WiFi 2 SSID with Different IP
Hello
I have one router mikrotik RB750R2 i want to fix this senario for one customer i Have one router from my profider with Dhcp 192.168.1.x and gateway 192.168.1.1
In mikrotik i have plug the provider in lan1 From lan 2 i have fix a DHCP 192.168.88.xx i put it in switch ubnt TS-5 PRO And from switch i go to AP UBNT to 4 Villas and i am ok with internet.
The customer they want to have a second SSID to Have a private network from Provider Router How i can pass it from mikrotik ? in all AP i can fix 4 SSID
Use VLANs internally in Mikrotik. Configure WiFi APs (real and/or virtual) with vlan-mode=use-tag and use different VLAN ids for different SSIDs. Then you can use different ether ports as access ports for those VLANs, thus making different SSIDs members of different LANs. Just make sure you don’t create bridge between the two LANs …
Besides using vlan, you may create a virtual AP with different IP address that you want. You have to create different IP pool for the newly created virtual AP with suitable routes and masquerade NAT.
YH
i need to have the pool of provider router not from mikrotik i fix one vlan to use it in wifi that i have now
and i want to pass the address pool from privider router via the mikrotik to have it in a new ssid in one of my AP in one villas
and the new ssid i want to have the pool of provider router not from my mikrotik
