I have a wierd problem with Winbox logging to one RB450G: Winbox hangs on connection attempt, showing “Retrieving preferences …”. After some time it reports “Router has been disconnected”.
I have checked and found many suggestions, all pointing to damaged plugin or something similar, but the reason must lie somewhere else. Here are the facts:
Chaniging Winbox version only generated the fault in a different phase of login.
Changing router OS from 4.11 to 5.4 did not change a thing.
Any version of Winbox on that very machine can login to 20 different other routers I have access to.
If I VPN to my company LAN, I am suddenly able to login to the router with very same Winbox(es) that did not work before.
If you connect via VPN and it works, but connect directly (presumabely from an external wan-derived IP) and it does not that would infer firewall interference of some sort. Is port 8291 allowed at your networks gateway?
No, everything i OK with 8291 port traffic.
I am able to connect from other locations to this router, and I am able to connect to other routers from the critical location. I am totally puzzled.
The big issue is (aside of the general scarry fact that this CAN be an issue), that I cannot connect to this router from customer’s main management server - which can normally connect to the rest of the 10 affiliate routers.
Let me throw in another fact: Looking at the router’s log during the attempt to connect from the critical site, I can see that I have connected and disconnected - just like everything was OK. It look s like the router is not aware that Winbox did not manage to get pass the “Loading preferences…” screen.
Yes, I tried. It did not help.
In fact, I tried to untick both “Previous session” and “Secure mode” (one by one), but it did not fix the problem. I tried a different version of Winbox too. The difference was that the older version gets stuck at loading preferences, while the newer version gets stuck on loading plugins.
Both versions work for ALL other routers always, and they work with the critical router if I re-route through a VPN to some other network.
Is there a way to debug that from router side, or should I dig into Wireshark to pinpoint the problem?
