Wi-fi network solition Plz..
Hi friends!!
We have a campus at my work location. I have to implement the Wi-Fi campus in 1Km range with 360 degree angle, and full strength of single like mobile phone signal.
Kindly advise me for the product for my campus. I have to implement omni directional antenna for my campus.
Is there any other suggestions please advise for my required designe, i want to purchase that model.
Please leave a valuable suggestion for me..
Thanks in advance..
NO SUCH DEVICE
We’ll need more information to really help. A rough map and an idea of scale will help. As a rule of thumb you might be able to broadcast a wifi signal 360 degrees quite a long distance…but the issue is the clients. Smaller devices - which we’re trending more and more towards - like cell phones and tablets really only have an effective range of 100 meters.
You’re best model is going to be a backhaul using panel antennas distributed out to multiple points on your campus (unless you have fiber or ethernet run) and your choice of antennas and equipment at each of those points.
-Mac
Or just put a bunch of devices to do roaming.
