Wi-Fi on MikroTik RB2011UAS-2HnD-IN
For those who are interested I found unicast key timeout trying to establish a connection.
I just delete the local wireless virtual AP and create a new one including the bridged interfase and works again. :confused:
Cheers.
Hello All,
I am having a challenge with my MikroTik RB2011UAS-2HnD-IN, while setting it up I gave the DHCP server a different IP address from the gateway address. I tried accessing the Router Board later but could not get in,tried to reset the Router Board but everything remains the same. Can anyone help me out ? Does this Router Board have a radius server?
Help needed urgently…
Try to connect using MAC address in Winbox (press button “…”, find your mikrotik, and click on its MAC address). Other way is to configure IP address of your computer manually instead of DHCP.
RB has RadiusServer. Look here http://wiki.mikrotik.com/wiki/Manual:Interface/Wireless
I want to start a WISP and I intend to use Mikrotik RB2011UAS-2HnD-IN as my core router, can anyone guide me on how to set up access control list on this device and also set up the radius server.
Also I want to use ubiquiti nanostation m5 as my base station and use nanostation loco5 at the user end,I hope there wont be any compactibility issues. Lastly what is range of d above mentioned RB when used indoors?
Thanks. I have resolved the issue. Had to do reinstall of RouterOS using netinstall and its working very well.
gud
lol i have the same problem with ipad2… AGAIN :confused:
Current Version 5.25
IOS 6.1.3
after power on - ping is about 100ms (distance - 1m) and then no ping at all
looks like Mikrotik hardware doesn’t like Apple at all :laughing:
maybe someone will help - frequency set to 2447 mhz solve the problem with apple …
Hello guys, I am also despеrate here. I have same board RB2011UAS-2HnD-IN - before it I had RB750G,
From a long time ago I have such problems with my apple devices. I used many 5.xx version , and now I am using 6.15 for RB2011UAS-2HnD-IN .
I have many apple devices, 2 iPads, 3 iPhones, 1 ipod - all have same problem as all you describe.
I am trying to do the one thing here which looks to work - to change rate-selection
My Current value is advanced. I am trying to make it legacy - but can not :frowning:
I am using this command from terminal
/interface wireless edit 0 rate-selection
It gives me text editor - there I delete word “advanced” and replace it with “legacy” - After that I press CTRL+O - but again my value is advanced. I try this for some other option like frequency and it works fine.
I really like mikrotik routers, I use then on many places for small ISPs , but I just can not make it work fine with my Apple devices. Help please.
P.S. I think problem got works after I updated to 6.15 yesterday .
god damn, my ipad2 dont work normal AGAIN
wlan1: data from unknown device 34:51:C9:2C:40:32, sent deauth – many times…
what is it ?? i was all ok for some months..but again…
Strange that only iThings still have such problems…
its 2014 and still the same problem continues with Mikrotik devices used at Wireless Access Points…
please help… someone… i am on verge of loosing clients… because of this strange issues…
Me too .. Mikrotik it’s fantastic but has a big problem with wifi connections. My advice: buy a mikrotik that don’t have wifi, and buy a Wiffi appliance appart, it’s the best solution for two things: 1) wifi change more than routing 2) wifi in mikrotik don’t work very smooth
I had never seen wifi incompatibility when 802.11 (abgn, mimo, 20/40HT) mode was used on Mikrotik devices with any other devices. On the other hand I have to admit that there are almost none apple products around…
What I see here on the forum time to time, generally apple products have the problems. Why to blame Mikrotik for that?
@Jarda :
I do not fully agree with you when you say generally apple devices are affected.
My log of one AP (Groove A-52HPn) :
jan/21 23:48:48 wireless,info 44:33:4C:C9:E9:0F@wlan1: connected
jan/21 23:57:56 wireless,info 48:43:7C:8B:04:17@wlan1: connected
jan/21 23:58:42 wireless,info E4:12:1D:F8:D4:80@wlan1: connected
jan/21 23:58:44 wireless,info F8:84:F2:7A:3C:61@wlan1: connected
jan/21 23:58:49 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
jan/21 23:59:35 wireless,info F8:84:F2:7A:3C:61@wlan1: disconnected, extensive data loss
jan/21 23:59:40 wireless,info E4:12:1D:F8:D4:80@wlan1: disconnected, extensive data loss
00:02:51 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, extensive data loss
00:08:44 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:29:25 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
00:29:26 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
00:29:26 wireless,info 48:43:7C:8B:04:17@wlan1: connected
00:29:26 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
00:35:01 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
00:35:10 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
00:35:11 wireless,info 48:43:7C:8B:04:17@wlan1: connected
00:39:25 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
00:39:41 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
00:39:41 wireless,info 48:43:7C:8B:04:17@wlan1: connected
00:39:41 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
00:39:42 wireless,info 48:43:7C:8B:04:17@wlan1: connected
00:48:02 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
00:48:42 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
00:49:17 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
00:49:17 wireless,info 48:43:7C:8B:04:17@wlan1: connected
00:49:17 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
00:49:18 wireless,info 48:43:7C:8B:04:17@wlan1: connected
00:49:31 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:49:31 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:49:31 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:49:50 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:49:50 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:49:50 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:50:00 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:50:00 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:50:00 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:50:18 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:50:18 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:50:18 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:50:28 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:50:28 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:50:28 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:50:38 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:50:38 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:50:38 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:51:02 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:51:02 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:51:02 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:51:12 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:51:12 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:51:12 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:51:35 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:51:35 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:51:35 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:51:55 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:51:55 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:51:55 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:52:22 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
00:52:25 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
00:52:25 wireless,info 48:43:7C:8B:04:17@wlan1: connected
00:52:25 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
00:52:37 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:52:37 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:52:37 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:52:58 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:52:58 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:52:58 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:53:09 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:53:09 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:53:09 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:53:13 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
00:53:56 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:53:56 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:53:56 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:54:36 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:54:36 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:54:36 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:54:57 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:54:57 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:54:57 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:55:13 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:55:13 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:55:13 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:55:36 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:55:36 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:55:36 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:55:53 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:55:53 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:55:53 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:56:09 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:56:09 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:56:09 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:56:10 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
00:56:10 wireless,info 48:43:7C:8B:04:17@wlan1: connected
00:56:31 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:56:31 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:56:31 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:56:51 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:56:51 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:56:51 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:57:07 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:57:07 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:57:07 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:57:18 wireless,info 00:22:43:47:04:DB@wlan1: reassociating
00:57:18 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, ok
00:57:18 wireless,info 00:22:43:47:04:DB@wlan1: connected
00:57:18 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
00:57:43 wireless,info 00:22:43:47:04:DB@wlan1: disconnected, extensive data loss
00:59:05 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
00:59:06 wireless,info 48:43:7C:8B:04:17@wlan1: connected
01:00:19 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
01:00:36 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
01:00:36 wireless,info 48:43:7C:8B:04:17@wlan1: connected
01:00:36 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
01:00:52 wireless,info F8:84:F2:22:41:F4@wlan1: connected
01:00:52 wireless,info F8:84:F2:22:41:F4@wlan1: disconnected, received disassoc: sending station leaving (8)
01:02:24 wireless,info F8:84:F2:22:41:F4@wlan1: connected
01:02:24 wireless,info F8:84:F2:22:41:F4@wlan1: reassociating
01:02:24 wireless,info F8:84:F2:22:41:F4@wlan1: disconnected, ok
01:02:43 wireless,info F8:84:F2:22:41:F4@wlan1: disconnected, registered to other device in network
01:12:15 wireless,info F8:84:F2:22:41:F4@wlan1: connected
01:12:15 wireless,info F8:84:F2:22:41:F4@wlan1: disconnected, received disassoc: sending station leaving (8)
01:12:15 wireless,info wlan1: data from unknown device F8:84:F2:22:41:F4, sent deauth
01:34:15 wireless,info 84:38:38:17:C4:B7@wlan1: connected
01:34:17 wireless,info 84:38:38:17:C4:B7@wlan1: disconnected, received disassoc: sending station leaving (8)
01:34:17 wireless,info wlan1: data from unknown device 84:38:38:17:C4:B7, sent deauth
03:33:42 wireless,info 38:0B:40:5E:AC:A4@wlan1: connected
03:34:45 wireless,info 38:0B:40:5E:AC:A4@wlan1: disconnected, received disassoc: sending station leaving (8)
06:51:05 wireless,info 2C:8A:72:B3:0B:A4@wlan1: connected
06:51:31 wireless,info 2C:8A:72:B3:0B:A4@wlan1: disconnected, received deauth: sending station leaving (3)
07:20:25 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:21:14 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
07:21:55 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
07:21:55 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:21:55 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
07:27:55 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
07:27:56 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
07:27:56 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:27:56 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
07:28:45 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
07:31:40 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
07:31:40 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:34:51 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
07:35:09 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
07:35:10 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:36:55 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
07:37:24 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
07:37:24 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:37:24 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
07:37:25 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:40:38 wireless,info F0:27:65:73:C8:A9@wlan1: connected
07:41:09 wireless,info F0:27:65:73:C8:A9@wlan1: disconnected, received disassoc: sending station leaving (8)
07:41:09 wireless,info wlan1: data from unknown device F0:27:65:73:C8:A9, sent deauth
07:41:11 wireless,info F0:27:65:73:C8:A9@wlan1: connected
07:41:42 wireless,info F0:27:65:73:C8:A9@wlan1: disconnected, received disassoc: sending station leaving (8)
07:41:42 wireless,info wlan1: data from unknown device F0:27:65:73:C8:A9, sent deauth
07:42:06 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
07:43:24 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
07:43:25 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:45:01 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
07:45:39 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
07:45:40 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:47:58 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
07:48:40 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
07:48:40 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:48:40 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
07:48:41 wireless,info 48:43:7C:8B:04:17@wlan1: connected
07:49:28 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
07:50:09 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
07:51:57 wireless,info A4:EB:D3:7C:AB:93@wlan1: connected
07:52:28 wireless,info A4:EB:D3:7C:AB:93@wlan1: disconnected, extensive data loss
08:05:30 wireless,info 48:43:7C:8B:04:17@wlan1: connected
08:11:11 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
08:11:30 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
08:11:30 wireless,info 48:43:7C:8B:04:17@wlan1: connected
08:11:30 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
08:15:02 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
08:15:15 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
08:15:16 wireless,info 48:43:7C:8B:04:17@wlan1: connected
08:41:23 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
08:42:01 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
08:42:01 wireless,info 48:43:7C:8B:04:17@wlan1: connected
08:42:01 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
08:43:01 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
08:43:26 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, extensive data loss
08:43:31 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
08:43:39 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
08:43:41 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
08:43:41 wireless,info 48:43:7C:8B:04:17@wlan1: connected
08:44:30 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, extensive data loss
08:45:27 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
08:46:51 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
08:46:51 wireless,info 48:43:7C:8B:04:17@wlan1: connected
08:46:51 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
09:18:59 wireless,info 1C:99:4C:C5:B2:A0@wlan1: connected
09:19:24 wireless,info 1C:99:4C:C5:B2:A0@wlan1: disconnected, extensive data loss
09:54:02 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
09:54:02 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
09:54:36 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
10:13:00 wireless,info F8:84:F2:22:41:F4@wlan1: connected
10:13:00 wireless,info F8:84:F2:22:41:F4@wlan1: disconnected, received disassoc: sending station leaving (8)
10:13:00 wireless,info wlan1: data from unknown device F8:84:F2:22:41:F4, sent deauth
10:15:17 wireless,info 00:73:E0:DB:8E:81@wlan1: connected
10:15:53 wireless,info 00:73:E0:DB:8E:81@wlan1: disconnected, extensive data loss
10:17:33 wireless,info 00:73:E0:DB:8E:81@wlan1: connected
10:17:55 wireless,info 00:73:E0:DB:8E:81@wlan1: disconnected, received disassoc: unspecified (1)
10:20:25 wireless,info 48:43:7C:8B:04:17@wlan1: connected
10:31:49 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
10:32:14 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
10:32:14 wireless,info 48:43:7C:8B:04:17@wlan1: connected
10:32:16 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, registered to other device in network
10:37:13 wireless,info 2C:8A:72:B3:0B:A4@wlan1: connected
10:37:13 wireless,info 2C:8A:72:B3:0B:A4@wlan1: disconnected, received deauth: sending station leaving (3)
10:37:23 wireless,info 2C:8A:72:B3:0B:A4@wlan1: connected
10:37:24 wireless,info 48:43:7C:8B:04:17@wlan1: connected
10:42:43 wireless,info D0:4F:7E:47:E2:90@wlan1: connected
10:43:17 wireless,info 20:64:32:B9:BD:6F@wlan1: connected
10:43:28 wireless,info 2C:8A:72:B3:0B:A4@wlan1: disconnected, registered to other device in network
10:43:49 wireless,info 20:64:32:B9:BD:6F@wlan1: disconnected, registered to other device in network
10:44:43 wireless,info 2C:8A:72:B3:0B:A4@wlan1: connected
10:51:46 wireless,info 2C:8A:72:B3:0B:A4@wlan1: disconnected, extensive data loss
10:57:37 wireless,info 00:73:E0:DB:8E:81@wlan1: connected
11:00:42 wireless,info 2C:8A:72:B3:0B:A4@wlan1: connected
11:02:38 wireless,info 2C:8A:72:B3:0B:A4@wlan1: disconnected, received deauth: sending station leaving (3)
11:07:51 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
11:07:54 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
11:07:55 wireless,info 48:43:7C:8B:04:17@wlan1: connected
11:15:44 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
11:16:01 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
11:19:11 wireless,info 00:73:E0:DB:8E:81@wlan1: disconnected, registered to other device in network
11:20:42 wireless,info C0:F2:FB:E8:34:DB@wlan1: connected
11:23:15 wireless,info C0:F2:FB:E8:34:DB@wlan1: disconnected, extensive data loss
11:23:43 wireless,info wlan1: data from unknown device C0:F2:FB:E8:34:DB, sent deauth
11:27:36 wireless,info 20:6E:9C:6C:58:BC@wlan1: connected
11:27:37 wireless,info 20:6E:9C:6C:58:BC@wlan1: disconnected, received disassoc: unspecified (1)
11:33:54 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
11:33:54 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, received disassoc: unspecified (1)
11:37:58 wireless,info 38:0B:40:5E:AC:A4@wlan1: connected
11:37:58 wireless,info 38:0B:40:5E:AC:A4@wlan1: disconnected, received disassoc: sending station leaving (8)
11:38:44 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
11:38:58 wireless,info 38:0B:40:5E:AC:A4@wlan1: connected
11:39:28 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, received disassoc: unspecified (1)
11:40:26 wireless,info 38:0B:40:5E:AC:A4@wlan1: disconnected, received disassoc: sending station leaving (8)
11:49:55 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
11:49:55 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, received disassoc: unspecified (1)
11:59:56 wireless,info 48:43:7C:8B:04:17@wlan1: connected
12:03:38 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
12:03:39 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
12:03:53 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:05:00 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:05:03 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:05:03 wireless,info wlan1: data from unknown device F0:27:65:DA:1F:EC, sent deauth
12:05:57 wireless,info 48:43:7C:8B:04:17@wlan1: connected
12:07:14 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:07:17 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:07:17 wireless,info wlan1: data from unknown device F0:27:65:DA:1F:EC, sent deauth
12:08:37 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
12:08:40 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:08:44 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:08:44 wireless,info wlan1: data from unknown device F0:27:65:DA:1F:EC, sent deauth
12:10:27 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:10:30 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:11:51 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:11:54 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:14:06 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:14:09 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:16:40 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:16:43 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:16:43 wireless,info wlan1: data from unknown device F0:27:65:DA:1F:EC, sent deauth
12:18:32 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:18:35 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:18:35 wireless,info wlan1: data from unknown device F0:27:65:DA:1F:EC, sent deauth
12:20:39 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:20:41 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:21:44 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:21:47 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:21:47 wireless,info wlan1: data from unknown device F0:27:65:DA:1F:EC, sent deauth
12:22:02 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:22:04 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:22:04 wireless,info wlan1: data from unknown device F0:27:65:DA:1F:EC, sent deauth
12:22:27 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
12:29:03 wireless,info 00:EB:2D:6B:C7:33@wlan1: connected
12:43:52 wireless,info 48:43:7C:8B:04:17@wlan1: connected
12:47:38 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
12:50:28 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
12:50:28 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, received disassoc: unspecified (1)
12:51:24 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
12:55:29 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
12:55:29 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, received disassoc: unspecified (1)
13:02:24 wireless,info AC:36:13:B0:81:03@wlan1: connected
13:04:31 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
13:05:38 wireless,info AC:36:13:B0:81:03@wlan1: connected
13:07:15 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
13:07:15 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, received disassoc: unspecified (1)
13:08:50 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
13:08:53 wireless,info AC:36:13:B0:81:03@wlan1: connected
13:08:53 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
13:09:17 wireless,info AC:36:13:B0:81:03@wlan1: connected
13:10:23 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
13:10:27 wireless,info AC:36:13:B0:81:03@wlan1: connected
13:11:35 wireless,info 20:6E:9C:B3:86:3D@wlan1: connected
13:11:37 wireless,info 20:6E:9C:B3:86:3D@wlan1: disconnected, received disassoc: sending station leaving (8)
13:12:43 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
13:13:13 wireless,info 00:EB:2D:6B:C7:33@wlan1: disconnected, received disassoc: sending station leaving (8)
13:13:34 wireless,info AC:36:13:B0:81:03@wlan1: connected
13:14:51 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
13:14:51 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, received disassoc: unspecified (1)
13:16:23 wireless,info 20:6E:9C:B3:86:3D@wlan1: connected
13:16:23 wireless,info 20:6E:9C:B3:86:3D@wlan1: disconnected, received disassoc: sending station leaving (8)
13:16:23 wireless,info wlan1: data from unknown device 20:6E:9C:B3:86:3D, sent deauth
13:17:16 wireless,info 20:6E:9C:B3:86:3D@wlan1: connected
13:18:27 wireless,info 20:6E:9C:B3:86:3D@wlan1: disconnected, received disassoc: sending station leaving (8)
13:22:39 wireless,info 84:38:38:17:C4:B7@wlan1: connected
13:22:40 wireless,info 84:38:38:17:C4:B7@wlan1: disconnected, received disassoc: sending station leaving (8)
13:23:32 wireless,info 48:43:7C:8B:04:17@wlan1: connected
13:24:31 wireless,info 18:AF:61:D4:CF:64@wlan1: connected
13:29:12 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
13:30:07 wireless,info AC:36:13:B0:81:03@wlan1: connected
13:31:21 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
13:34:09 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
13:35:29 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
13:35:29 wireless,info 48:43:7C:8B:04:17@wlan1: connected
13:35:30 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
13:35:30 wireless,info 48:43:7C:8B:04:17@wlan1: connected
13:37:08 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
13:37:10 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
13:37:10 wireless,info 48:43:7C:8B:04:17@wlan1: connected
13:37:10 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
13:37:11 wireless,info 48:43:7C:8B:04:17@wlan1: connected
13:38:51 wireless,info 18:AF:61:D4:CF:64@wlan1: disconnected, extensive data loss
13:39:22 wireless,info wlan1: data from unknown device 18:AF:61:D4:CF:64, sent deauth
13:42:06 wireless,info 84:38:38:17:C4:B7@wlan1: connected
13:44:13 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
13:44:14 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
13:44:18 wireless,info 84:38:38:17:C4:B7@wlan1: disconnected, received disassoc: sending station leaving (8)
13:44:23 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
13:48:59 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
13:49:21 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
13:49:21 wireless,info 48:43:7C:8B:04:17@wlan1: connected
13:49:21 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
13:50:10 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
13:51:01 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
13:51:01 wireless,info 48:43:7C:8B:04:17@wlan1: connected
13:51:01 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
13:51:02 wireless,info 48:43:7C:8B:04:17@wlan1: connected
13:52:37 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
13:56:01 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
13:56:02 wireless,info 48:43:7C:8B:04:17@wlan1: connected
13:56:49 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:00:31 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:00:32 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:02:17 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:03:42 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:03:42 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:03:42 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
14:04:30 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:06:01 wireless,info 20:6E:9C:B3:86:3D@wlan1: connected
14:08:23 wireless,info 20:6E:9C:B3:86:3D@wlan1: disconnected, received disassoc: sending station leaving (8)
14:09:31 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:09:32 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:09:57 wireless,info 20:6E:9C:B3:86:3D@wlan1: connected
14:10:27 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:11:12 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:11:12 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:11:12 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
14:12:08 wireless,info 20:6E:9C:B3:86:3D@wlan1: disconnected, received disassoc: sending station leaving (8)
14:12:49 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:15:34 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:15:35 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:18:08 wireless,info 20:6E:9C:B3:86:3D@wlan1: connected
14:18:08 wireless,info 20:6E:9C:B3:86:3D@wlan1: disconnected, received disassoc: sending station leaving (8)
14:18:45 wireless,info 20:6E:9C:B3:86:3D@wlan1: connected
14:19:23 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:20:53 wireless,info 20:6E:9C:B3:86:3D@wlan1: disconnected, received disassoc: sending station leaving (8)
14:21:45 wireless,info 00:EB:2D:6B:C7:33@wlan1: connected
14:21:50 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
14:22:23 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:22:23 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:23:40 wireless,info 00:EB:2D:6B:C7:33@wlan1: disconnected, received disassoc: sending station leaving (8)
14:25:23 wireless,info 1C:4B:D6:74:42:D2@wlan1: connected
14:25:37 wireless,info 20:6E:9C:6C:58:BC@wlan1: connected
14:25:39 wireless,info 20:6E:9C:6C:58:BC@wlan1: disconnected, received disassoc: unspecified (1)
14:25:40 wireless,info 1C:4B:D6:74:42:D2@wlan1: disconnected, received deauth: unspecified (1)
14:25:40 wireless,info 1C:4B:D6:74:42:D2@wlan1: connected
14:26:19 wireless,info 20:6E:9C:B3:86:3D@wlan1: connected
14:26:19 wireless,info 20:6E:9C:B3:86:3D@wlan1: disconnected, received disassoc: sending station leaving (8)
14:29:20 wireless,info 1C:4B:D6:74:42:D2@wlan1: disconnected, received deauth: unspecified (1)
14:29:20 wireless,info 1C:4B:D6:74:42:D2@wlan1: connected
14:32:54 wireless,info 1C:4B:D6:74:42:D2@wlan1: disconnected, received deauth: unspecified (1)
14:32:55 wireless,info wlan1: data from unknown device 1C:4B:D6:74:42:D2, sent deauth
14:33:03 wireless,info 1C:4B:D6:74:42:D2@wlan1: connected
14:33:31 wireless,info 1C:4B:D6:74:42:D2@wlan1: disconnected, received deauth: unspecified (1)
14:33:33 wireless,info 1C:4B:D6:74:42:D2@wlan1: connected
14:34:08 wireless,info 1C:4B:D6:74:42:D2@wlan1: reassociating
14:34:08 wireless,info 1C:4B:D6:74:42:D2@wlan1: disconnected, ok
14:34:08 wireless,info 1C:4B:D6:74:42:D2@wlan1: connected
14:34:27 wireless,info 84:38:38:17:C4:B7@wlan1: connected
14:34:33 wireless,info 84:38:38:17:C4:B7@wlan1: disconnected, received disassoc: sending station leaving (8)
14:35:01 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:35:03 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:38:11 wireless,info 84:38:38:17:C4:B7@wlan1: connected
14:38:16 wireless,info 84:38:38:17:C4:B7@wlan1: disconnected, received disassoc: sending station leaving (8)
14:41:48 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:48:18 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:48:41 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:48:41 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:48:41 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
14:49:14 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:49:17 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:49:26 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:49:27 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:52:23 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:52:23 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:52:27 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:53:05 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:53:50 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:53:51 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:55:27 wireless,info 1C:4B:D6:74:42:D2@wlan1: disconnected, extensive data loss
14:57:23 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
14:57:50 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
14:57:50 wireless,info 48:43:7C:8B:04:17@wlan1: connected
14:57:50 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
14:57:51 wireless,info 48:43:7C:8B:04:17@wlan1: connected
15:28:24 wireless,info 38:0B:40:5E:AC:A4@wlan1: connected
15:29:11 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
15:29:14 wireless,info 38:0B:40:5E:AC:A4@wlan1: disconnected, extensive data loss
15:29:31 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
15:29:31 wireless,info 48:43:7C:8B:04:17@wlan1: connected
15:29:31 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
15:39:15 wireless,info 38:0B:40:5E:AC:A4@wlan1: connected
15:40:57 wireless,info 38:0B:40:5E:AC:A4@wlan1: disconnected, extensive data loss
15:41:36 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
15:42:15 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
15:42:15 wireless,info 48:43:7C:8B:04:17@wlan1: connected
15:44:58 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
15:45:15 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
15:45:15 wireless,info 48:43:7C:8B:04:17@wlan1: connected
15:48:38 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
15:49:00 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
15:49:00 wireless,info 48:43:7C:8B:04:17@wlan1: connected
15:51:46 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
15:51:52 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
15:58:28 wireless,info 48:43:7C:8B:04:17@wlan1: connected
16:00:02 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
16:00:43 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
16:00:43 wireless,info 48:43:7C:8B:04:17@wlan1: connected
16:00:43 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
16:00:44 wireless,info 48:43:7C:8B:04:17@wlan1: connected
16:01:53 wireless,info C0:F2:FB:E8:34:DB@wlan1: connected
16:01:54 wireless,info C0:F2:FB:E8:34:DB@wlan1: disconnected, received disassoc: sending station leaving (8)
16:01:59 wireless,info F8:84:F2:7A:3C:61@wlan1: connected
16:02:11 wireless,info C0:F2:FB:E8:34:DB@wlan1: connected
16:02:16 wireless,info F8:84:F2:7A:3C:61@wlan1: disconnected, registered to other device in network
16:02:40 wireless,info C0:F2:FB:E8:34:DB@wlan1: disconnected, received disassoc: sending station leaving (8)
16:08:08 wireless,info 20:6E:9C:B3:86:3D@wlan1: connected
16:10:27 wireless,info 20:6E:9C:B3:86:3D@wlan1: disconnected, received disassoc: sending station leaving (8)
16:20:06 wireless,info 78:92:3E:BC:E6:A4@wlan1: disconnected, extensive data loss
16:20:16 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
16:21:59 wireless,info 78:92:3E:BC:E6:A4@wlan1: disconnected, extensive data loss
16:22:01 wireless,info wlan1: data from unknown device 78:92:3E:BC:E6:A4, sent deauth
16:22:01 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
16:23:13 wireless,info 78:92:3E:BC:E6:A4@wlan1: disconnected, extensive data loss
16:23:15 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
16:23:39 wireless,info 78:92:3E:BC:E6:A4@wlan1: disconnected, registered to other device in network
16:23:53 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
16:23:53 wireless,info 78:92:3E:BC:E6:A4@wlan1: disconnected, received disassoc: unspecified (1)
16:28:59 wireless,info 18:AF:61:D4:CF:64@wlan1: connected
16:30:56 wireless,info 18:AF:61:D4:CF:64@wlan1: disconnected, extensive data loss
16:30:59 wireless,info wlan1: data from unknown device 18:AF:61:D4:CF:64, sent deauth
16:31:08 wireless,info wlan1: data from unknown device 18:AF:61:D4:CF:64, sent deauth
16:31:08 wireless,info 18:AF:61:D4:CF:64@wlan1: connected
16:31:08 wireless,info 18:AF:61:D4:CF:64@wlan1: disconnected, received deauth: sending station leaving (3)
16:31:50 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
16:36:12 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
16:36:13 wireless,info 48:43:7C:8B:04:17@wlan1: connected
16:39:38 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
16:40:42 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
16:40:43 wireless,info 48:43:7C:8B:04:17@wlan1: connected
16:43:07 system,info,account user admin logged in from 172.18.255.1 via winbox
16:47:25 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
16:48:23 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
16:48:23 wireless,info 48:43:7C:8B:04:17@wlan1: connected
16:48:23 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
16:48:51 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
16:49:42 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
16:49:43 wireless,info 48:43:7C:8B:04:17@wlan1: connected
16:52:29 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
16:56:35 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
16:56:36 wireless,info 48:43:7C:8B:04:17@wlan1: connected
16:57:27 wireless,info 20:6E:9C:6C:58:BC@wlan1: connected
16:57:29 wireless,info 20:6E:9C:6C:58:BC@wlan1: disconnected, received disassoc: unspecified (1)
16:58:21 wireless,info 20:6E:9C:6C:58:BC@wlan1: connected
16:58:22 wireless,info 20:6E:9C:6C:58:BC@wlan1: disconnected, received disassoc: unspecified (1)
16:59:23 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
16:59:46 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
16:59:46 wireless,info 48:43:7C:8B:04:17@wlan1: connected
16:59:46 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received deauth: sending station leaving (3)
16:59:47 wireless,info 48:43:7C:8B:04:17@wlan1: connected
17:02:47 wireless,info D0:4F:7E:47:E2:90@wlan1: disconnected, extensive data loss
17:02:49 wireless,info wlan1: data from unknown device D0:4F:7E:47:E2:90, sent deauth
17:03:12 wireless,info wlan1: data from unknown device D0:4F:7E:47:E2:90, sent deauth
17:03:37 wireless,info AC:36:13:B0:81:03@wlan1: connected
17:04:17 wireless,info 20:6E:9C:6C:58:BC@wlan1: connected
17:04:37 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
17:05:01 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
17:05:25 system,info,account user admin logged out from 172.18.255.1 via winbox
17:06:24 wireless,info 20:6E:9C:6C:58:BC@wlan1: disconnected, received disassoc: unspecified (1)
17:06:54 wireless,info AC:36:13:B0:81:03@wlan1: connected
17:07:05 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
17:07:42 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
17:07:42 wireless,info 48:43:7C:8B:04:17@wlan1: connected
17:09:29 wireless,info 20:6E:9C:6C:58:BC@wlan1: connected
17:09:31 wireless,info 20:6E:9C:6C:58:BC@wlan1: disconnected, received disassoc: unspecified (1)
17:14:25 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
17:16:31 wireless,info 20:6E:9C:6C:58:BC@wlan1: connected
17:16:32 wireless,info 20:6E:9C:6C:58:BC@wlan1: disconnected, received disassoc: unspecified (1)
17:17:06 wireless,info 20:6E:9C:6C:58:BC@wlan1: connected
17:19:13 wireless,info 20:6E:9C:6C:58:BC@wlan1: disconnected, received disassoc: unspecified (1)
17:24:04 wireless,info 14:A3:64:EE:A4:41@wlan1: connected
17:24:04 wireless,info 14:A3:64:EE:A4:41@wlan1: disconnected, received disassoc: unspecified (1)
17:24:06 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
17:25:42 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
17:25:43 wireless,info 48:43:7C:8B:04:17@wlan1: connected
17:26:56 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
17:26:56 wireless,info wlan1: data from unknown device F0:27:65:DA:1F:EC, sent deauth
17:28:32 wireless,info AC:36:13:B0:81:03@wlan1: connected
17:28:42 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
17:38:07 wireless,info AC:36:13:B0:81:03@wlan1: connected
17:39:40 wireless,info 18:AF:61:D4:CF:64@wlan1: connected
17:40:24 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
17:40:30 wireless,info 18:AF:61:D4:CF:64@wlan1: disconnected, extensive data loss
17:40:37 wireless,info AC:36:13:B0:81:03@wlan1: connected
17:41:11 wireless,info wlan1: data from unknown device 18:AF:61:D4:CF:64, sent deauth
17:41:12 wireless,info 18:AF:61:D4:CF:64@wlan1: connected
17:41:12 wireless,info 18:AF:61:D4:CF:64@wlan1: disconnected, received deauth: sending station leaving (3)
17:42:01 wireless,info 18:AF:61:D4:CF:64@wlan1: disconnected, extensive data loss
17:42:05 wireless,info wlan1: data from unknown device 18:AF:61:D4:CF:64, sent deauth
17:42:44 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
17:47:08 wireless,info AC:36:13:B0:81:03@wlan1: connected
17:49:14 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
17:51:19 wireless,info wlan1: data from unknown device 18:AF:61:D4:CF:64, sent deauth
17:51:56 wireless,info 18:AF:61:D4:CF:64@wlan1: connected
17:53:18 wireless,info 2C:8A:72:B3:0B:A4@wlan1: connected
17:53:33 wireless,info 18:AF:61:D4:CF:64@wlan1: disconnected, extensive data loss
17:53:40 wireless,info wlan1: data from unknown device 18:AF:61:D4:CF:64, sent deauth
17:53:40 wireless,info 18:AF:61:D4:CF:64@wlan1: connected
17:53:41 wireless,info 18:AF:61:D4:CF:64@wlan1: disconnected, received deauth: sending station leaving (3)
18:01:04 wireless,info F8:84:F2:22:41:F4@wlan1: connected
18:01:04 wireless,info F8:84:F2:22:41:F4@wlan1: disconnected, received disassoc: sending station leaving (8)
18:01:46 wireless,info F8:84:F2:22:41:F4@wlan1: connected
18:01:46 wireless,info F8:84:F2:22:41:F4@wlan1: disconnected, received disassoc: sending station leaving (8)
18:13:42 wireless,info F8:84:F2:7A:3C:61@wlan1: connected
18:14:56 wireless,info F8:84:F2:7A:3C:61@wlan1: disconnected, received disassoc: sending station leaving (8)
18:27:03 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
18:28:16 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
18:28:18 wireless,info 78:92:3E:BC:E6:A4@wlan1: reassociating
18:28:18 wireless,info 78:92:3E:BC:E6:A4@wlan1: disconnected, ok
18:28:18 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
18:28:40 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
18:28:52 wireless,info 78:92:3E:BC:E6:A4@wlan1: reassociating
18:28:52 wireless,info 78:92:3E:BC:E6:A4@wlan1: disconnected, ok
18:28:52 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
18:29:30 wireless,info 78:92:3E:BC:E6:A4@wlan1: reassociating
18:29:30 wireless,info 78:92:3E:BC:E6:A4@wlan1: disconnected, ok
18:29:30 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
18:32:22 wireless,info 48:43:7C:8B:04:17@wlan1: connected
18:32:38 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, received disassoc: sending station leaving (8)
18:37:14 wireless,info 2C:8A:72:B3:0B:A4@wlan1: disconnected, disabling
18:37:14 wireless,info 44:33:4C:C9:E9:0F@wlan1: disconnected, disabling
18:37:14 wireless,info 78:92:3E:BC:E6:A4@wlan1: disconnected, disabling
18:37:22 wireless,info wlan1: data from unknown device 2C:8A:72:B3:0B:A4, sent deauth
18:37:34 wireless,info 44:33:4C:C9:E9:0F@wlan1: connected
18:37:52 wireless,info wlan1: data from unknown device 78:92:3E:BC:E6:A4, sent deauth
18:38:22 wireless,info wlan1: data from unknown device 78:92:3E:BC:E6:A4, sent deauth
18:38:47 wireless,info AC:36:13:B0:81:03@wlan1: connected
18:38:47 wireless,info AC:36:13:B0:81:03@wlan1: disconnected, received disassoc: unspecified (1)
18:38:52 wireless,info wlan1: data from unknown device 78:92:3E:BC:E6:A4, sent deauth
18:39:22 wireless,info AC:36:13:B0:81:03@wlan1: connected
18:39:22 wireless,info wlan1: data from unknown device 78:92:3E:BC:E6:A4, sent deauth
18:39:42 wireless,info wlan1: data from unknown device 78:92:3E:BC:E6:A4, sent deauth
18:39:42 wireless,info 78:92:3E:BC:E6:A4@wlan1: connected
18:47:51 wireless,info 48:43:7C:8B:04:17@wlan1: connected
18:49:38 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
18:49:41 wireless,info F0:27:65:DA:1F:EC@wlan1: disconnected, received disassoc: sending station leaving (8)
18:50:08 wireless,info 48:43:7C:8B:04:17@wlan1: disconnected, extensive data loss
18:50:15 wireless,info wlan1: data from unknown device 48:43:7C:8B:04:17, sent deauth
18:50:16 wireless,info 48:43:7C:8B:04:17@wlan1: connected
18:52:58 wireless,info 18:AF:61:D4:CF:64@wlan1: connected
18:53:18 wireless,info F0:27:65:DA:1F:EC@wlan1: connected
Based on my DHCP-Server or MAC-Vendor the affected MACs are:
  • 1 WindowsPhone
  • 1 PC
  • 4 Apple devices
  • 13 Android devices
  • 4 unknown
The problem still exists, even in 6.25.
A solution would be nice, because my clients are beginning to go crazy.
THX.
please make a support output file when you have this problem and email it to support@mikrotik.com
hi uldis… thank you for finally taking a note of this problem.
i hope the solution you work out will be applicable across the entire Mikrotik platform.
Don’t mean to resurrect an old topic but I have a possible solution.
I recently bought RB915G-2HnD and was facing the same problems as the OP. IOS devices keep getting disconnected after a few minutes of going into standby.
The logs show that [macaddress]@wlan1: disconnected, extensive data loss.
After sometime, the IOS device, not knowing that it has been disconnected, tries to send some data and instead get sent a deauth from the router.
The log will show "data from unknown device [macaddress], send deauth.
On my IOS device, I will see that the wifi icon disappears, then reconnects.
Then the cycle repeats.
I tried all the solutions suggested in these forums, to no avail.
There is no way to disable the ‘disconnect’ mechanism in routerOS.
There must be some traffic being generated by the router to the IOS device every so often, to which the IOS device does not respond to once it goes into standy (wifi power save) mode, and this then triggers the hw retries etc, which eventually leads to the router disconnecting the client due to extensive data loss.
This ‘traffic’ seem the the the keepalive-frames.
Paradoxically, setting the keepalive-frames to disabled has now allowed my IOS devices to stay connected to the router for hours, even without any activity, with the default hw retries, disconnect timeout and on fail retry time settings. No more disconnects.
/interface wireless
set 0 keepalive-frames=disabled
Have the same problem (RB951Ui-2HND)
Windows 7
Android mobile
So I have been using the “keepalive-frames=disabled” setting for 3 weeks, and while my ios devices are able to stay connected for longer periods of times, sometimes hours, I still get the “disconnected due to extensive data loss” messages.
Same issue, using the bugfix or current release.
I have the exact same problems on the 2 RB951G-2HnD as well as my new HAP AC (on 2.4 ghz), both being used in different locations.
Also, throughput is dismal, high rez content streamed to my google chromecast 1 (2.4 ghz) just stutters, practically unplayable.
This is in comparison to other consumer grade routers that i used, on the same channels (channel 6, or 11, as channel 1 in my area has some other access points on it), ie:
  1. Asus RT N16
  2. Asus RT AC66U
  3. Dlink DIR-615
  4. Dlink DAP 2660 (Enterprise grade)
All these modems play the same content with the same settings, same channel, flawlessly.
Much research yielded nothing, till I came across this post by taloot in this thread:
http://forum.mikrotik.com/viewtopic.php?t=60636&start=50
He mentions that the RB751U-2HnD is only workable on frequencies 2412-2427, channel 1.
Thinking that if at all, performance would be worse using channel 1 because there are other access points on it, I was surprised, almost shocked, that once I set the frequency to channel 1, performance spiked, huge difference, now it performs as expected, ie. wonderfully.
This is even with default setting for everything, except channel and security profiles. Even with the keep alive frames turned on.
Its been working well for the past 1 week.
Taloot says it is a hardware design bug, but the routerboards listed seem to use different atheros 2.4 ghz chips, however, they are all displayed as the Atheros AR9300 chip in router os.
Maybe it is a driver issue?
Basically, changing to channel 1 seems to have solved all my problems for the past 1 week.
