Hi all,
I am unable to see the wi-fi ssid on any device which I try to connect with my router.
If I connect a LAN cable to the router, it can access the internet without any problems.
The router is connected to another router which is the gateway to the internet.
Why is the wi-fi ssid not visible?
Here is the router configuration.
[admin@MikroTik] > export
may/28/2023 20:08:31 by RouterOS 7.9.1
software id = TREE-5IVV
model = C52iG-5HaxD2HaxD
add name=bridge-lan
/interface wifiwave2 channel
add frequency="5180,5200,5220,5240,5260,5280,5300,5320,5500,5520,5540,5560,5580,5600,5620,5640,5660,5680,5700,5720,574
5,5765,5785,5805,5825" name=ch-5ghz width=20/40/80mhz
add frequency=2412,2432,2472 name=ch-2ghz width=20mhz
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk encryption=ccmp,gcmp,ccmp-256,gcmp-256 management-protection=allowed name=
common-auth wps=disable
/interface wifiwave2 configuration
add country=India name=common-conf security=common-auth ssid=Periscope5G
no supported channels
set [ find default-name=wifi1 ] channel=ch-2ghz configuration=common-conf configuration.mode=ap disabled=no
set [ find default-name=wifi2 ] channel=ch-5ghz configuration=common-conf disabled=no
/port
set 0 name=serial0
add bridge=bridge-lan interface=all
/ip settings
set ip-forward=no
/ipv6 settings
set max-neighbor-entries=15360
/ip dhcp-client
add interface=bridge-lan
/system clock
set time-zone-name=Asia/Kolkata
/system note
set show-at-login=no
Pranav
