:9C@cap9 disconnected, registered to other interface
15:08:17 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -51
15:08:17 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
15:08:42 caps,info 6C:C7:EC:6A:27:E8@cap9 connected, signal strength -46
15:08:42 caps,info 6C:C7:EC:6A:27:E8@cap8 disconnected, registered to other interface
15:09:01 caps,info 66:D3:CA:D3:AB:CC@cap10 connected, signal strength -68
15:09:01 caps,info 66:D3:CA:D3:AB:CC@cap7 disconnected, registered to other interface
15:09:02 caps,info 6C:C7:EC:6A:27:E8@cap10 connected, signal strength -66
15:09:02 caps,info 6C:C7:EC:6A:27:E8@cap9 disconnected, registered to other interface
15:09:04 caps,info 6A:05:AA:5A:C7:29@cap9 disconnected, group key timeout
15:09:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
15:09:12 caps,info 66:D3:CA:D3:AB:CC@cap9 connected, signal strength -65
15:09:12 caps,info 66:D3:CA:D3:AB:CC@cap10 disconnected, registered to other interface
15:09:18 caps,info 6A:05:AA:5A:C7:29@cap9 connected, signal strength -55
15:09:38 caps,info 5A:38:0F:3C:50:38@cap10 disconnected, received disassoc: sending station leaving (8)
15:09:42 caps,info 22:38:75:6F:2E:9D@cap10 connected, signal strength -64
15:09:42 caps,info 22:38:75:6F:2E:9D@cap9 disconnected, registered to other interface
15:09:52 caps,info 4C:79:6E:49:56:A6@cap10 disconnected, received deauth: unspecified (1)
15:10:00 caps,info 42:F1:52:9C:BE:83@cap10 connected, signal strength -69
15:10:00 caps,info 42:F1:52:9C:BE:83@cap9 disconnected, registered to other interface
15:10:05 caps,info 42:F1:52:9C:BE:83@cap9 connected, signal strength -66
15:10:05 caps,info 42:F1:52:9C:BE:83@cap10 disconnected, registered to other interface
15:10:12 caps,info 42:F7:D8:0E:4A:AD@cap10 connected, signal strength -59
15:10:12 caps,info 42:F7:D8:0E:4A:AD@cap7 disconnected, registered to other interface
15:10:21 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -53
15:10:45 caps,info 1A:23:5D:74:FD:5F@cap1 connected, signal strength -40
15:10:46 caps,info 1A:23:5D:74:FD:5F@cap8 disconnected, registered to other interface
15:10:49 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -61
15:10:49 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
15:11:16 caps,info B6:C6:77:2C:66:9C@cap7 connected, signal strength -58
15:11:16 caps,info B6:C6:77:2C:66:9C@cap10 disconnected, registered to other interface
15:11:42 caps,info B6:C6:77:2C:66:9C@cap9 connected, signal strength -54
15:11:42 caps,info B6:C6:77:2C:66:9C@cap7 disconnected, registered to other interface
15:11:53 caps,info B6:C6:77:2C:66:9C@cap10 connected, signal strength -61
15:11:53 caps,info B6:C6:77:2C:66:9C@cap9 disconnected, registered to other interface
15:12:05 caps,info 6A:FD:44:8F:3A:52@cap2 disconnected, group key timeout
15:12:39 caps,info 66:D3:CA:D3:AB:CC@cap1 connected, signal strength -72
15:12:39 caps,info 66:D3:CA:D3:AB:CC@cap9 disconnected, registered to other interface
15:12:40 caps,info 66:D3:CA:D3:AB:CC@cap7 connected, signal strength -54
15:12:40 caps,info 66:D3:CA:D3:AB:CC@cap1 disconnected, registered to other interface
15:12:54 caps,info 6A:FD:44:8F:3A:52@cap2 connected, signal strength -59
15:12:59 caps,info 2E:2E:10:AE:B7:68@cap9 connected, signal strength -55
15:12:59 caps,info 2E:2E:10:AE:B7:68@cap10 disconnected, registered to other interface
15:13:20 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -59
15:13:20 caps,info 6A:05:AA:5A:C7:29@cap9 disconnected, registered to other interface
15:13:20 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -55
15:13:20 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
15:13:30 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -50
15:13:30 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
15:14:03 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -51
15:14:03 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
15:14:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
15:14:26 caps,info 2E:2E:10:AE:B7:68@cap10 connected, signal strength -59
15:14:26 caps,info 2E:2E:10:AE:B7:68@cap9 disconnected, registered to other interface
15:14:31 caps,info 4C:79:6E:49:56:A6@cap10 connected, signal strength -45
15:14:34 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -54
15:14:40 caps,info EA:9D:12:DD:72:C2@cap7 connected, signal strength -57
15:14:40 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
15:16:30 caps,info 3E:B3:93:EC:8B:27@cap10 connected, signal strength -57
15:16:30 caps,info 3E:B3:93:EC:8B:27@cap9 disconnected, registered to other interface
15:16:44 caps,info 42:F7:D8:0E:4A:AD@cap7 connected, signal strength -54
15:16:44 caps,info 42:F7:D8:0E:4A:AD@cap10 disconnected, registered to other interface
15:17:01 caps,info 66:90:37:5D:41:CE@cap1 connected, signal strength -62
15:17:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
15:17:48 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -61
15:17:54 caps,info 66:90:37:5D:41:CE@cap9 connected, signal strength -62
15:17:55 caps,info 66:90:37:5D:41:CE@cap1 disconnected, registered to other interface
15:18:08 caps,info 3A:A1:73:54:DF:E7@cap8 connected, signal strength -62
15:18:15 caps,info 3A:A1:73:54:DF:E7@cap7 connected, signal strength -47
15:18:15 caps,info 3A:A1:73:54:DF:E7@cap8 disconnected, registered to other interface
15:18:17 caps,info C6:16:7A:FF:FE:99@cap7 connected, signal strength -64
15:18:17 caps,info C6:16:7A:FF:FE:99@cap10 disconnected, registered to other interface
15:18:37 caps,info 60:AB:67:F4:4A:39@cap1 connected, signal strength -61
15:18:38 caps,info 04:B1:67:62:7C:80@cap9 connected, signal strength -70
15:18:39 caps,info 04:B1:67:62:7C:80@cap1 disconnected, registered to other interface
15:18:42 caps,info EA:9D:12:DD:72:C2@cap8 connected, signal strength -52
15:18:42 caps,info EA:9D:12:DD:72:C2@cap7 disconnected, registered to other interface
15:18:53 caps,info 66:90:37:5D:41:CE@cap7 connected, signal strength -57
15:18:53 caps,info 66:90:37:5D:41:CE@cap9 disconnected, registered to other interface
15:18:54 caps,info 04:B1:67:62:7C:80@cap9 disconnected, received disassoc: unspecified (1)
15:18:54 caps,info 04:B1:67:62:7C:80@cap1 connected, signal strength -54
15:19:05 caps,info 38:00:25:0E:E6:38@cap9 connected, signal strength -38
15:19:05 caps,info 38:00:25:0E:E6:38@cap8 disconnected, registered to other interface
15:19:07 caps,info EA:9D:12:DD:72:C2@cap10 connected, signal strength -48
15:19:07 caps,info EA:9D:12:DD:72:C2@cap8 disconnected, registered to other interface
15:19:14 caps,info 42:F7:D8:0E:4A:AD@cap9 connected, signal strength -59
15:19:14 caps,info 42:F7:D8:0E:4A:AD@cap7 disconnected, registered to other interface
15:19:29 caps,info 60:AB:67:F4:4A:39@cap9 connected, signal strength -63
15:19:29 caps,info 60:AB:67:F4:4A:39@cap1 disconnected, registered to other interface
15:19:36 caps,info 60:AB:67:F4:4A:39@cap7 connected, signal strength -45
15:19:36 caps,info 60:AB:67:F4:4A:39@cap9 disconnected, registered to other interface
15:20:02 caps,info 1A:23:5D:74:FD:5F@cap8 connected, signal strength -58
15:20:02 caps,info 1A:23:5D:74:FD:5F@cap1 disconnected, registered to other interface
15:20:04 caps,info 42:F7:D8:0E:4A:AD@cap8 connected, signal strength -60
15:20:04 caps,info 42:F7:D8:0E:4A:AD@cap9 disconnected, registered to other interface
15:20:11 caps,info 52:57:80:8B:17:88@cap7 connected, signal strength -67
15:20:11 caps,info 52:57:80:8B:17:88@cap9 disconnected, registered to other interface
15:20:12 caps,info 42:F7:D8:0E:4A:AD@cap10 connected, signal strength -58
15:20:12 caps,info 42:F7:D8:0E:4A:AD@cap8 disconnected, registered to other interface
15:21:03 caps,info 38:47:BC:57:4F:41@cap8 connected, signal strength -57
15:21:03 caps,info 3E:B3:93:EC:8B:27@cap9 connected, signal strength -43
15:21:03 caps,info 3E:B3:93:EC:8B:27@cap10 disconnected, registered to other interface
15:21:35 caps,info 52:57:80:8B:17:88@cap9 connected, signal strength -58
15:21:35 caps,info 52:57:80:8B:17:88@cap7 disconnected, registered to other interface
15:22:05 caps,info 6A:FD:44:8F:3A:52@cap2 disconnected, group key timeout
15:22:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
15:22:07 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -59
15:23:11 caps,info 6A:FD:44:8F:3A:52@cap1 connected, signal strength -40
15:23:29 caps,info 2E:2E:10:AE:B7:68@cap8 connected, signal strength -80
15:23:29 caps,info 2E:2E:10:AE:B7:68@cap10 disconnected, registered to other interface
15:23:32 caps,info 2E:2E:10:AE:B7:68@cap9 connected, signal strength -58
15:23:33 caps,info 2E:2E:10:AE:B7:68@cap8 disconnected, registered to other interface
15:23:36 caps,info C6:16:7A:FF:FE:99@cap10 connected, signal strength -54
15:23:37 caps,info C6:16:7A:FF:FE:99@cap7 disconnected, registered to other interface
15:24:29 caps,info 62:7C:CD:B1:86:51@cap9 connected, signal strength -44
15:24:29 caps,info 62:7C:CD:B1:86:51@cap10 disconnected, registered to other interface
15:25:02 caps,info 6A:FD:44:8F:3A:52@cap2 connected, signal strength -58
15:25:03 caps,info 6A:FD:44:8F:3A:52@cap1 disconnected, registered to other interface
15:25:11 system,info,account user tcaadmin logged in from 10.11.11.183 via winbox
15:25:13 system,info,account user tcaadmin logged in from 10.11.11.183 via telnet
15:25:16 caps,info 2E:2E:10:AE:B7:68@cap10 connected, signal strength -59
15:25:16 caps,info 2E:2E:10:AE:B7:68@cap9 disconnected, registered to other interface
15:25:19 caps,info 1A:23:5D:74:FD:5F@cap7 connected, signal strength -44
15:25:19 caps,info 1A:23:5D:74:FD:5F@cap8 disconnected, registered to other interface
15:25:25 caps,info 1A:23:5D:74:FD:5F@cap8 connected, signal strength -60
15:25:25 caps,info 1A:23:5D:74:FD:5F@cap7 disconnected, registered to other interface
15:25:38 caps,info 3E:B3:93:EC:8B:27@cap8 connected, signal strength -51
15:25:38 caps,info 3E:B3:93:EC:8B:27@cap9 disconnected, registered to other interface
15:25:43 caps,info 2E:2E:10:AE:B7:68@cap7 connected, signal strength -72
15:25:43 caps,info 2E:2E:10:AE:B7:68@cap10 disconnected, registered to other interface
15:25:46 caps,info 3E:B3:93:EC:8B:27@cap7 connected, signal strength -66
15:25:48 caps,info 3E:B3:93:EC:8B:27@cap8 disconnected, registered to other interface
15:27:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
15:27:06 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -57
15:27:28 caps,info 08:71:90:8B:61:B3@cap7 connected, signal strength -54
15:27:45 caps,info 9E:98:53:99:BC:11@cap8 connected, signal strength -57
15:27:45 caps,info 9E:98:53:99:BC:11@cap7 disconnected, registered to other interface
15:27:53 caps,info 4C:79:6E:49:56:A6@cap10 disconnected, received deauth: unspecified (1)
15:28:06 caps,info 66:90:37:5D:41:CE@cap10 connected, signal strength -57
15:28:06 caps,info 66:90:37:5D:41:CE@cap7 disconnected, registered to other interface
15:28:07 caps,info 2E:2E:10:AE:B7:68@cap10 connected, signal strength -53
15:28:07 caps,info 2E:2E:10:AE:B7:68@cap7 disconnected, registered to other interface
15:28:12 caps,info 3E:B3:93:EC:8B:27@cap10 connected, signal strength -50
15:28:12 caps,info 3E:B3:93:EC:8B:27@cap7 disconnected, registered to other interface
15:28:26 caps,info 3E:B3:93:EC:8B:27@cap9 connected, signal strength -52
15:28:26 caps,info 3E:B3:93:EC:8B:27@cap10 disconnected, registered to other interface
15:28:53 caps,info 66:90:37:5D:41:CE@cap9 connected, signal strength -56
15:28:53 caps,info 66:90:37:5D:41:CE@cap10 disconnected, registered to other interface
15:28:55 caps,info 42:F1:52:9C:BE:83@cap10 connected, signal strength -70
15:28:55 caps,info 42:F1:52:9C:BE:83@cap9 disconnected, registered to other interface
15:29:04 caps,info FA:21:F9:5D:2B:57@cap7 disconnected, group key timeout
15:29:04 caps,info A6:71:EB:C0:6E:57@cap7 disconnected, group key timeout
15:29:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
15:29:10 caps,info 4C:79:6E:49:56:A6@cap10 connected, signal strength -45
15:29:23 caps,info A6:71:EB:C0:6E:57@cap7 connected, signal strength -51
15:29:24 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -51
15:29:24 caps,info 04:B1:67:62:7C:80@cap1 disconnected, received disassoc: unspecified (1)
15:29:24 caps,info 04:B1:67:62:7C:80@cap9 connected, signal strength -71
15:29:28 caps,info 42:F1:52:9C:BE:83@cap7 connected, signal strength -78
15:29:28 caps,info 42:F1:52:9C:BE:83@cap10 disconnected, registered to other interface
15:29:28 caps,info 42:F1:52:9C:BE:83@cap9 connected, signal strength -67
15:29:29 caps,info 42:F1:52:9C:BE:83@cap7 disconnected, registered to other interface
15:29:30 caps,info 66:9C:14:9E:17:73@cap9 connected, signal strength -50
15:29:30 caps,info 66:9C:14:9E:17:73@cap10 disconnected, registered to other interface
15:29:34 caps,info 66:90:37:5D:41:CE@cap10 connected, signal strength -65
15:29:34 caps,info 66:90:37:5D:41:CE@cap9 disconnected, registered to other interface
15:29:52 caps,info FA:21:F9:5D:2B:57@cap7 connected, signal strength -53
15:30:23 caps,info 04:B1:67:62:7C:80@cap1 connected, signal strength -63
15:30:23 caps,info 04:B1:67:62:7C:80@cap9 disconnected, registered to other interface
15:30:23 caps,info 66:9C:14:9E:17:73@cap10 connected, signal strength -62
15:30:23 caps,info 66:9C:14:9E:17:73@cap9 disconnected, registered to other interface
15:31:36 caps,info 42:F7:D8:0E:4A:AD@cap9 connected, signal strength -47
15:31:36 caps,info 42:F7:D8:0E:4A:AD@cap10 disconnected, registered to other interface
15:32:01 caps,info 3E:B3:93:EC:8B:27@cap10 connected, signal strength -55
15:32:01 caps,info 3E:B3:93:EC:8B:27@cap9 disconnected, registered to other interface
15:32:02 system,info log rule added by tcaadmin
15:32:05 caps,info 6A:05:AA:5A:C7:29@cap10 disconnected, group key timeout
15:32:24 caps,info 42:F7:D8:0E:4A:AD@cap10 connected, signal strength -58
15:32:24 caps,info 42:F7:D8:0E:4A:AD@cap9 disconnected, registered to other interface
15:32:35 caps,info 6A:05:AA:5A:C7:29@cap10 connected, signal strength -66
15:34:04 caps,info FA:21:F9:5D:2B:57@cap7 disconnected, group key timeout
15:34:04 caps,info 0E:C5:65:F1:90:E2@cap7 disconnected, group key timeout
15:34:13 caps,info 0E:C5:65:F1:90:E2@cap7 connected, signal strength -53
15:34:19 caps,info 42:F7:D8:0E:4A:AD@cap9 connected, signal strength -53
15:34:19 caps,info 42:F7:D8:0E:4A:AD@cap10 disconnected, registered to other interface
15:34:20 caps,info FA:21:F9:5D:2B:57@cap7 connected, signal strength -52
15:34:38 caps,info 42:F7:D8:0E:4A:AD@cap7 connected, signal strength -56
15:34:38 caps,info 42:F7:D8:0E:4A:AD@cap9 disconnected, registered to other interface
15:34:50 caps,info 42:F7:D8:0E:4A:AD@cap10 connected, signal strength -59
15:34:50 caps,info 42:F7:D8:0E:4A:AD@cap7 disconnected, registered to other interface
15:35:01 caps,info 42:F1:52:9C:BE:83@cap10 connected, signal strength -64
15:35:01 caps,info 42:F1:52:9C:BE:83@cap9 disconnected, registered to other interface
15:35:13 caps,info 42:F1:52:9C:BE:83@cap9 connected, signal strength -49
15:35:13 caps,info 42:F1:52:9C:BE:83@cap10 disconnected, registered to other interface
15:35:27 caps,info 6C:C7:EC:6A:27:E8@cap9 connected, signal strength -67
15:35:27 caps,info 6C:C7:EC:6A:27:E8@cap10 disconnected, registered to other interface
15:35:38 caps,info 22:38:75:6F:2E:9D@cap8 connected, signal strength -63
15:35:38 caps,info 22:38:75:6F:2E:9D@cap10 disconnected, registered to other interface
15:35:43 caps,info 42:F1:52:9C:BE:83@cap7 connected, signal strength -57
15:35:43 caps,info 42:F1:52:9C:BE:83@cap9 disconnected, registered to other interface
15:36:22 caps,info 4E:C4:88:D3:89:1E@cap7 connected, signal strength -59
15:36:22 caps,info 4E:C4:88:D3:89:1E@cap9 disconnected, registered to other interface
15:36:24 caps,info 22:38:75:6F:2E:9D@cap10 connected, signal strength -56
15:36:24 caps,info 22:38:75:6F:2E:9D@cap8 disconnected, registered to other interface
15:36:40 system,info,account user tcaadmin logged in from 10.11.11.183 via telnet
15:36:43 system,info,account user tcaadmin logged out from 10.11.11.183 via telnet
15:36:47 caps,info 22:38:75:6F:2E:9D@cap8 connected, signal strength -87
15:36:47 caps,info 22:38:75:6F:2E:9D@cap10 disconnected, received deauth: class 3 frame received (7)
15:36:48 system,info,account user tcaadmin logged in from 10.11.11.183 via telnet
15:36:51 caps,info 42:F1:52:9C:BE:83@cap1 connected, signal strength -68
15:36:51 caps,info 22:38:75:6F:2E:9D@cap8 disconnected, extensive data loss
15:36:51 caps,info 42:F1:52:9C:BE:83@cap7 disconnected, registered to other interface
Go back through and rename your caps with location, band and channel.
You will be able to figure it out much quicker when the log has these in the entries.
I would try local forwarding as you aren’t using a super powerful device as a capsman server.
This would be in your data path config.
Combining the Teams statistics with the connection log would be interesting. Now they cover a different timeframe.
This here looks more a flapping client (very fast switching radio or even AP). Are they walking around, or just sitting?
444: 14:16:57 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -60
445: 14:16:57 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
446: 14:16:59 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -71
447: 14:16:59 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
448: 14:16:59 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -71
449: 14:16:59 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
450: 14:17:00 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -78
451: 14:17:00 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
452: 14:17:00 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -61
453: 14:17:00 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
454: 14:17:01 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -77
455: 14:17:01 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
456: 14:17:01 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -66
457: 14:17:01 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
458: 14:17:02 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -69
459: 14:17:02 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
460: 14:17:04 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -69
461: 14:17:04 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
462: 14:17:04 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -75
463: 14:17:04 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
464: 14:17:06 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -72
465: 14:17:06 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
466: 14:17:09 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -74
467: 14:17:09 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
468: 14:17:11 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -71
469: 14:17:11 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
Be carefull with weak connections that do lead to low interface rates (PHY), as could be spotted in the registration table.
It is not certain that this low dBm (<86) is causing very low speeds. But it could be.
Any device in the channel transmitting continously and at a low PHY rate, will slow down all other connections, to actually that same low speed.
489: 14:20:22 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -88
490: 14:20:22 caps,info 68:5A:CF:EB:1F:17@cap2 reassociating
491: 14:20:22 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -89
492: 14:20:22 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
493: 14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 reassociating
494: 14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -89
495: 14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 reassociating
496: 14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -88
497: 14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 reassociating
498: 14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -88
499: 14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 reassociating
500: 14:20:41 caps,info 68:5A:CF:EB:1F:17@cap2 connected, signal strength -90
501: 14:20:42 caps,info 68:5A:CF:EB:1F:17@cap1 connected, signal strength -74
502: 14:20:46 caps,info 68:5A:CF:EB:1F:17@cap2 disconnected, extensive data loss
505: 14:20:55 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -79
506: 14:20:55 caps,info 68:5A:CF:EB:1F:17@cap1 disconnected, registered to other interface
507: 14:20:55 caps,info 68:5A:CF:EB:1F:17@cap9 reassociating
508: 14:20:55 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -78
509: 14:20:56 caps,info 68:5A:CF:EB:1F:17@cap9 reassociating
510: 14:20:56 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -84
511: 14:20:57 caps,info 68:5A:CF:EB:1F:17@cap7 connected, signal strength -84
512: 14:20:57 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, registered to other interface
513: 14:20:58 caps,info 68:5A:CF:EB:1F:17@cap8 connected, signal strength -85
514: 14:20:59 caps,info 68:5A:CF:EB:1F:17@cap7 disconnected, registered to other interface
515: 14:21:04 caps,info 68:5A:CF:EB:1F:17@cap8 disconnected, extensive data loss
516: 14:21:04 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -83
517: 14:21:04 caps,info 68:5A:CF:EB:1F:17@cap9 reassociating
518: 14:21:04 caps,info 68:5A:CF:EB:1F:17@cap9 connected, signal strength -85
519: 14:21:34 caps,info 68:5A:CF:EB:1F:17@cap9 disconnected, extensive data loss
Thank you for advice! I have enable ACL to drop clients with weak RSSI. Continue to monitor the situation.
http://prntscr.com/26xhoox
Maybe you need to go for 3 units in more of a triangle arrangement, with reduced TX-power, then?
Also, you should double check, that on 5GHz channel DFS detection is not kicking in.
I live in a rural area and 5GHz channels are not crowed, but I noticed that some cars may also cause this.
Actually two of our neighbours have a model with automatic distance/speed control and all these other gismos - and whenever they come home, one of my cAP-ac report a detected radar, which is of course a false alarm, but nevertheless is forcing wifi to go down for 10mins in that segment.
Only option top solve this has been to force capsman to use non-dfs channels.
FWIW, I have two hAP-ac3 units, now on wifiwave2 drivers and here, the radar detection is much more robust than with standard wifi drivers (and performance as well as coverage is doubled -unfortunately, no capsman support and roaming between APs is a bit worse, because clients simply decide to stick - without capsman, there is no real use of ACL IMHO).
Why do you think so?
Experiences vary. Uses too. Let me tell my perception. It’s only perception, YMMV.
Didn’t look at the size of the room so far. But indeed 3 units might be an improvement. I would not reduce TX power until really needed. The 3 units should work on different frequencies. If on the same freq all devices wait for each other whatever TXpower reduction is used.
DFS radar detect should be clearly indicated in the LOG. And avoiding false detections can be very hard. Detection is different for different frequencies, so changing frequencies is a possible answer. False positive radar detect for a certain frequency may happen in one unit , and not in another some meters away fo the same frequency.
Cruise control and emergency radar detection of cars is at 24, 75 or 95GHz if I read the specs. But some cars, like an Audi try to connect to any AP they see. I see those cars drive around in town on the city network. So far the MT wAP ac was the worst generator of false positives for me. (With “Snooper” I could even see phantom radio frequencies of them). 10 minutes downtime only happens if the wheater channels are checked (120,124,128). With standalone setting (non CAPsMAN) there is also avoid “10min CAC” in the “Skip DFS channels” option. Without that a well crafted channel list can be used, even avoiding the known false-positive-sensitive channels as well.
I do not use CAPsMAN because I fine tune every AP independently. And various ACL’s are an important part of this tuning, to avoid weak connections and kick off sticky clients where needed.
No wifiwave2 here yet, but surprised that roaming would be less fluent. At least I hoped that wifiwave2 included 802.11/r/k/v to support fast roaming and controlled roaming handover. A hAP ac3 on the ceiling is visually not very well integrated in an open office. :frowning:
DFS and radar detects are biggest problem for me currently on mikrotik wifi setups and specially on more dense capsman setups, i get so many radar downtimes per day not to mention often CAPs just get stuck forever in detecting-radar state until i reboot them or toggle wifi interface on/off, so im forced to disable radar freqs and limit my self to less channels and add more interference and bring down performanse of network down in general in favor of not having total blackouts which pisses off customers more than anything..
I just deployed Aruba instant on aps on site with 20 aps, they all work without any radar issues and use DFS channels and bring up wifi very fast without any dropouts thru day, while on the other side i get false positive radar detects on Mikrotik in basements where not even GSM signal penetrates, which is absolute joke…
…because it is a distributed list…you need extra effort to manage it centrally, then deploy to each AP.
Also in winbox, the “copy to ACL” button in wifiwave2 registration list panel is simply non existant (as is the details panel at all)
