can someone explain why this connections appear? and why?
got those 2 ips doing some wierd connections between them :X
How does your firewall look like?
add chain=icmp comment=“echo reply” icmp-options=0:0 protocol=icmp
add chain=icmp comment=“net unreachable” icmp-options=3:0 protocol=icmp
add chain=icmp comment=“host unreachable” icmp-options=3:1 protocol=icmp
add chain=icmp comment=“allow source quench” icmp-options=4:0 protocol=icmp
add chain=icmp comment=“allow echo request” icmp-options=8:0 protocol=icmp
add chain=icmp comment=“allow time exceed” icmp-options=11:0 protocol=icmp
add chain=icmp comment=“allow parameter bad” icmp-options=12:0 protocol=icmp
add action=drop chain=icmp comment=“deny all other types”
add chain=input comment=“deny all other types” disabled=yes protocol=icmp src-address=66.220.2.74
add action=drop chain=input comment=“drop ftp brute forcers” dst-port=21 protocol=tcp src-address-list=ftp_blacklist
add chain=output content=“530 Login incorrect” dst-limit=1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist address-list-timeout=3h chain=output content=“530 Login incorrect” protocol=tcp
add action=drop chain=input comment=“drop ssh brute forcers” dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=1w3d chain=input connection-state=new dst-port=22 protocol=tcp
src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp
src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp
src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp
add action=drop chain=forward comment=“drop ssh brute downstream” dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment="Port scanners to list " protocol=tcp
psd=21,3s,3,1
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“NMAP FIN Stealth scan” protocol=tcp
tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“SYN/FIN scan” protocol=tcp tcp-flags=
fin,syn
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“SYN/RST scan” protocol=tcp tcp-flags=
syn,rst
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“FIN/PSH/URG scan” protocol=tcp
tcp-flags=fin,psh,urg,!syn,!rst,!ack
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“ALL/ALL scan” protocol=tcp tcp-flags=
fin,syn,rst,psh,ack,urg
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“NMAP NULL scan” protocol=tcp tcp-flags=
!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment=“dropping port scanners” src-address-list=“port scanners”
add action=drop chain=forward comment=“dropping port scanners” src-address-list=“port scanners”
add chain=input comment=“Allow Established connections” connection-state=established
add chain=input in-interface=!ONI src-address=192.168.1.0/24
add chain=input in-interface=!BLU src-address=192.168.1.0/24
add chain=input in-interface=!BLU src-address=192.168.168.0/24
add chain=input in-interface=!ONI src-address=192.168.168.0/24
add action=drop chain=input comment=“Drop everything else”
add action=drop chain=forward comment=“drop invalid connections” connection-state=invalid
add chain=forward comment=“allow already established connections” connection-state=established
add chain=forward comment=“allow related connections” connection-state=related
add action=drop chain=forward comment=“Block Bogon IP addresses” src-address=0.0.0.0/8
add action=drop chain=forward dst-address=0.0.0.0/8
add action=drop chain=forward src-address=127.0.0.0/8
add action=drop chain=forward dst-address=127.0.0.0/8
add action=drop chain=forward src-address=224.0.0.0/3
add action=drop chain=forward dst-address=224.0.0.0/3
add action=jump chain=forward comment=“Make jumps to new chains” jump-target=tcp protocol=tcp
add action=jump chain=forward jump-target=udp protocol=udp
add action=jump chain=forward jump-target=icmp protocol=icmp
add action=drop chain=tcp comment=“deny TFTP” dst-port=69 protocol=tcp
add action=drop chain=tcp comment=“deny RPC portmapper” dst-port=111 protocol=tcp
add action=drop chain=tcp comment=“deny RPC portmapper” dst-port=135 protocol=tcp
add action=drop chain=tcp comment=“deny NBT” dst-port=137-139 protocol=tcp
add action=drop chain=tcp comment=“deny cifs” dst-port=445 protocol=tcp
add action=drop chain=tcp comment=“deny NFS” dst-port=2049 protocol=tcp
add action=drop chain=tcp comment=“deny NetBus” dst-port=12345-12346 protocol=tcp
add action=drop chain=tcp comment=“deny NetBus” dst-port=20034 protocol=tcp
add action=drop chain=tcp comment=“deny BackOriffice” dst-port=3133 protocol=tcp
add action=drop chain=tcp comment=“deny DHCP” dst-port=67-68 protocol=tcp
add action=drop chain=udp comment=“deny TFTP” dst-port=69 protocol=udp
add action=drop chain=udp comment=“deny PRC portmapper” dst-port=111 protocol=udp
add action=drop chain=udp comment=“deny PRC portmapper” dst-port=135 protocol=udp
add action=drop chain=udp comment=“deny NBT” dst-port=137-139 protocol=udp
add action=drop chain=udp comment=“deny NFS” dst-port=2049 protocol=udp
add action=drop chain=udp comment=“deny BackOriffice” dst-port=3133 protocol=udp
add action=drop chain=input comment=“Drop Invalid connections” connection-state=invalid
add action=tarpit chain=input connection-limit=3,32 protocol=tcp src-address-list=blocked-addr
add chain=forward disabled=yes protocol=ipv6
