Wich Model do you recommend for a 80 users Network?
Hello Pals,
My first Topic here. I have some questions about the Mikrotik Hardware I need for this requirement, let me show you:
We advise on the computing aspect to some small businesses and manage their network. We are currently supporting an office (our client) to expand, as they open a new branch, for this obviously will require Internet service. The amount is 80 users and Internet use will be primarily for mail no more than that, (by the way, we add to this common usage that give users Youtube, Facebook and the like, perhaps to relax a bit) .
In a second instance, we might consider that in the medium term, say about 6 months, begin to use the Internet for tasks that use higher bandwidth, such as FTP for access to third parties where files will be moved (up and down) in size approx of 250 Mb.
In summary, we need a device that must:
  • Do Load balancing.
  • Do QoS.
  • Manage a 80 users network without any problem.
    I’ll thanks any advice about this.
Cheers!!
You would need to tell us what speed the internet connection is to the office, and how many wireless users if any. Your decision for which router you need depends on how many packets per second you need to process and how many firewall and QOS rules you want to add. Then you look at any other features you may need and your budget.
this information its important to establish the requirements
for a installation like that i think minimum a ccr1009 will be needed
