WiFi ac solution
Dear bro
I bought 3011 router to replace Netgear R7000 router ,now I use r7000 to do ap .
Now,I want to replace the r7000 , which products can provide the better profromance ?
What are your requirements?
Jarda bro
I live Hong Kong,my home is very small…
Just 20-30 device connect by WiFi.(iphone,Android device,cam…)
I saw the product wap ac ,but I don’t know better than r7000 or not,
Maybe you should see this. It has all the wifi you can need.
https://mikrotik.com/product/RB962UiGS-5HacT2HnT
Hap ac better than wap ac?
yes, it has better wifi antena (look to the letters in model number)
wap ac is: RBwAPG-5HacT2HnD (tripal chain fo 5ghz and dual for 2.4)
hap ac is: RB962UiGS-5HacT2HnT (tripal chain fo 5ghz and tripall for 2.4)
