How can i use multiple routerboards in order to scan all 2.4Ghz channels at the same time without hopping? Can routerboard scan the entire band of 20 Mhz wider which overlaps? By example having three routerboard which would scan channels 1, 6 and 11 on >20Mhz, to capture the entire range of 2.4Ghz channels?
The idea is to not have channel hopping during the scan.
