Wi-Fi speed issues on hAP AC Lite
Hey,
have anyone managed to sort this issue?
Im experiencing the same thing, Rx and Tx speed drop dramastically when using wifi’s, but the speed is great when using cabel connection.
I have tested this on serveral devices using wifi, throughput is the same on all of them, never gets faster than 1,8 Mbp/s
Br.
The same issue. And also 2.4 GHz wireless download speed is always not higher than 25 Mbit/s whereas ZyXel Keenetic Lite III gives me ~45 Mbit/s.
(only speaking of 5ghz performance below, we just about dont test for 2.4 bc of interference):
I think this is either a HW issue (wireless chipsets used), or something in the ROS driver, but we contently see MUCH worse wifi speeds on mobile devices when comparing MT (wAP AC, hAP AC, hAP AC Lite) VS ubiquiti AC-APs or many different consumer AC wifi - routers (the higher end consumer AC routers, which are usually trash, but have solid wireless throughput speeds )
we are very experienced in wifi and almost solely use MT / ROS for the past 10 years (100s+ of MTs currently deployed), so am fully aware of frequency / interference issues + configuration (every time and every physical place we have done this comparison, the routers are in the same environment, usually ~8ft apart from each other).
Now on laptop or PC/mac products the speeds for MT APs are MUCH better (but still trail all other wifi products considerably at peek throughput).
We really need MT to address or respond to this issue as we often deploy wifi to large apartments (ie 1 AP per unit), and try our hardest to stick to all MT / ROS products, for the obvious Superior LAN/networking ability of ROS. (its just this sub-par wifi performance MUST be addressed).
Random example:
1g fiber ISP/uplink: (speeds are device download , same SW, same room, only AP being tested is powered up)
wAP AC (def. config, 6.40.5) -
iphone 7+ 5ghz (ac, 3chain): 120-260mbit throughput, peak: ~280m
w7 laptop, USB asus 5ghz AC (3x chain): 350-400m throughput, peak: ~450mbit
ubnt AC-AP-Pro -
iphone 7+ 5ghz (ac, 3chain): 300-380mbit throughput, peak: ~500m
w7 laptop, USB asus 5ghz AC (3x chain): 500-600m throughput, peak: ~735mbit
Netgear nighthawk x4s (4x chain) -
.. similar to ubnt AP speeds above.
These difference may seem pety, but they are not- as they scale down proportionally when there is increased interference or noise, and additionally scale down when the MT device only has fewer chains, (ie 1x chain w the hAP ac lite, you can just about cut the numbers in 1/3) .
i can spend the time providing screen shots, but this is not a configuration or environment issue, its a HW or ROS or ROS driver issue (which really needs a reply to or addressing).
If this is the max speeds we should expect the MTs to be capable of (bc of HW or other issues), fine, not a problem, but please let us know this so we stop wasting time trying to ID the issue or test for the issue.
(maybe the slower AC performance is just a trade off to running the FAR Superior and powerful ROS , OS - no problem, just let us know pls so we can plan accordingly)
thanks.
I just happened to setup my hAP AC Lite over the weekend and did a few speedtests on 2.4Ghz. Here are my results.
Router: Mikrotik RB750Gr3 6.41
AP: Mikrotik hAP AC Lite 6.41
ISP: Telekom Malaysia UniFi 100mbps FTTH (100 down/50 up)
Toshiba Portege z930 2012. 2.4Ghz, single chain, 40Mhz channel width, SGI (short guard interval). Link speed: 150mbps.
MacBook Pro Retina 15" 2013. 2.4Ghz, dual chain, 20Mhz channel width, SGI. Link speed: 144mbps.
Can’t get my iPhone 6s to go any higher than 92mbps.
iPhone 6s. 2.4Ghz, dual chain, 20Mhz channel width, SGI. Link speed: 144mbps.
Radio environment.
Notes:
hAP AC Lite is 100mbps ethernet ports only. In order to go above 100mbps, I bonded 2 ports to my RB750Gr3.
thanks soonwai, that is useful info and very detailed, but to be clear my speed issues/problems and testing are all on 5ghz.
Ive never benchmarked 2ghz much as in most places its not very usable (for higher speeds).
Can you provide some 5ghz speeds tests (the ac lite supports 5g AC but 1 chain/stream , which will still be useful data)?
also, did you recently purchase your ac lite? (im wondering if there have been HW or other upgrades done possibly, as ive never seen over 40-60mbit on ac lite @ 2ghz (but again, 2ghz is horrible spectrum wise))
thanks
AP: Mikrotik WAP AC Lite 6.41
ISP: (100 down/100 up)
the same issue on 2.4 GHz speed is always not higher than download:30 Mbit/s upload:60 Mbit/s
Client: MacBook Pro 2017/2013
5 GHz 1 chain download:57 Mbit/s upload:63 Mbit/s
I’m getting the same sort of problems, even just pinging the router with a single client gives me many ping response times >10ms, why?
All of the above posters seem to have in common that the half speed only happens on 2GHz.
Please test 5GHz also.
Also try to disable one of the chains and see what happens then.
I get the same thing on 5ghz only, with no other wifi nearby interfering
all working great when I upgraded all my wAP ac to version 6.41.
When I also upgraded the Firmware to 6.41 I could not get speeds more than 12Mbps on 2.4GHz (My laptop has only 2.4).
When I downgraded to 6.39 (Bugfix) it all came to life. even though that Routerboard firmware is 6.41.
hope this helps find solution to this issue as I I have a lot of Mikrotik in the house and I do not want to have any bugs or vulnerabilities so I always upgrade.
I have an RB3100 and it seems that the issue is only affecting the WiFi.
Im not sure how much real world proof you all need, but i have tested every consumer type (builtin wifi) device MT makes with AC (and have pre-orders in for newly announced mt APs) and the performance or noise rejection (or im not sure what) = bandwidth really poor at AC 3x or 2x chains. Ive tested many “generic” consumer AC APs (netgear, TPlink, linksys) , side by side with my own MT ACs at clients locations (or my own impromptu tests on site) and its never even close / comparable. All other devices will jump right up to 250, 300, even 400mbit down, the MTs will usually slowly crawl up to ~100-150 (or even sometime jump to ~150-200m), but its never consistent like other APs , and never close to the max numbers ill see on those.
Note: i am most often testing with an iphone 7 or iphone X, to local ISPs speed-test server (w many test repeats, both APs on same Freq, same channel width + center channel) or sometimes testing via a WIN PC with USB AC adapter.
Im also very surprised that the newly announced MT ACs are 2 chain and not 3 chain (esp. at this point in the AC life cycle), I love MT and will never use anything else bc of its power/flex at routing, but this is a really concerning issue going on 12+ months now.
I have a 600+ unit (res) complex coming up for wifi and want to stick to all MT throughout as ive done on others, but am very worried as users want wifi speed on their consuemr devices. I KNOW i can deliver that wifi speed with UBNT APs and MT routing, but want so badly to go all MT (only issue is this 5g AC performance).
Frankly, the same issue may exist on 2g MT as well, but i refuse to do any testing / draw any conclusions from that noisy band.
I just wish more attention would be paid to this isssue by MT, they clearly want to be in this specific market.
2 chain makes sense, because nearly all of the consumer devices have only 1 or 2 chains.
Also new MT ACs (cAP AC) uses IPQ4018 IC which is a really powerful compact IC (AC Wave 2 / MU-MIMO), they just need to utilize this power.
https://www.qualcomm.com/products/ipq4018
On 6.40.5 wifi works with no problems.
Thanks for reply / info-
Is this on a Hap AC (if so was the RB purchased recently)? Also, I’m assuming that this is via a three chain desktop/laptop AC adapter/client , right? ( as those are the down speeds I do sometimes see on mt , 300-450mbit). However with the same equipment on a ubiquity AC pro (or even low end consumer 3chainAC) , same test client devices consistently shows 550 to 750 Mbit on the same test real throughput.
Additionally, my main issue in raising this thread, isn’t so much about the occasional RB Max throughput, it’s more about the throughput consistency especially on mobile devices (even with back to back tests on Many various mobile devices I have tested on various mt ac AP models). Ie sometimes I will see 200 250mbit, but often it’s 60 to 160 (w ap showing 3s SGI , strong rssi).
On other (non mt, including low price consumer) three chain AC APs, there is just about perfect consistency- the speed or iperf tests immediately jumps up to the maximum speed and stays there , on the mt APs , it will often slowly build to a decent speed (ie start at 60m down and by end of test will be at 180m , as an example, on mobile).
As I’ve stated before, I clearly understand and respect the power and flexibility of routerOS versus these other APs, but please keep in mind in all my many tests I am absolutely controlling for these features (ie on ros only a straight bridge w fastpath enabled and being used), as well as frequency and band.
Tks
jo2jo - where are you based? would love chat offline about this…
Would be nice if people would
  1. not talk so loosely about wildly different WiFi models. After all this thread started specifically about the hAP AC Lite and an asymmetric download issue.
  2. provide client and distance information. Are you using an AC client and what type, e.g. phone, tablet, laptop, MacBook Pro or any other high end laptop, PC (if it is a very old one, you should mention it), USB adapter, PCIe adapter, 2x2, 3x3, 4x4, etc. Are you any further than or different from 6m or 20ft line of sight from the WiFi router?
If you are going to give any specific data or feedback of any kind, it would help to mention the model regardless, otherwise there may be rampant confusion when so many others keep talking about other models. There are complaints about other (newer) WiFi products, with only slightly different names, yet they are built on wildly different hardware …
For example, is Boter’s post even about the hAP AC Lite?
I have done some tests on hAP ac lite, the results on 5G ac looks very good (can maintain at 89Mbps), for details, please take at the following thread:
http://forum.mikrotik.com/t/hap-ac-2-problems-extremely-poor-performance-found-in-2-4g-and-5g-wifi/118063/1
YH
I have the same problem on RB941-2nD
ISP roter wifi: Down: 100Mbps Up: 60Mbps
RB941-2nD wifi with latest firmware: Down:20Mbps Up.20Mbps
At the time of the test only my laptop is connected to wifi.
Is there any solution?
Sorry for gravedigging but this post is one of the top google results so I am going to post a solution for possible other users.
I have a the following system
> system routerboard print
       routerboard: yes
        board-name: hAP ac lite
             model: RB952Ui-5ac2nD
          revision: r2
     firmware-type: qca9531L
  factory-firmware: 6.44.5
  current-firmware: 6.45.9
  upgrade-firmware: 6.45.9
The 2.4 ghz is disabled. I have a 50/10 connection with internet and an homelab as well (connected to the AC via cable, 100 Mb).
I could get on the 5 ghz only around 25 Mbps and not more. It wasn’t bad, but neither great. After reading today (admittedly a bit late, as I have the system for more than 12 months) a bit, I tried to play conservatively and I improved the situation:
On the wireless interface the Band was set to 5ghzA (see https://en.wikipedia.org/wiki/IEEE_802.11a-1999 ). Now it is 5Ghz-A/N.
The Channel width is 20 Mhz (I tried 20/40 Mhz XX but didn’t bring improvements)
I set the country and I changed the base frequency (default 5180) randomly (picking allowed center frequencies from https://en.wikipedia.org/wiki/List_of_WLAN_channels#5_GHz_(802.11a/h/j/n/ac/ax)) and doing tests until the wifi “unblocked” itself. Now I can finally use the 50/10 and I can use well the 100 mbps internally with the homelab (though I was happy seeing 60 mbps and I didn’t test further).
Hope it helps (and yes, compared to some people my requirements are low. Some have surely more than 50/10 mbps and internal connections exceeding 1 gbps).
