Wifi 7 - MikroTik when???
Ordered a be lite as well and it is now with DHL so I should have it tomorrow. No sight of the BE media however.....
So my WiFI 6 APs still don't work. LETS JUMP RIGHT INTO WIFI7!
My wifi 6 APs are working great :slight_smile:
But my "pre-ordered" be3 has gotten another delay :wink:
I believe you will have better luck with new WiFi 7 devices :laughing:
At least new game - new luck.
Got my hAP BE Lite yesterday and realize that I now need to understad how to configure the new mld interface. Anyone who got a device who have tested this with multiple SSID and VLANS?
Tried to Google and ChatGPT and got referenses to Belgium (BE) and gave up :slight_smile:
Edit: Ignore this. This does not work with FT which makes sense so for now FT stay.
from 7.23 you can use "network" under wifi. You just configure "common" parameters and it will create everything itself
From 7.24beta its even in winbox :smiley:
P.s. i dont have an be device yet to test this but i have tested it with the AX line (which doesnt have MLO but theres a "enable MLO" setting) :slight_smile:
I would like to test it on new be device but right now I think that my device will arrive just in time for WiFi 8 release.
Got everything running and it's workning great. No stabillity issues as far as I can test. Did not try the mld as I use FT and this is not supported to run at the same time. FT is more important currently so does not matter.
Did a speedtest and had to use a 5g frequenzy that is used close by but managed to get around 600 mbit from a mobile device both up and down. Which is better then what I normally get on my cAP AX.
Now I just need to add Zerotier and fix routing and then off to the site it is going to be in.
It's frustrating. be3 CZ distributor - availability 31.7, then 23.7. (yupee!) and today changed to 17.8. :-(((
@Kindis It's not the Cap AX . . .On one now from my Android tablet, linked to it at 864, and moving traffic at 750 to the Internet (the max my ISP will run) using Speedtest.
(I've had faster links as well . . . )
Yhea I'm wating for a BE3 as well that I plan on using at home and it looks like it is pushed to Aug as well now.
I would say from early to September.
