Wi-fi without antenna
Hi! Did wifi will work only with miniPCI? I want try wifi but i dont have an antenna
yes, if you have a miniPCI wifi card, you must attach some kind of antenna, so that the miniPCI card is not damaged.
But how i can attach if i don’t have antenna? a simple wire or something like that?
In Latvian
Pat mazā rādiusā bez antenas neies ar pliku mini PCI karti neies man wifi?
The connectors are to small to attache a simple wire, and without any deeper knowledge you wouldn’t get teh impedance right anyway.
Sorry, you really must use an antenna, otherwise you will definitely damage your card within seconds(depending on output power).
nav svarīgi, ka jums nevajag lielu distanci, kartiņa nodegs bez antenas. šāda tipa antenu var dabūt par kādu latu! http://img.routerboard.com/pricelist/125_l.png
Skaidrs, baidijos jau ka tā būs. Kur tieši to antenu dabūt? Uz rīgo nedomāju braukt kādu laiku, pastām pasta pakalpojumi? protams tos es apmaksāju
pie mums nebūs lēti. kāda ir jūsu kartiņa precīzi? konektors ir mmcx, ufl vai kāds cits? var skatīties argus.lv
man ir abu veidu, vot paldies par argus ieteikumu, to varu dabut šurpu :slight_smile: jūsu cenas jau skatijso jā, kaut kad pirkšu korpusu 433ah platei :slight_smile:
Paldies par palīdzību
I can use any antenna with mmcx connector or just those who i can buy on mikrotik home page?
any antenna
Can i Use different miniPCI cards no RB433AH or the cards must be the same?
you can use different ones, no problem
in each slot can by diferent model and power?
yes!
